My almost completed pde
Posted: Wed Apr 04, 2012 6:36 am
Hi
Well, here it is , its only the "vortech menu" I still need to work on, and spacing of display
Any comments welcome!
And this is still a bit wrong - should pull values from PWM expansion and not atinics. Is there a document on the forum with code explanations? like ReefAngel.PWM.GetAtinicValue , and then the function of it?
// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 22:54)
/*Included Features File
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define RelayExp
#define PWMEXPANSION
#define CUSTOM_MAIN
#define SALINITYEXPANSION
#define RFEXPANSION
#define IOEXPANSION
#define CUSTOM_MAIN
#define CUSTOM_MENU_ENTRIES 9
#define COLORS_PDE
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
#include <avr/pgmspace.h>>
//---------------------------------------------------- PWM Cloud ------------------------------------------------------------------
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
boolean ForceCloud=false;
boolean ForceLightning=false;
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDWhiteBlue 0
#define LEDWhiteBlue1 1
#define LEDWhiteBlue2 2
#define MixedLED 3
#define LEDMoonlights 4
// Initial values to all 6 PWM channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//MoonPhase Value Setting
byte MoonPWMValue;
// Globals Needed for Params on Custom Main
byte x,y;
int v;
int maxTemp=0;
int minTemp=2000;
int maintemp=270;
int roomtemp=300;
int ph=700;
int maxPH=600;
int minPH=900;
byte TempRelay =15;
byte TempRelay2=15;
byte vtechmode;
boolean bFeeding=false;
//------------------------------------------------------ Custom Menu Code ---------------------------------------------------------
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Salinity Calibration";
prog_char menu7_label[] PROGMEM = "Vortech Setup";
prog_char menu8_label[] PROGMEM = "Force Cloud";
prog_char menu9_label[] PROGMEM = "Force Lightning";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupCalibrateSalinity();
void MenuEntry7()
void MenuEntry8()
ForceCloud=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry9()
ForceLightning=true;
//------------------------------------------------------ Grouped Menu Entries ----------------------------------------------------
menu4_label, menu5_label, menu6_label,
menu7_label,menu8_label,menu9_label
//---------------------------------------------------------- Custom Main ----------------------------------------------------------
void DrawCircle(int a, int b, int r, byte color)
int f = 1 - r;
int ddF_x = 1;
int ddF_y = -2 * r;
int x = 0;
int y = r;
ReefAngel.LCD.PutPixel(color, a, b+r);
ReefAngel.LCD.PutPixel(color ,a, b-r);
ReefAngel.LCD.PutPixel(color, a+r, b);
ReefAngel.LCD.PutPixel(color, a-r, b);
while (x<y)
if (f >= 0)
{ y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
ReefAngel.LCD.PutPixel(color, a + x, b + y);
ReefAngel.LCD.PutPixel(color, a - x, b + y);
ReefAngel.LCD.PutPixel(color, a + x, b - y);
ReefAngel.LCD.PutPixel(color, a - x, b - y);
ReefAngel.LCD.PutPixel(color, a + y, b + x);
ReefAngel.LCD.PutPixel(color, a - y, b + x);
ReefAngel.LCD.PutPixel(color, a + y, b - x);
ReefAngel.LCD.PutPixel(color, a - y, b - x);
void FillCircle(int a, int b, int r, byte color)
int f = 1 - r;
int ddF_x = 1;
int ddF_y = -2 * r;
int x = 0;
int y = r;
for (int i=b-r; i<=b+r; i++)
ReefAngel.LCD.PutPixel(color, a, i);
while (x<y)
if (f >= 0)
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
for (int i=b-y; i<=b+y; i++)
ReefAngel.LCD.PutPixel(color, a+x, i);
ReefAngel.LCD.PutPixel(color, a-x, i);
