Page 1 of 6
Custom Main Screens
Posted: Sat Jun 11, 2011 7:31 pm
by binder
Starting with 0.8.5.15 dev libraries, you are now able to create your own custom main screen. This topic will contain various main screens with the code to create them.
NOTE: There is a guide on creating the custom main screens. The link to download the guide is here:
http://curtbinder.info/ragen/docs/RA_Cu ... Screen.pdf
  • Default Screen
    Default screen
    Default screen
      ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
                                ReefAngel.PWM.GetDaylightValue(),
                                ReefAngel.PWM.GetActinicValue());
  • Default Screen with banner at top
    Default screen with banner
      // Change the 30 to adjust the horizontal position of the text on the screen, max 20-21 chars
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Trevor's NC6");
      ReefAngel.LCD.DrawMonitor(15, 68, ReefAngel.Params,
      ReefAngel.LCD.DrawOutletBox(12, 101, TempRelay);
      ReefAngel.LCD.DrawGraph(5, 11);
  • Banner with 2 Relays with Outlets Green = ON and Red = OFF
    Banner with 2 relays
    NOTE: This color change requires enabling COLORS_PDE in your ReefAngel_Features.h file
    // ReefAngel_Features.h
    #define COLORS_PDE
    This is the code that goes in your ReefAngel_CustomColors.h file. The file will already contain a lot of stuff in there (all this will be in there) but not the changes which are noted below. So you can just edit those lines indicated below.
    // ReefAngel_CustomColors.h
    #define T1TempColor         COLOR_RED
    #define T2TempColor         COLOR_CHOCOLATE
    #define T3TempColor         COLOR_MEDIUMORCHID
    #define PHColor             COLOR_SEAGREEN
    #define DPColor             COLOR_SADDLEBROWN
    #define APColor             COLOR_DARKSLATEBLUE
    #define CalibrateColor      COLOR_RED
    #define ModeScreenColor     COLOR_BLUE
    #define DateTextColor       COLOR_RED
    #define OutletBorderColor   0x54
    #define OutletOnBGColor     COLOR_GREEN  // CHANGED
    #define OutletOnFGColor     COLOR_WHITE
    #define OutletOffBGColor    COLOR_RED  // CHANGED
    #define OutletOffFGColor    COLOR_WHITE  // CHANGED
    #define BtnBorderColor      COLOR_BLACK
    #define BtnActiveColor      COLOR_GRAY
    #define BtnInactiveColor    COLOR_LIGHTGRAY
    #define SelectionBGColor    COLOR_BLUE
    #define SelectionFGColor    COLOR_WHITE
    #define DefaultBGColor      COLOR_WHITE
    #define DefaultFGColor      COLOR_BLACK
    #define GraphDotLineColor   0x49
    Code to add at the top of your PDE file
    // You must add these lines at the top of the includes in your PDE
    #include <ReefAngel_Colors.h>
    #include <ReefAngel_Features.h>  // This is the first include line normally
    The custom main screen functions
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 45, 2, "Alex Bush");
      ReefAngel.LCD.DrawDate(6, 119);
      ReefAngel.LCD.DrawMonitor(15, 63, ReefAngel.Params,
      // draw main relay
    #ifdef RelayExp
      // draw 1st expansion relay
      ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
    #endif  // RelayExp
      ReefAngel.LCD.DrawGraph(5, 10);
Feel free to post your own custom main screens. Please include a screenshot and the code used to create the screen with your post.
Re: Custom Main Screens
Posted: Sat Jun 11, 2011 11:54 pm
by alexwbush
awesome! Can you post a code to display 16 relays? They can be directly below the top 8.
Posted: Sun Jun 12, 2011 5:36 am
by binder
alexwbush wrote:awesome! Can you post a code to display 16 relays? They can be directly below the top 8.
Like which screen? I've got some that can display the 16 relays. I just would like to know which screen you would like it to look like.....the default or with a banner.
Posted: Sun Jun 12, 2011 1:08 pm
by alexwbush
I would like both. Does the banner get rid of the time at the bottom? If so, preference goes to the default. Is this the one with green=on and red=off? I might end up replacing the DP and AP with a timer when the ATO starts up. I am having some trouble with the timer, but I'll post that in my auto water change thread. Thanks Curt!
Posted: Sun Jun 12, 2011 2:52 pm
by binder
alexwbush wrote:I would like both. Does the banner get rid of the time at the bottom?
No, the banner does not get rid of the time at the bottom. Take a second look at the pictures. You will probably have to scroll the image down to see the bottom but the time is still there.
alexbush wrote:Is this the one with green=on and red=off?
