Custom Main Screens
Would you like to help?
Re: Custom Main Screens
Try this:
//The following features are enabled for this File:
//#define VersionMenu
#define DisplayLEDPWM
#define wifi
//#define WDT
//#define SIMPLE_MENU
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  //static byte vtechmode=0;
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawLargeText(0,255,8,16,"Redneck Reefin!", Font8x8);
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.PWM.GetDaylightValue(),
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_NAVY,255,90,119, ReefAngel.PWM.GetActinicValue());
  //ReefAngel.PWM.GetActinicValue());
  //ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.SingleATO( true,Port2,60,0 );
    pinMode(lowATOPin,OUTPUT);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Port5);
    //randomSeed(analogRead(0));
    //ReefAngel.Init();  //Initialize controller
    //ReefAngel.Timer[1].SetInterval(random(15,35));
    //ReefAngel.Timer[1].Start();
    //ReefAngel.Relay.On(Port5);
    ReefAngel.AddWifi();
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port7,6,0,20,0 );
    ReefAngel.StandardLights( Port8,7,0,19,0 );
    //////// ReefAngel.Wavemaker1(Port5);
    /////// ReefAngel.Wavemaker2(Port6);
    //ReefAngel.PWM.SetActinic( MoonPhase ) Test for Meanwells
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
    ///if ( ReefAngel.Timer[1].IsTriggered() )
          ///  ReefAngel.Timer[1].SetInterval(random(15,35));
          ///  ReefAngel.Timer[1].Start();
           /// ReefAngel.Relay.Toggle(Port5);
          ///  ReefAngel.Relay.Toggle(Port6);
    if (hour()>=6 && hour()<20)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
My Dev Lib Version isnt showing. Tried what you said. It just shows xx.xx.xx
What was the compile size?
Are you trying the exact same code I posted?
Which libraries are you running?
Yes. All I did what the changes you mentioned above. I think the libraries are 0.9.6
I just added the custom main screen and now the client suite won't connect.
Ok... In this case, you have to manually set the features.
The new Arduino automatically sets features for you.
Open RAGen, go to tab features and make sure that wifi is checked.
Did that before. It didn't work. I'm using com3 USB. I don't what the issue is.
I suggest you download the latest installer from the download section to get up to date stuff.
I have the newest everything. Just checked. Ive only had this 2 weeks. It's all new downloads and libraries etc
Can you post the results of what you get when you click compile button?
Binary sketch size: 35,340 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1693)
at processing.app.Sketch.build(Sketch.java:1626)
at processing.app.Sketch.exportApplet(Sketch.java:1648)
at processing.app.Sketch.exportApplet(Sketch.java:1634)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2349)
at java.lang.Thread.run(Thread.java:619)
TOO BIG :(
That's what I mean.
You don't have the latest stuff.
Just within the past week, we've gone through 3 libraries releases.
Please download the latest RA installer.
Oh thank you..sorry Roberto...I'll keep up on those from now on..didn't realize
Issue with the new release in ReefAngel.h
Even though in RAGen I have Salinity Unchecked
This error:
In file included from RA_052912_1615custom2Main.cpp:32:
C:\Users\User\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:95: error: 'SalinityClass' does not name a type
I don't think you are using the code I gave you, but the reason you have the error is because you are missing a header.
My display temp T1_PROBE and Light temp T3_PROBE are in the wrong place on my display? I've tried to move the temp probes and nothing changes their location on my display. Help? :)
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
#define NUMBERS_8x16
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(0,255,8,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
Thanks Roberto :)
My custom main:
If anyone wants my PDE let me know.
Nice :)
Well done
alexwbush
Post by alexwbush »
DrewPalmer04 wrote:My custom main:
I'd be interested in looking at your code :D
Here it is as of today (I change it all the time):
The fonts are smaller due to my size limitations.
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(0,255,3,17,"Drew Palmer's 75 Reef");
  ReefAngel.LCD.DrawText(0,255,48,47,"Cloud");
  ReefAngel.LCD.DrawText(0,255,48,57,"00:00");
  ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 10, 40, text);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(COLOR_BLACK, 255, 95, 40, text);
image doesn't show :(
Still not :(
better?
Yay :)
Lol good ol' photobucket messing up
