Cloud and Lightning Code
TanksNStuff
Re: Cloud and Lightning Code
Has anyone had any luck modifying this code to work on the dimmer expansion module yet?
I'm getting ready to redo my entire coding for my tank upgrade and was hoping to incorporate clouds/lightning.
- lnevo
- cosmith71
Is there a way to write values directly to the dimming expansion? That's key. Otherwise it won't be fast enough for the right effect.
Actually the wired dimming has a fast enough connection. The wireless one is the one that doesn't.
TanksNStuff
Lee, is that because you haven't had time to try or because you ran into issues/errors that still need to be worked out? If it's simply a matter of changing just the PMWValue variables, maybe I'll try to take a stab at it.
In fact, I'll take a look at it now and see if I can figure it out. I'll report back here if I get it working.
I have wired connection dimmer expansion, so I should be good to go.
- cosmith71
The obstacle is here, in the analogWrite statement. That bypasses the RA libraries to write directly to the daylight pin. It's the only way to get fast enough flashes.
If you want to convert it, you'd need to find an equivalent way to write to the expansion module.
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255)); // Flash on
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
analogWrite(daylightPWMPin,DaylightPWMValue*2.55); // Flash off
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset();
}--Colin
JTMBTech
Sorry if this is a dumb question. Can i use this code to add lightning and cloud to my main white and actinic channels with the output from the relay box dimming ports, and then use the channels 0-3 on dimming expansion (using 4-5 for dc pumps) with the wizard generated code for the my other colored leds, green red uv and 2700k white? i have a diy led with steves led drivers and 6 different color leds over my 180 currently controlled by a typhoon. or would it not get the same effect because the other channels won't have the effect. I was hoping this might work because the main number of leds is white and actinic leds. i didnt realize when i ordered the dimming module and plus upgrade last week that the custom lighting codes had not been written for dimming module because the design had changed. I have very high hopes with the dimming module and just want to use my leds to their full potential! or is the code getting close to be finished for the new dimming module?
- Sacohen
From what I understand this code only works on the relay dimming channels, it hasn't be ported over to the dimming hub yet. So I will work on your white and actinic lights only.
The dimming channel 1-3 will be normal dimming only.
Colin has already ported and made it even better when used with the dimming module.
Let's have him pitch in
- cosmith71
It's ported to the RANet Dimming Expansion, but that code could be adapted. The issue noted a few posts above has been solved. It's just a matter of putting it all together.
I don't have a standard dimming expansion, so there may be some trial and error. I'll see if I can come up with something over the next week or so.
- cosmith71
Roberto, is the address of the standard dimming expansion 0x40? I'm guessing it's the same dimming unit used in the RANet version?
- Sacohen
That awesome.cosmith71 wrote:It's ported to the RANet Dimming Expansion, but that code could be adapted. The issue noted a few posts above has been solved. It's just a matter of putting it all together.
- cosmith71
JTMBTech:
Do you want the Daylight channel, and expansion channels 0-3 to flash? Actinic doesn't flash.
- Rodasphoto
- Contact:
JTMBTech
If the code only effects the white I would want to put my 2700 k white on one chanel, I was thinking 2700k white on relay box and 6300k white either on the same chanel or one of the chanels on the dimming expansion my other led chanels I can put on the remaining dimming expansion chanels, and the actinic chanel. Is the white normally the only chanel that flashes/changes? I just wanted to know if it was possible to use the relay box white output on storm and the expansion dimming ports on standard, however if the code has been ported to the dimming ex pansies I am sure it will work.
- cosmith71
Normally it's just the white that flashes, but that's just personal preference. We can make any channels you like flash.
MDB1029
So this code only works from the relay dimming ports, which are 0-10v, but you can only get the quick lightning flashes using LDD type drivers, 0-5v. Am i missing something here?
- cosmith71
If you have a modified relay box you can get 0-5v from the dimming ports. I thought the dimming module version had been sorted out. I'll look into it.