No, it's not with the green=on and red=off. That will require enabling the COLORS_PDE define and adding in additional includes to your PDE for the custom colors. I can do it though and post how to enable it. :ugeek:
Posted: Sun Jun 12, 2011 5:22 pm
by NanoTrevor
hey all, just a preference but it does add to the clean lines of the main, set the relay port outline to match the bg color...then you just have the colored ports.
hey curt, how hard would it be to invert the values for ap and dp that are displayed? roberto got me a working code for the pwmslope cause buckpucks r inverted, 0 volt is on 5 volts is off...while it works as it should the displayed values are wrong, instead on being say 60% as it should it reads 40%, get what im saying? thanks
Posted: Sun Jun 12, 2011 8:26 pm
by alexwbush
Please feel free to delete this later to keep the tutorial clean.
I am having trouble making this work. I followed all of the steps and I didn't have any compile errors, but I still see the same default display. Here's my PDE code:
Note that I tried to make the web banner work with my expansion relays, but no luck so that's why that code is commented out.
// Autogenerated file by RAGen (v1.0.4.92), (05/08/2011 17:03)
// RA_050811_1703.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define RelayExp
#define SingleATOSetup
#define StandardLightSetup
#define ATOSetup
//Custom colors
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Box1_Port1    11    Fuge LED
#define Box1_Port2    12    Carbon Reactor
#define Box1_Port3    13
#define Box1_Port4    14    Vortech
#define Box1_Port5    15    WC Heater
#define Box1_Port6    16    WC Pump
#define Box1_Port7    17    Actinic LED
#define Box1_Port8    18
//#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "wolfpack1206";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "Room";
prog_char probe3_label[] PROGMEM = "Not%20Used";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "Moonlight";
prog_char relay3_label[] PROGMEM = "Actinic";
prog_char relay4_label[] PROGMEM = "Halide";
prog_char relay5_label[] PROGMEM = "Sump%20Light";
prog_char relay6_label[] PROGMEM = "Powerhead";
prog_char relay7_label[] PROGMEM = "Heater";
prog_char relay8_label[] PROGMEM = "Return";
#ifdef RelayExp
#if InstalledRelayExpansionModules >= 1
prog_char relay11_label[] PROGMEM = "Box1%20Port1";
prog_char relay12_label[] PROGMEM = "Box1%20Port2";
prog_char relay13_label[] PROGMEM = "Box1%20Port3";
prog_char relay14_label[] PROGMEM = "Box1%20Port4";
prog_char relay15_label[] PROGMEM = "Box1%20Port5";
prog_char relay16_label[] PROGMEM = "Box1%20Port6";
prog_char relay17_label[] PROGMEM = "Box1%20Port7";
prog_char relay18_label[] PROGMEM = "Box1%20Port8";
#endif  // InstalledRelayExpansionModules >= 1
#if InstalledRelayExpansionModules >= 2
prog_char relay21_label[] PROGMEM = "Box2%20Port1";
prog_char relay22_label[] PROGMEM = "Box2%20Port2";
prog_char relay23_label[] PROGMEM = "Box2%20Port3";
prog_char relay24_label[] PROGMEM = "Box2%20Port4";
prog_char relay25_label[] PROGMEM = "Box2%20Port5";
prog_char relay26_label[] PROGMEM = "Box2%20Port6";
prog_char relay27_label[] PROGMEM = "Box2%20Port7";
prog_char relay28_label[] PROGMEM = "Box2%20Port8";
#endif  // InstalledRelayExpansionModules >= 2
#if InstalledRelayExpansionModules >= 3
prog_char relay31_label[] PROGMEM = "Box3%20Port1";
prog_char relay32_label[] PROGMEM = "Box3%20Port2";
prog_char relay33_label[] PROGMEM = "Box3%20Port3";
prog_char relay34_label[] PROGMEM = "Box3%20Port4";
prog_char relay35_label[] PROGMEM = "Box3%20Port5";
prog_char relay36_label[] PROGMEM = "Box3%20Port6";
prog_char relay37_label[] PROGMEM = "Box3%20Port7";
prog_char relay38_label[] PROGMEM = "Box3%20Port8";
#endif  // InstalledRelayExpansionModules >= 3
#if InstalledRelayExpansionModules >= 4
prog_char relay41_label[] PROGMEM = "Box4%20Port1";
prog_char relay42_label[] PROGMEM = "Box4%20Port2";
prog_char relay43_label[] PROGMEM = "Box4%20Port3";
prog_char relay44_label[] PROGMEM = "Box4%20Port4";
prog_char relay45_label[] PROGMEM = "Box4%20Port5";
prog_char relay46_label[] PROGMEM = "Box4%20Port6";
prog_char relay47_label[] PROGMEM = "Box4%20Port7";
prog_char relay48_label[] PROGMEM = "Box4%20Port8";
#endif  // InstalledRelayExpansionModules >= 4
#if InstalledRelayExpansionModules >= 5
prog_char relay51_label[] PROGMEM = "Box5%20Port1";