for (int i=b-x; i<=b+x; i++)
ReefAngel.LCD.PutPixel(color,a+y, i);
ReefAngel.LCD.PutPixel(color,a-y, i);
void DrawCircleBox (byte x, byte y, byte RelayData)
byte b = 0;
byte c = 0;
byte d = 0;
for (byte a=0;a<2;a++)
DrawCircle ((a*10)+x,y+30,5,COLOR_BLACK);
if ((RelayData&(1<<a))==1<<a)
FillCircle((a*10)+x,y+30,3,OutletOnBGColor);
FillCircle((a*10)+x,y+30,3,OutletOffBGColor);
for (byte a=2;a<4;a++)
b=(a-2)*10;
DrawCircle (b+x,y+20,5,COLOR_BLACK);
FillCircle(b+x,y+20,3,OutletOnBGColor);
FillCircle(b+x,y+20,3,OutletOffBGColor);
for (byte a=4;a<6;a++)
c=(a-4)*10;
DrawCircle (c+x,y+10,5,COLOR_BLACK);
FillCircle(c+x,y+10,3,OutletOnBGColor);
FillCircle(c+x,y+10,3,OutletOffBGColor);
for (byte a=6;a<8;a++)
d=(a-6)*10;
DrawCircle (d+x,y,5,COLOR_BLACK);
FillCircle(d+x,y,3,OutletOnBGColor);
FillCircle(d+x,y,3,OutletOffBGColor);
//Top Banner
ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 1, " Drop Reef Tank ", Font8x8); //Top Banner
// Display T1 Header Text
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,255,30,15,"Sump Temp", Font8x8);
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 35, 25, 50, 60);
if (maintemp>270) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 35, 25, text);
else if (maintemp>270) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 35, 25, text);
else ReefAngel.LCD.DrawHugeNumbers(COLOR_MIDNIGHTBLUE, 255, 35, 25, text);
// Display the T2 Header Text
ReefAngel.LCD.DrawLargeText(0,255,8,50,"Room Temp", Font8x8);
// Display the T2 Temp Value
ReefAngel.LCD.Clear(255, 90, 50, 132, 60);
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 50, text, Num8x8);
// Display pH Header Text
ReefAngel.LCD.DrawLargeText(COLOR_DARKSLATEBLUE,255,102,75,"pH", Font8x8);
// Display pH Value
ConvertNumToString(text, ph, 100);
ReefAngel.LCD.Clear(0, 65, 62 , 65, 62);
if (ph>840 || ph<790) ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 95, 88, text, Num8x8);
else if (ph>830 || ph<800) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, 255, 95, 88, text, Num8x8);
else ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 95, 88, text, Num8x8);
// Display Vortech Mode
ReefAngel.LCD.DrawLargeText(0,255,8,60,"Vortech", Font8x8);
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 90, 60, 132, 70);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 66, 60,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 66, 60,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 66, 60,"RCM");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 66, 60,"Short");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255, 66, 60,"Long");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 66, 60,"NTM");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 66, 60,"TSM");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255, 66, 60,"Night");
// Display Salinity
ReefAngel.LCD.DrawLargeText(0,255,66,100,"Salinity", Font8x8);
// Display Salinity Value
ReefAngel.LCD.Clear(255, 82, 85, 65, 95);
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 65, 110, text, Num8x8);
//Start Moon Phase Display
x += (16*4) + 8;
y += MENU_START_ROW+3;
if (ReefAngel.PWM.GetChannelValue(4) ==0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,75,"Off");
else if(ReefAngel.PWM.GetChannelValue(4) >=1 && ReefAngel.PWM.GetChannelValue(4) < 5) ReefAngel.LCD.DrawText(20,255,81,75,"New");
else if(ReefAngel.PWM.GetChannelValue(4) >=5 && ReefAngel.PWM.GetChannelValue(4) < 10) ReefAngel.LCD.DrawText(20,255,81,75,"Cresent");
else if(ReefAngel.PWM.GetChannelValue(4) >=10 && ReefAngel.PWM.GetChannelValue(4) < 20) ReefAngel.LCD.DrawText(20,255,81,75,"Half");
