How many watts does it draw?
Posted: Mon Apr 02, 2012 9:46 am
by clownfishy
Can you tell me how many watts the basic Reef Angel draw with just the pH module and also the wifi unit?
Many thanks
Re: How many watts does it draw?
Posted: Mon Apr 02, 2012 9:22 pm
by tkeracer619
watts? negligible.
I can provide you with the info if nobody else does on friday. My guess is less then ~3?
Posted: Tue Apr 03, 2012 11:30 am
by clownfishy
That would be cool if you could. I am running an experiment at the moment to see how low I can go running my nano so want to keep wattage as low as possible.
Many thanks
Posted: Sun Jun 03, 2012 1:31 pm
by clownfishy
Did anyone work out how many watts the controller uses in it default settings?
Posted: Thu Jun 14, 2012 11:25 am
by ChrisL1976
Go buy yourself a Kill-a-watt tester. One of the best $20 bucks you will ever spend.
You can test amps, watts, kilowatts per hour. Its really useful for all kind of testing.
Search amazon for Killawatt.....just saw it for like $16
Posted: Tue Mar 26, 2013 12:53 am
by clownfishy
I dont have a unit yet so just wondered if anyone could measure the watts the base RA draws?
Many thanks
Posted: Tue Mar 26, 2013 8:29 am
It's very little. What will consume energy is the equipment you connect to it.
Would you mind sharing what you have in mind?