prog_char relay52_label[] PROGMEM = "Box5%20Port2";
prog_char relay53_label[] PROGMEM = "Box5%20Port3";
prog_char relay54_label[] PROGMEM = "Box5%20Port4";
prog_char relay55_label[] PROGMEM = "Box5%20Port5";
prog_char relay56_label[] PROGMEM = "Box5%20Port6";
prog_char relay57_label[] PROGMEM = "Box5%20Port7";
prog_char relay58_label[] PROGMEM = "Box5%20Port8";
#endif  // InstalledRelayExpansionModules >= 5
#if InstalledRelayExpansionModules >= 6
prog_char relay61_label[] PROGMEM = "Box6%20Port1";
prog_char relay62_label[] PROGMEM = "Box6%20Port2";
prog_char relay63_label[] PROGMEM = "Box6%20Port3";
prog_char relay64_label[] PROGMEM = "Box6%20Port4";
prog_char relay65_label[] PROGMEM = "Box6%20Port5";
prog_char relay66_label[] PROGMEM = "Box6%20Port6";
prog_char relay67_label[] PROGMEM = "Box6%20Port7";
prog_char relay68_label[] PROGMEM = "Box6%20Port8";
#endif  // InstalledRelayExpansionModules >= 6
#if InstalledRelayExpansionModules >= 7
prog_char relay71_label[] PROGMEM = "Box7%20Port1";
prog_char relay72_label[] PROGMEM = "Box7%20Port2";
prog_char relay73_label[] PROGMEM = "Box7%20Port3";
prog_char relay74_label[] PROGMEM = "Box7%20Port4";
prog_char relay75_label[] PROGMEM = "Box7%20Port5";
prog_char relay76_label[] PROGMEM = "Box7%20Port6";
prog_char relay77_label[] PROGMEM = "Box7%20Port7";
prog_char relay78_label[] PROGMEM = "Box7%20Port8";
#endif  // InstalledRelayExpansionModules >= 7
#if InstalledRelayExpansionModules >= 8
prog_char relay81_label[] PROGMEM = "Box8%20Port1";
prog_char relay82_label[] PROGMEM = "Box8%20Port2";
prog_char relay83_label[] PROGMEM = "Box8%20Port3";
prog_char relay84_label[] PROGMEM = "Box8%20Port4";
prog_char relay85_label[] PROGMEM = "Box8%20Port5";
prog_char relay86_label[] PROGMEM = "Box8%20Port6";
prog_char relay87_label[] PROGMEM = "Box8%20Port7";
prog_char relay88_label[] PROGMEM = "Box8%20Port8";
#endif  // InstalledRelayExpansionModules >= 8
#endif  // RelayExp
    id_label, probe1_label, probe2_label, probe3_label,
    relay1_label, relay2_label, relay3_label, relay4_label,
    relay5_label, relay6_label, relay7_label, relay8_label,
#ifdef RelayExp
    relay11_label, relay12_label, relay13_label, relay14_label,
    relay15_label, relay16_label, relay17_label, relay18_label,
    relay21_label, relay22_label, relay23_label, relay24_label,
    relay25_label, relay26_label, relay27_label, relay28_label,
    relay31_label, relay32_label, relay33_label, relay34_label,
    relay35_label, relay36_label, relay37_label, relay38_label,
    relay41_label, relay42_label, relay43_label, relay44_label,
    relay45_label, relay46_label, relay47_label, relay48_label,
    relay51_label, relay52_label, relay53_label, relay54_label,
    relay55_label, relay56_label, relay57_label, relay58_label,
    relay61_label, relay62_label, relay63_label, relay64_label,
    relay65_label, relay66_label, relay67_label, relay68_label,
    relay71_label, relay72_label, relay73_label, relay74_label,
    relay75_label, relay76_label, relay77_label, relay78_label,
    relay81_label, relay82_label, relay83_label, relay84_label,
    relay85_label, relay86_label, relay87_label, relay88_label,
#endif  // RelayExp
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 45, 2, "Alex's Cube");
  // draw main relay
#ifdef RelayExp
#endif  // RelayExp
    //ReefAngel.LoadWebBanner(pgm_read_word(&(webbanner_items[0])), SIZE(webbanner_items));
    // Initialize and start the timer
    ReefAngel.Timer[4].SetInterval(120);  // set interval to 180 seconds
    ReefAngel.Timer[4].Start();
    ReefAngel.FeedingModePorts = B10101000;
    //ReefAngel.WaterChangePorts = B10000010;
    ReefAngel.WaterChangePorts = B00000001;
    ReefAngel.OverheatShutoffPorts = B00000110;
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Box1_Port4);
    // Specific functions
    // ReefAngel.SingleATOHigh(Port1);
        ReefAngel.Relay.On(Port1);
    if(ReefAngel.HighATO.IsActive()==false)
        ReefAngel.Relay.Off(Port1);
        ReefAngel.Relay.Off(Box1_Port6);
    if(ReefAngel.LowATO.IsActive())
    if(ReefAngel.LowATO.IsActive()==false)
        ReefAngel.Relay.Off(Port6);
    ReefAngel.MHLights(Port3);
    ReefAngel.Wavemaker1(Port4);
    ReefAngel.StandardFan(Port5);
    ReefAngel.StandardLights(Box1_Port7,12,15,21,45);
Posted: Mon Jun 13, 2011 10:56 am
by binder
It works great for me.
