Lights issue
Posted: Fri Apr 06, 2012 12:27 pm
by Threedo
I used the RAGen application and easily selected the setup i wanted to get things up and running while i spend time creating a custom code. However, the first time i updated i had a selection for Halides and Standard lights and now whenever i upload code i only get the option to select the times for Halides and Halide delay.
Also... this timer does not seem to be running correctly if i click turn on or off the lights from the menu is there somewhere i need to set it back to normal settings so that it will go back to the timers set in the menu?
thanks!
Re: Lights issue
Posted: Fri Apr 06, 2012 1:25 pm
I'm assuming you are talking about the menu when you press the joystick, right?
The option MH or Standard lights get included if you choose the function when generating your code.
For example, if you use Port1 for MH and Port2 for Standard, both are gonna be included.
If you choose only MH, only MH will be included. The same for Standard.
the Lights On/Off option on the menu will work if you pick the correct ports when generating the code too.
There is a series of checkbox for Lights On. You need to pick which ports you want to turn on/off when you hit that menu option.
Re: Lights issue
Posted: Sun Apr 08, 2012 4:00 pm
by Threedo
I select port 3 and 4 as halides and standard lights... whichever one is on port 4 seems to not bee added to the menus. Here is the code and i notice its not adding it to #define
// Autogenerated file by RAGen (v1.2.2.171), (04/08/2012 17:57)
// RA_040812_1757.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DisplayLEDPWM
#define StandardLightSetup
#define FONT_12x16
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO(Port1);
ReefAngel.StandardHeater(Port2);
ReefAngel.StandardLights(Port3);
ReefAngel.MHLights(Port4);
Re: Lights issue
Posted: Sun Apr 08, 2012 4:27 pm
Open the file ReefAngel_Features.h and place this code in it:
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define WDT
#endif  // __REEFANGEL_FEATURES_H__
The file is located at "Document\Arduino\libraries\ReefAngel_Features"
Re: Lights issue
Posted: Sun Apr 08, 2012 4:59 pm
by Threedo
i set back all the defaults in ragen and it then added the menu so i just moved my lights to the default 2 and 3 ports... i think the application might have a glitch. Thanks for the quick response though i checked the reef angel_features.h file after setting ragen to my old setup and it does remove port 4 again.
Re: Lights issue
Posted: Mon Apr 09, 2012 6:24 pm
i will take a look at that and see if i can track down any bug with that. thanks for the input.
Re: Lights issue
Posted: Mon Apr 16, 2012 9:32 pm
by Blawson
having the same challenges... Light options are not available on the controller.
I think it has to do with the "simple menu" option. But when I uncheck that, the sketch is too big. A little frustrating since the only thing I have added is the wifi. I can't be out of memory...
Re: Lights issue
Posted: Mon Apr 16, 2012 10:06 pm
Yes, the simple menu strips out the menu settings for all functions.
If you add wifi, you can easily change the settings with the other apps on the fly. Client, Java Status, smart phone apps are all capable of changing the memory settings.
That's why you should pick either one or the other. The only other option would be to upgrade to RA+, in which case you can have them all loaded.
Lights issue
Posted: Mon Apr 16, 2012 11:23 pm
by Blawson
Just so I understand, with the standard RA, i can only have simple menu if I have wifi? So with this controller, I cannot have wifi, control of settings, PMW dimming and such without upgrading?
Lights issue
Posted: Tue Apr 17, 2012 12:04 am
by Blawson
Think I figured the light part out. Looks like I just need to do a lot more research to get this setup the way I am wanting.