else if(ReefAngel.PWM.GetChannelValue(4) >=20 && ReefAngel.PWM.GetChannelValue(4) < 30) ReefAngel.LCD.DrawText(20,255,81,75,"Gibbous");
else if(ReefAngel.PWM.GetChannelValue(4) >=30 && ReefAngel.PWM.GetChannelValue(4) < 45) ReefAngel.LCD.DrawText(20,255,81,75,"Full");
//End Display Moon Phase Display
// Display Main and Expansion Relay Box
DrawCircleBox (10,90,TempRelay);
DrawCircleBox (40,90,TempRelay2);
void DrawCustomGraph() // Not Used
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
ReefAngel.SetTemperatureUnit(1);
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit;
//---------------------------------------------------- Ports that are always on ----------------------------------------------------
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port2);
ReefAngel.Relay.On(Box1_Port6);
ReefAngel.Relay.On(Box1_Port8);
//--------------------------------------------------------- RF Module Setup -------------------------------------------------------
// ReefAngel.RF.SetMode(Slave_Start,0,0);
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'RF'
Please make sure that you enabled RF Expansion on your features file.
Open RAGen and make sure you have RF Expansion checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define RFEXPANSION
InternalMemory.RFMode_write(0);
InternalMemory.RFSpeed_write(128);
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
//------------------------------------------------------ Specific functions -------------------------------------------------------
ReefAngel.Relay.DelayedOn(Port2, 1);
ReefAngel.StandardATO(Port3);
ReefAngel.MoonLights(Port5);
ReefAngel.StandardLights(Box1_Port6);
ReefAngel.StandardLights(Box1_Port7,120);
ReefAngel.MHLights(Box1_Port8);
ReefAngel.StandardHeater(Port6);
//------------------------------------------------ Start PWM Expansion Code for Slope ----------------------------------------------
PWMChannel[LEDWhiteBlue]=PWMSlope(
InternalMemory.StdLightsOnHour_read(),
InternalMemory.StdLightsOnMinute_read(),
InternalMemory.StdLightsOffHour_read(),
InternalMemory.StdLightsOffMinute_read(),
InternalMemory.PWMSlopeStartD_read(),
InternalMemory.PWMSlopeEndD_read(),
InternalMemory.PWMSlopeDurationD_read(),
0);
PWMChannel[MixedLED]=PWMSlope(
InternalMemory.PWMSlopeStartA_read(),
InternalMemory.PWMSlopeEndA_read(),
InternalMemory.PWMSlopeDurationA_read(),
0);
PWMChannel[LEDWhiteBlue1]=PWMChannel[LEDWhiteBlue];
PWMChannel[LEDWhiteBlue2]=PWMChannel[LEDWhiteBlue];
ReefAngel.PWM.SetChannel(0,PWMChannel[LEDWhiteBlue]);
ReefAngel.PWM.SetChannel(1,PWMChannel[LEDWhiteBlue1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[LEDWhiteBlue2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[MixedLED]);
//---------------------------------------------------------PWM Slope Per Channel-----------------------------------------------------
MoonPWMValue=MoonPhase();
if (hour()==22 || hour()==6)
MoonPWMValue=PWMSlope(22,00,7,00,0,MoonPhase(),60,0);
if (PWMChannel[LEDWhiteBlue]) MoonPWMValue=0;
ReefAngel.PWM.SetChannel(4,MoonPWMValue);
// PWMChannel[LEDWhiteBlue1]=PWMSlope(15,0,21,30,15,45,90,PWMChannel[LEDWhiteBlue1]);
PWMChannel[LEDWhiteBlue]=PWMSlope(8,0,22,0,0,90,300,PWMChannel[LEDWhiteBlue]);
PWMChannel[LEDWhiteBlue1]=PWMSlope(8,30,21,30,0,90,270,PWMChannel[LEDWhiteBlue1]);
PWMChannel[LEDWhiteBlue2]=PWMSlope(9,0,21,0,0,90,240,PWMChannel[LEDWhiteBlue2]);
PWMChannel[MixedLED]=PWMSlope(12,0,18,0,0,90,60,PWMChannel[MixedLED]);
// In the example above, we are starting the slope at 8:00am with 0% and going up to 90% within 300 minutes, which would be 5:00pm.