- cosmith71
Officially adapted for the 6 channel Dimming Expansion Module.
http://forum.reefangel.com/viewtopic.php?f=12&t=5460
troylong45
Has any one been able to override the dc pump setting for when a storm chance is going to happen?
troylong45
any idea on how to not allow the lights to dim to X amount during cloud/strike?
i got my fuge light on oppisite of daylights and daylights are off when dimming is 1% or less and storm code is causing daylights to dim below that level from time to time when actived
i use update led set to Mem_B_LightsOffPerc,1
here is my store code
void UpdateLED() {
ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
#define Clouds_Every_X_Days InternalMemory.read(Mem_B_CloudsEveryXDays)
#define Cloud_Chance_per_Day InternalMemory.read(Mem_B_CloudChancePerDay)
// Minimum number of minutes for cloud duration. Don't use min duration of less than 6
#define Min_Cloud_Duration InternalMemory.read(Mem_B_MinCloudDuration)
#define Max_Cloud_Duration InternalMemory.read(Mem_B_MaxCloudDuration)
#define Min_Clouds_per_Day InternalMemory.read(Mem_B_MinCloudsPerDay)
#define Max_Clouds_per_Day InternalMemory.read(Mem_B_MaxCloudsPerDay)
#define Start_Cloud_After NumMins(InternalMemory.read(Mem_B_StartCloudAfterHour),InternalMemory.read(Mem_B_StartCloudAfterMin))
#define End_Cloud_Before NumMins(InternalMemory.read(Mem_B_EndCloudBeforeHour),InternalMemory.read(Mem_B_EndCloudBeforeMin))
#define Lightning_Chance_per_Cloud InternalMemory.read(Mem_B_LightningChance)
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
// Example: { Calm, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = {Slow};
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
// Commenting out to see if it's interfering with our other seed.
// randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
// if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
if (ReefAngel.Relay.isMaskOn(LED_STORM)) {
InternalMemory.write(Mem_B_EnableStorm,false);
if (ReefAngel.Relay.isMaskOff(LED_STORM)) {
InternalMemory.write(Mem_B_EnableStorm,true);
if (InternalMemory.read(Mem_B_EnableStorm)) return;
if (cloudchance)
if (ReefAngel.Relay.isMaskOff(TRIGGER_STORM)) // Change this to whatever port you want to use as a trigger.
cloudstart = NumMins(hour(), minute());
ReefAngel.Relay.Auto(TRIGGER_STORM); // Here, too.
//is it time for cloud yet?
// Increase Blue channel first for better effect and to compensate for drop in Whites
ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
// Send the trigger
Strike();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
Strike();
break;
case Fast:
Strike();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
if (lightningchance && second()%40<8)
SlowStrike();
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
// Cloud ON option - Clouds every minute
if (ReefAngel.Relay.isMaskOn(TRIGGER_STORM) && now()%60<10)
SlowStrike();
void SlowStrike()
int r = random(100);
if (r<20) lightningstatus=1;
else lightningstatus=0;
if (lightningstatus)
// Let's separate left and right both.
if (r<14) {
DaylightPWMValue0=4095;
DaylightPWMValue2=4095;
ActinicPWMValue1=4095;
ActinicPWMValue3=4095;
} else if (r<17) {
DaylightPWMValue0=100;
DaylightPWMValue2=100;
delay(1);
void DrawClouds(int x, int y)
ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
int x=0;
else x=17;
ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
ReefAngel.CustomVar[0]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
ReefAngel.CustomVar[1]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
ReefAngel.CustomVar[2]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
else x=57;
ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
ReefAngel.CustomVar[7]=(cloudstart+(cloudduration/2))%60;
void Strike()
// Flash on
int newdata=4095;
Wire.beginTransmission(0x40); // Address of the dimming expansion module
Wire.write(0x8+(4*0)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 0.
