unreachable address and Error code 11: bad URL?
Posted: Mon Apr 02, 2012 1:30 pm
by miked
I am getting and errorcode11 bad URL when attempting to access my portal from the android app on my tablet. It worked previously and I am also getting the unreachable address error on the portal here on RA?
My DNS is still showing my current IP. Any one else run into this, any thoughts?
thanks
Re: unreachable address and Error code 11: bad URL?
Posted: Mon Apr 02, 2012 1:40 pm
by miked
also, my RA wifi is no longer showing up in my attached devices for my router?
Posted: Mon Apr 02, 2012 2:25 pm
Can you try rebooting the wifi atatchment?
Also, you may want to restore to factory settings and set iy up again.
I've seen cases where settings were not saved correctly that caused this behavior.
Posted: Mon Apr 02, 2012 6:01 pm
by miked
yep, just reset, unplugged the RA and now it works. Thanks
Posted: Sun Nov 03, 2013 10:46 pm
by Francois
I'm getting this all the time where I have to restore to factory settings and set it up again. Why does the wifi expansion unit only keeping the settings for a few hours and then bombs out?