// Then it would stay at 90% from 13:00pm to 300 minutes prior to 10:00pm, which would be 5:00pm.
// Then from 8:00pm, it would start sloping down from 45% all the way back to 15% within 90 minutes, which would be 9:30pm.
//CheckCloud(); (May be used at a later date with cloud/storm effects)
if (hour()>=22 || hour()<8)
ReefAngel.PWM.SetChannel(4,MoonPhase()); //Moon phase schedule between 10:00pm - 7:00am
ReefAngel.PWM.Expansion(LEDWhiteBlue,int(PWMChannel[LEDWhiteBlue]));
ReefAngel.PWM.Expansion(LEDWhiteBlue1,int(PWMChannel[LEDWhiteBlue1]));
ReefAngel.PWM.Expansion(LEDWhiteBlue2,int(PWMChannel[LEDWhiteBlue2]));
ReefAngel.PWM.Expansion(MixedLED,int(PWMChannel[MixedLED]));
//------------------------------------------------- End PWM Expansion Code for Slope ----------------------------------------------
//------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
//------------------------------------------------ Start Feeding Mode Schedule ----------------------------------------------------
// if the hour is 7pm, minute is 30 and seconds is 0
// start the feeding mode
if ( ((hour() == 17) &&
(minute() == 30) &&
(second() == 0) ) )
vtechmode = InternalMemory.RFMode_read();
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
if (hour() >=8 && hour() <= 22)
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,155,5);
ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
ReefAngel.Timer[4].Start();
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
ReefAngel.RF.UseMemory=true;
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=22 || hour()<8) // Defining "Nightmode" hours for VorTech = between 10 PM and 8 AM
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
ReefAngel.Portal("JNieuwenhuizen");
// From Roberto - THANKS ROBERTO!
void CheckCloud()
#define Clouds_Every_5_Days 1
#define Cloud_Chance_per_Day 25
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(12,00)
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(18,0)
#define Lightning_Change_per_Cloud 25
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000101
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B001010
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
//fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(26);
if ((day()%Clouds_Every_5_Days)!=0) cloudchance=0;
// If we have cloud today
if (cloudchance)
lightningchance=random(36);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
lightningchance=random(100);
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//End Cloud & Lighting
x += (16*4) + 8;
if (ReefAngel.PWM.GetActinicValue() ==0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,5,55,"Off");
else if(ReefAngel.PWM.GetActinicValue() >=1 && ReefAngel.PWM.GetActinicValue() < 5)
ReefAngel.LCD.DrawText(20,255,81,55,"New");
else if(ReefAngel.PWM.GetActinicValue() >=5 && ReefAngel.PWM.GetActinicValue() < 10)
ReefAngel.LCD.DrawText(20,255,81,55,"Cresent");
else if(ReefAngel.PWM.GetActinicValue() >=10 && ReefAngel.PWM.GetActinicValue() < 20)
ReefAngel.LCD.DrawText(20,255,81,55,"Half");
else if(ReefAngel.PWM.GetActinicValue() >=20 && ReefAngel.PWM.GetActinicValue() < 30)
ReefAngel.LCD.DrawText(20,255,81,55,"Gibbous");
else if(ReefAngel.PWM.GetActinicValue() >=30 && ReefAngel.PWM.GetActinicValue() < 45)
ReefAngel.LCD.DrawText(20,255,81,55,"Full");