Wire.write(newdata&0xff); // Send the data 8 bits at a time. This sends the LSB
Wire.write(newdata>>8); // This sends the MSB
Wire.endTransmission();
Wire.write(0x8+(4*2)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 2.
// Flash off. Return to baseline.
newdata=ReefAngel.PWM.GetChannelValueRaw(0); // Use the channel number you're flashing here
Wire.beginTransmission(0x40); // Same as above
newdata=ReefAngel.PWM.GetChannelValueRaw(2); // Use the channel number you're flashing here
wdt_reset(); // Reset watchdog timer to avoid re-boots
cstart*=60;
cend*=60;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
cstart*=60;
cend*=60;
bkc6868
DmnYnkee
Any chance someone can look at this part of my storm coding and let me know why my fluorescents stay on during storm? Is there a better way of doing this?
Thanks much!
Thanks much!
if (cloudchance)
if (ReefAngel.Relay.isMaskOn(Port7)) // Change this to whatever port you want to use as a trigger to start a storm.
ReefAngel.Relay.Auto(Port7); // Here, too.
ReefAngel.Relay.Off(Box1_Port7); // Turn off Fluorescents
ReefAngel.Relay.Auto(Box1_Port7); // Fluorescents back to auto.
// Increase Blue channel first, for better effect and to compensate for drop in Whites
ActinicPWMValue0=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue0,ActinicPWMValue0+DaylightPWMValue1*1.1,180);
ActinicPWMValue2=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue2,ActinicPWMValue2+DaylightPWMValue3*1.1,180);
ActinicPWMValue4=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ActinicPWMValue4,ActinicPWMValue4+DaylightPWMValue5*1.1,180);
// Daylight dimming from cloud
DaylightPWMValue1=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue1/40.95,2,180)*40.95;
DaylightPWMValue3=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue3/40.95,2,180)*40.95;
DaylightPWMValue5=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue5/40.95,2,180)*40.95;-
I don't think this the piece of code that is having problems.
You may have something further down in the code that is overriding this.
Can you post the entire code?
DmnYnkee
As it is now, if I try to manually turn fluorescents on outside of their normal 2pm-6pm time frame, they flash on, then turn right back off, so I think the auto is overriding my manual on attempts as well.
Also while you are looking, my storms always happen at 3:30pm, even though I have the random time portion in my code.
Thanks Roberto!
Thanks Roberto!
#include <SunLocation.h>
#include <Tide.h>
#include <Moon.h>
#include <WiFiAlert.h>
SunLocation sl;
int avgph[10];
unsigned long totalavgph=0;
byte avgindex=0;
byte x;
byte y = 2;
char text[7];
// *********** CHANGE TEMP READOUT COLOR DEPENDENT ON FAN AND HEATER STATUS ***********
int TempColor; // Color for drawing temperature
boolean HeatOn = ReefAngel.Relay.Status(Port2); // Get the status of the heater relay
if (HeatOn)
TempColor = COLOR_NAVY; // Blue text, too cold, heater is on
if (!HeatOn)
TempColor = COLOR_GREEN; // Green text, no fan or heater on
int pHColor; // Color for drawing pH
boolean LowpH = (ReefAngel.Params.PH < 780) ; // Check for Low pH Value
boolean HighpH = (ReefAngel.Params.PH > 850); // Check for High pH Value
if (LowpH)
pHColor = COLOR_NAVY; // Blue text, Low pH value
if (HighpH)
pHColor = COLOR_RED; // Red text, High pH value
if (!LowpH && !HighpH)
pHColor = COLOR_GREEN; // Green text, pH acceptable
ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,DefaultBGColor, 6, 3, " Thunder Reef",Font8x8); // Put a banner at the top
ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 12, 132, 12); // Draw a black line under the banner
x = 6;
y += MENU_START_ROW*1.4; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, COLOR_WHITE, x, y+1, " Temp pH");
ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
x = 2;
y += MENU_START_ROW*1.6;
ReefAngel.LCD.DrawHugeNumbers(COLOR_BLACK, TempColor, x, y, text); // Draw the temperature, white numbers on a colored background
ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
x = 2;
y = MENU_START_ROW*2.6;
ReefAngel.LCD.DrawHugeNumbers(COLOR_YELLOW, pHColor, x+65, y+6, text); // Put pH on the screen
x += 6;
y += MENU_START_ROW*3.3;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Sump Level",Font8x8); // Draw the Sump Float switch status
{ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_RED);
ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
x += 6;
y += MENU_START_ROW*2.0;
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,25,y,"Skimmer Cup",Font8x8); // Draw the Skimmer Cup Float switch status
if (ReefAngel.HighATO.IsActive()) {ReefAngel.LCD.FillCircle(15,y+3,7,COLOR_GREEN);
byte TempRelay = ReefAngel.Relay.RelayData; // Code for drawing the relay box
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
int ActinicPWMValue0=1; // For cloud code, channel 0, left blue
int ActinicPWMValue2=1; // For cloud code, chennel 2, center blue
int ActinicPWMValue4=1; // For cloud code, chennel 4, right blue
int DaylightPWMValue1=1; // For cloud code, channel 1, left white
int DaylightPWMValue3=1; // For cloud code, chennel 3, center white
int DaylightPWMValue5=1; // For cloud code, chennel 5, right white
ReefAngel.Init(); // Initialize controller
ReefAngel.Timer[FEEDING_TIMER].SetInterval(1200); // Feeding timer at 20 minutes (in seconds)
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled in Feeding Mode
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled in Water Change Mode
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit; // Ports toggled when Lights On / Off menu entry selected
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit; // Ports turned off when Overheat temperature exceeded
ReefAngel.TempProbe = T1_PROBE; // Use T1 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 820 ); // Set the Overheat temperature setting
CustomOverheatClear(T1_PROBE);
ReefAngel.Relay.On( Port1 ); // Return
// Ports that are always off
ReefAngel.Relay.Off( Port7 );
// Delayed start for skimmer to allow sump level to return to normal after water change
ReefAngel.Relay.DelayedOn( Port5,5 );
sl.Init(28.5700, -81.6800); // Lat/long for Clermont, FL
sl.SetOffset(-2,0,-2,0); // rise_hour, rise_seconds, set_hour, set_seconds (set 2 hrs later for better viewing time (-4 offset = actual time))
randomSeed(now()%SECS_PER_DAY);
//Custom Variable [0] = Month/Season
ReefAngel.CustomLabels[0]="Return";
ReefAngel.CustomLabels[1]="Heaters";
ReefAngel.CustomLabels[2]="Cooling Fan";
ReefAngel.CustomLabels[3]="ATO/Swabbie";
ReefAngel.CustomLabels[4]="Skimmer";
ReefAngel.CustomLabels[5]="Kalk Stirrer";
ReefAngel.CustomLabels[6]="Storm Mode";
ReefAngel.CustomLabels[7]="Fuge Light";
ReefAngel.CustomLabels[8]="Left Whites";
ReefAngel.CustomLabels[9]="Left Blues";
ReefAngel.CustomLabels[10]="Center Whites";
ReefAngel.CustomLabels[11]="Center Blues";
ReefAngel.CustomLabels[12]="Right Whites";
ReefAngel.CustomLabels[13]="Right Blues";
ReefAngel.CustomLabels[14]="ATI Coral+";
ReefAngel.CustomLabels[15]="Moonlights";
// seasonal temperatures
SeasonalTemps();
// Default lights program
ActinicPWMValue0=PWMSlopeHighRes(10,00,21,30,1,72,180,41); // Default for blues
ActinicPWMValue2=PWMSlopeHighRes(10,15,21,45,1,72,180,41);
ActinicPWMValue4=PWMSlopeHighRes(10,30,22,00,1,72,180,41);
DaylightPWMValue1=PWMSlopeHighRes(12,45,18,45,1,22,105,41); // Default for whites
DaylightPWMValue3=PWMSlopeHighRes(13,00,19,00,1,22,105,41);
DaylightPWMValue5=PWMSlopeHighRes(13,15,19,15,1,22,105,41);
CheckCloud(); // Check for cloud and slow lightning.
