Can you tell me how many watts the basic Reef Angel draw with just the pH module and also the wifi unit?
Many thanks
How many watts does it draw?
clownfishy
Many thanks,
Kind Regards
Clownfishy
Kind Regards
Clownfishy
tkeracer619
Re: How many watts does it draw?
watts? negligible.
I can provide you with the info if nobody else does on friday. My guess is less then ~3?
clownfishy
That would be cool if you could. I am running an experiment at the moment to see how low I can go running my nano so want to keep wattage as low as possible.
Many thanks
Many thanks
Many thanks,
Kind Regards
Clownfishy
Kind Regards
Clownfishy
clownfishy
Did anyone work out how many watts the controller uses in it default settings?
Many thanks,
Kind Regards
Clownfishy
Kind Regards
Clownfishy
ChrisL1976
Go buy yourself a Kill-a-watt tester. One of the best $20 bucks you will ever spend.
You can test amps, watts, kilowatts per hour. Its really useful for all kind of testing.
Search amazon for Killawatt.....just saw it for like $16
clownfishy
I dont have a unit yet so just wondered if anyone could measure the watts the base RA draws?
Many thanks
Many thanks
Many thanks,
Kind Regards
Clownfishy
Kind Regards
Clownfishy
It's very little. What will consume energy is the equipment you connect to it.
Would you mind sharing what you have in mind?
