PWMParabola( )
Sebyte
PWMParabola( )
Am I correct in thinking that PWMParabola( ) is only available to the PWM expansion module?
If so, is there any way of providing a parabola style of control to the two PWM channels on the main relay box?
If not how do you direct the function to control them.
Sebyte
Re: PWMParabola( )
Alread dId that but did not get the result I was expecting.
Both channels worked at the same level,even though different start and end times were set in the pwmparabola() for actinic and daylight.
Will take another look.
Sebyte
Re: PWMParabola( )
Roberto
I looked again at the example and rebuilt my code from scratch. I still had the same problem, that Port 7 and Port 8 come on at the same time. When Port 8 should be 1 hour after port 7.
This means that the Daylight LED's come on at the same time as the Royal Blues and sit at 5% for one hour then start to ramp up. I don't want them on at all during that hour and want Port8 off so that the MeanWell driver is not powered up. I proved Port8 was live by pulling the driver plug from the socket.
If you can please take a look at the code and see where I am wrong.
Many thanks
PS: You may notice that the date stamp on my banner below is wrong. It appears to be ahead of time
// Autogenerated file by RAGen (v1.2.2.171), (04/05/2012 08:19)
// RA_033112_0819.ino
#define DisplayLEDPWM
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 5
Ports assignment:
Port8 - Daylight fixture - "http://www.reefangel.com/Support.Relay-function-StandardLights.ashx"
Port7 - Actinic fixture
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Overheat Clear";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
// Initialize the custom menu
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port6);
// ReefAngel.SingleATOLow(Port2); // commented out 27/11/11 advice of rimai re ATO shutdown like overheat
ReefAngel.StandardFan(Port4);
ReefAngel.Wavemaker1(Port5);
ReefAngel.StandardLights(Port7);
ReefAngel.StandardLights(Port8);
// Activate Watch Dog Timer at 6am and 6pm
if ((now()%86400)==21600) delay(1000);
if ((now()%86400)==43200) delay(1000);
// ATO available 6 times per day - 00:00 to 01:00, 04:00 to 05:00, 08:00 to 09:00, 12:00 to 13:00, 16:00 to 17:00, 20:00 to 21:00,
if (hour() % 4 == 0 && ReefAngel.LowATO.IsActive()) //Rev made 19/11/11
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.Off(Port2);
// Kalk Reactor available 6 times per day - 01:30 to 2:00, 05:30 to 06:00, 09:30 to 10:00,
// 13:30 to 14:00, 17:30 to 18:00, 21:30 to 2:00.
if (hour() % 4 == 1 && minute()>30)
pinMode(highATOPin,OUTPUT);
digitalWrite(highATOPin,HIGH); // Turn on Solid State Relay
digitalWrite(highATOPin,LOW); // Turn off Solid State Relay
// Wavemaker not available 9 pm to 10 am
if ( (hour() >= 20) || (hour() <= 9) )
ReefAngel.Relay.Off(Port5);
//LED SETUP
ReefAngel.StandardLights(Port7,9,0,22,0); // Actinic LED Lights on at 9:00am and off at 10:00pm
ReefAngel.StandardLights(Port8,10,0,21,0); // Daylight LED Lights on at 10:00am and off at 9:00pm
// PWMParabola(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
// startHour - Hour of the start the slope
// startMinute - Minute of the start the slope
// endHour - Hour of the end of the slope
// endMinute - Minute of the end slope
// startPWM - Beginning PWM value
// endPWM - Ending PWM value
// oldValue - Should be the startPWM value or the existing/current PWM value (ReefAngel.PWM.GetActinicValue() or GetDaylightValue())
ReefAngel.PWM.SetActinic(PWMParabola(9,0,22,0,5,100,5));
// Actinic PWM % starts raising from 5% to 100% and back down to 5% from 9:00am to 10:00pm forming a parabola.
ReefAngel.PWM.SetDaylight(PWMParabola(10,0,21,0,5,100,5));
// Daylight PWM % starts raising from 5% to 100% and back down to 5% from 10:00am to 9:00pm forming a parabola.
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'PWM'
Please make sure that you enabled Display LED PWM on your features file.
Open RAGen and make sure you have Display LED PWM checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
ReefAngel.Portal("sebyte", "xxxx"); // invoke Portal
// End of void loop()
Re: PWMParabola( )
http://forum.reefangel.com/status/banne ... ebyte&t=-7
-7 is the time difference from GMT
Sebyte
Re: PWMParabola( )
When I set the start to 0% instead of 5% everything worked as expected. My drivers kick in at 3%.I'll look into the parabola function
Strange
Re: PWMParabola( )
Seriously?
Those meanwell with multi signal start at 3%?
How dim is it?
Can it be used as moonlight?
Let me look at the code right now.
How dim is it?
Re: PWMParabola( )
I just loaded the example code and modified to what you had in the code above:
At 9:24am, I had AP: 13% and DP: 5%
At 11:00am, I had AP: 48% and DP: 31%
At 3:01pm, I had AP: 99% and DP: 99%
At 8:16pm, I had AP: 43% and DP: 24%
Seemed to be working fine.
So, I went and loaded with this, since you said that start 0% was giving problems:
At 9:24am, I had AP: 8% and DP: 0%
At 11:00am, I had AP: 45% and DP: 27%
At 8:16pm, I had AP: 40% and DP: 20%
Seemed to be working fine too.
So, I went ahead and loaded your code.
So, I'm not so sure why it wasn't working right...
ReefAngel.PWM.SetActinic(PWMParabola(9,0,22,0,0,100,0));
ReefAngel.PWM.SetDaylight(PWMParabola(10,0,21,0,0,100,0));
Sebyte
Re: PWMParabola( )
Roberto
I have two Meanwell LPF-60D-48, one for 10000K, the other for Royal blue. Each driver has 28 LED's in series/parallel circuit. When the blues kick in you have a deep blue light which makes the corals pop! It is a fraction brighter than my 8 x 1watt moonlights. I guess I could run them during the night but as I already have moonlights which I am happy with, I think I will stick as I am.
Initially I thought it was at 5% that they came on. That is why I set the start to 5%. But this morning playing around I set the start to 0% and watched as they ramped up. After 10 minutes the royal blues started, and the RA controller showed the actinic channel at 3%.Seriously?
How dim is it?