ReefAngel.PWM.SetChannelRaw(0,ActinicPWMValue0); // Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(2,ActinicPWMValue2); // lightning if it's time.
ReefAngel.PWM.SetChannelRaw(4,ActinicPWMValue4); // lightning if it's time.
ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue1); // Write values for either default or cloud/slow
ReefAngel.PWM.SetChannelRaw(3,DaylightPWMValue3); // lightning if it's time.
ReefAngel.PWM.SetChannelRaw(5,DaylightPWMValue5); // lightning if it's time.
// Turn Actinic outlets on if any % is >= 2
(ReefAngel.PWM.GetChannelValue(0)>=2) ? ReefAngel.Relay.On( Box1_Port2 ) : ReefAngel.Relay.Off( Box1_Port2 );
(ReefAngel.PWM.GetChannelValue(2)>=2) ? ReefAngel.Relay.On( Box1_Port4 ) : ReefAngel.Relay.Off( Box1_Port4 );
(ReefAngel.PWM.GetChannelValue(4)>=2) ? ReefAngel.Relay.On( Box1_Port6 ) : ReefAngel.Relay.Off( Box1_Port6 );
//Turn Daylight outlet on if any % is >=2
(ReefAngel.PWM.GetChannelValue(1)>=2) ? ReefAngel.Relay.On( Box1_Port1 ) : ReefAngel.Relay.Off( Box1_Port1 );
(ReefAngel.PWM.GetChannelValue(3)>=2) ? ReefAngel.Relay.On( Box1_Port3 ) : ReefAngel.Relay.Off( Box1_Port3 );
(ReefAngel.PWM.GetChannelValue(5)>=2) ? ReefAngel.Relay.On( Box1_Port5 ) : ReefAngel.Relay.Off( Box1_Port5 );
// ATI Coral+ Flourescents
if (hour()>=14 && hour()<18)
ReefAngel.Relay.Off( Box1_Port7 );
// Refugium Light: sPar38-Fuge
if (hour()<18 || hour() >=20)
ReefAngel.Relay.Off( Port8 );
// Moonlight Strip
if (hour()>=8 && hour()<23)
ReefAngel.Relay.Off( Box1_Port8 );
//Enclosure cooling fan control with T2 probe
if (ReefAngel.Params.Temp[T2_PROBE]>=820) ReefAngel.Relay.On( Port3 );
if (ReefAngel.Params.Temp[T2_PROBE]<800) ReefAngel.Relay.Off( Port3 );
// pp-15 powerheads schedule
if (hour()>=8 && hour()<10)
ReefAngel.PWM.SetDaylight( ReefCrestMode(40,5,true) ); // reefcrest at 40% +/- 5% on sync mode (Morning Mode)
ReefAngel.PWM.SetActinic( ReefCrestMode(40,5,false) ); // reefcrest at 40% +/- 5% on Anti-sync mode (Morning mode)
else if (hour()>=10 && hour()<13)
//byte random_speed=random(35,50);
//byte random_duration=random(3,7);
ReefAngel.PWM.SetDaylight( GyreMode(25,70,15,true) ); // Ramping 25%-70% for 15 min on sync mode (Gyre)
ReefAngel.PWM.SetActinic( GyreMode(25,70,15,false) ); // Ramping 25%-70% for 15 min on anti-sync mode (Gyre)
else if (hour()>=13 && hour()<15)
byte random_speed=random(40,60);
byte random_duration=random(3,5);
ReefAngel.PWM.SetDaylight( LongPulseMode(25,random_speed,random_duration,true) ); // Long Pulse 25% ramping up to 40%-60% for 3-5 seconds on sync mode (Medium swells)
ReefAngel.PWM.SetActinic( LongPulseMode(25,random_speed,random_duration,false) ); // Long Pulse 25% ramping up to 40%-60% for 3-5 seconds on Anti-sync mode (Medium swells)
else if (hour()>=15 && hour()<17)
byte random_speed=random(40,50);
ReefAngel.PWM.SetDaylight( ShortPulseMode(1,random_speed,408,true) ); // Short pulse at 45%-60% with 408ms pulse on sync mode (surface wave 1/2"-3/4")
ReefAngel.PWM.SetActinic( ShortPulseMode(1,random_speed,408,false) ); // Short pulse at 45%-60%% with 408ms pulse on Anti-sync mode (surface wave 1/2"-3/4")
else if (hour()>=17 && hour()<19)
byte random_duration=random(2,5);
ReefAngel.PWM.SetDaylight( LongPulseMode(1,random_speed,random_duration,true) ); // Long Pulse 1% ramping up to 40%-50% for 2-5 seconds on sync mode (Feeding hour)
ReefAngel.PWM.SetActinic( LongPulseMode(1,random_speed,random_duration,false) ); // Long Pulse 1% ramping up to 40%-50% for 2-5 seconds on Anti-sync mode (Feeding hour)
else if (hour()>=19 && hour()<20)
byte random_min=random(35,45);
byte random_speed=random(50,65);
byte random_duration=random(2,6);
ReefAngel.PWM.SetDaylight( LongPulseMode(random_min,random_speed,random_duration,true) ); // Long Pulse 35%-45% ramping up to 50%-65% for 2-5 seconds on sync mode (nutrient transport)
ReefAngel.PWM.SetActinic( LongPulseMode(random_min,random_speed,random_duration,false) ); // Long Pulse 35%-45% ramping up to 50%-65% for 2-5 seconds on Anti-sync mode (nutrient transport)
else if (hour()>=20 && hour()<21)
ReefAngel.PWM.SetDaylight( ReefCrestMode(40,10,true) ); // reefcrest at 40% +/- 10% on sync mode (Evening Mode)
ReefAngel.PWM.SetActinic( ReefCrestMode(40,10,false) ); // reefcrest at 40% +/- 10% on Anti-sync mode (Evening mode)
ReefAngel.PWM.SetDaylight( ReefCrestMode(35,10,true) ); // reefcrest at 35% +/- 10% on sync mode (night Mode)
ReefAngel.PWM.SetActinic( ReefCrestMode(35,10,false) ); // reefcrest at 35% +/- 10% on Anti-sync mode (night mode)
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
ReefAngel.PWM.SetActinic(20);
ReefAngel.PWM.SetDaylight(20);
if( ReefAngel.DisplayedMenu==WATERCHANGE_MODE )
ReefAngel.PWM.SetActinic(1);
ReefAngel.PWM.SetDaylight(1);
// enter feeding mode at 6:15pm
//if ( (hour()==18 && minute()==15 && second()==0))
//ReefAngel.FeedingModeStart(); // turn on feeding mode
if(ReefAngel.HighATO.IsActive()) // Float switch in Skimmer Locker
ReefAngel.Relay.Off(Port5); // Turn off Skimmer when locker full.
// ATO, Port 8 is ATO using Clear RoDi
ReefAngel.SingleATO(true,Port4,400,0); // Sump switch. If ATO/RoDi runs for 400 seconds, then shut off and send alert.
sl.CheckAndUpdate(); // handle updating sunrise and sunset values
ReefAngel.Portal( "DmnYnkee" );
void SeasonalTemps ()
static int heatArray[][2] = { {786,790}, // default in case of error in month=0 (June)
{786,790},//January (winter) // 77.6
{786,790},//February (winter) // 77.8
{786,790},//March (early spring) // 78.0
{786,790},//April (spring) // 78.2
{786,790},//May (spring) // 78.4
{786,790},//June (early summer) // 78.8
{786,790},//July (summer) // 79.2
{786,790},//August (summer) // 79.6
{786,790},//September (early fall) // 79.2
{786,790},//October (fall) // 78.8
{786,790},//November (fall) // 78.4
{786,790} };//December (early winter) // 78.0
ReefAngel.StandardHeater( Port2,heatArray[month()][0],heatArray[month()][1]);
}//end seasonalTemps
// ------------------------------------ Auto overheat clear
void CustomOverheatClear(byte probe)
if((bitRead(ReefAngel.AlertFlags, OverheatFlag)) && (ReefAngel.Params.Temp[probe] <= InternalMemory.OverheatTemp_read()-30))
ReefAngel.OverheatClear();
// ------------------------------------------------------------ Weather section
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 2
// In this example, start cloud after 1:30pm
#define Start_Cloud_After NumMins(13,30)
// In this example, end cloud before 6:30pm
byte LightningModes[] = { Mega }; // <---- set Storm modes here
#else
#endif
if (cloudchance)
if (cloudchance)
//if (NumMins(hour(),minute())>=cloudstart && NumMins(hour(),minute())<(cloudstart+cloudduration))
//ReefAngel.Relay.Off(Box1_Port7); // Turn off Flourescents
//else
//ReefAngel.Relay.Auto(Box1_Port7); // Flourescents back to auto.
case Calm:
break;
case Mega:
// Send the trigger
int r=random(34);
if (r<20) {
Strike1(); // All 3 lights
} else if (r<22) {
Strike2(); // Left only
} else if (r<24) {
Strike3(); // Center only
} else if (r<28) {
Strike4(); // Right only
} else if (r<30) {
Strike5(); // Left & Center
} else if (r<34)
Strike6(); // Center & Right
DelayTime=random(1800); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
Strike();
break;
case Fast:
Strike();
break;
case Slow:
SlowStrike();
break;
default:
break;
cloudindex++;
if (ReefAngel.Relay.isMaskOff(Port7) && now()%60<10)
SlowStrike();
void SlowStrike()
int r = random(80);
// Let's separate left, center, right, or All.
if (r<10 ) { // All 3
DaylightPWMValue1=4095;
DaylightPWMValue3=4095;
DaylightPWMValue5=4095;
} else if (r<12) { // Left only
DaylightPWMValue3=100;
DaylightPWMValue5=100;
} else if (r<14) { // Center only
DaylightPWMValue1=100;
} else if (r<16) { // Right only
} else if (r<18) { // Left & Center only
} else { // Center & Right only
delay(1);
int x=0;
else x=17;
//ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
else x=35;
//ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
void Strike1() // All 3 lights
// Flash on
int newdata=4095;
Wire.write(0x8+(4*1)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 1.
Wire.write(0x8+(4*3)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 3.
Wire.write(0x8+(4*5)); // 0x8 is channel 0, 0x12 is channel 1, etc. This is channel 5.
newdata=ReefAngel.PWM.GetChannelValueRaw(1); // Use the channel number you're flashing here
newdata=ReefAngel.PWM.GetChannelValueRaw(3); // Use the channel number you're flashing here
newdata=ReefAngel.PWM.GetChannelValueRaw(5); // Use the channel number you're flashing here
void Strike2() // Left only
int a=random(1,4); // Pick a number of consecutive flashes from 1 to 3.
// Flash on
int newdata=4095;
void Strike3() // Center only
// Flash on
int newdata=4095;
void Strike4() // Right only
// Flash on
int newdata=4095;
void Strike5() // Left & Center
// Flash on
int newdata=4095;
void Strike6() // Center & Right
// Flash on
int newdata=4095;
void Strike()
// Flash on
int newdata=4095;
cstart*=60;
cend*=60;
int ReversePWMSlope(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
cstart*=60;
cend*=60;