You gotta make sure you add in the 2 extra define statements in your Features file....
#define COLORS_PDE
#define CUSTOM_MAIN
That will fix it for you.
You got PM with PDE, Features & Colors files.
Posted: Mon Jun 13, 2011 8:36 pm
by alexwbush
Thanks Curt! Problem was that I had an older library without this in my features file
#define CUSTOM_MAIN
thanks for PM and all of the code! One thing down, now to the skimmer delay and automatic water change! Oh and I just ordered an LED set... so that too.
Posted: Tue Jun 14, 2011 5:02 am
by binder
alexwbush wrote:Thanks Curt! Problem was that I had an older library without this in my features file
#define CUSTOM_MAIN
The skimmer delay is in the latest library. Just use the DelayedOn function inside the loop instead of the On function inside setup.
Re: Custom Menu
Posted: Sun Jul 17, 2011 11:34 am
by lukeluke
Curt, with the new version, i'd want on the screen:
the Relay , AP,DP,PH,T1,T2,T3 and not the graph... and i want to see if the Timeout is on.
Like:
ATO Timeout : YES
Overheat Timeout : NO
How can i do ?
THANKS ;-)
Re: Custom Menu
Posted: Sun Jul 17, 2011 1:01 pm
by binder
lukeluke wrote:Curt, with the new version, i'd want on the screen:
Like:
ATO Timeout : YES
How can i do ?
THANKS ;-)
When you say if the "Timeout is on" what are you asking? You want to know if the ATO pump is currently running and if the timeout is counting down? Or do you want to know if the timeout limit has exceeded?
Is this for the single ato or for the dual ato? The code will be different for both of them.
I ask because the Overheat doesn't have a timeout. It only has an exceeded value that when exceeded it turns on the RED LED on the controller and shuts off the lights.
PS. I moved your post to be under the proper topic for the custom main screens.
Posted: Tue Aug 09, 2011 6:35 pm
by mbertalha
Hi Curt,
I'm having this error:
'class ReefAngel_NokiaLCD'has no member named'DrawHugeNumbers'
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
What might be happening?
Tanks
Marcelo
Posted: Wed Aug 10, 2011 4:19 am
by binder
you are missing a define statement inside your features file. Add this line to ReefAngel_Features.h
 #define NUMBERS_16X16
That will enable you to use that function.
Posted: Mon Aug 15, 2011 6:40 am
by mbertalha
binder wrote:you are missing a define statement inside your features file. Add this line to ReefAngel_Features.h
Tanks Curt.
My custon main screen,
just need to disable the functions that are not needed in the source code and fix the character that is trimmed further on the PH.
My PDE file:
// Autogenerated file by RAGen (v1.0.4.92), (08/10/2011 10:52)
// RA_081011_1052.pde
#define VersionMenu
#define ATOSetup
#include <Phillips6610LCDInv.h>
Phillips6610LCDInv e;
void ConvertNumToString(char* string, int num, byte decimal)
  char temptxt[3];
  int Temp = num;
  if (Temp==0xFFFF) Temp=0;
  itoa(Temp/decimal,string,10);
  if (decimal>1)
      itoa(Temp%decimal,temptxt,10);
      strcat(string, ".");
      if (Temp%decimal<10 && decimal==100) strcat(string, "0");
      strcat(string, temptxt);
  byte x = 6;
  byte y = 2;
  byte t;
  ReefAngel.LCD.DrawDate(6, 2);
  x = 12;
  y += MENU_START_ROW+1;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Temp         pH");
  char text[7];
  ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text,
Font8x16);
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  y += MENU_START_ROW*2;
  x = 10;
  ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+8,y+25,"Temp2:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
x+24, y+35, 10);
  ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+50,"Temp3:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
x+24, y+60, 10);
  y += 39*2;
  x = 13;
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.Relay.On(Port7);
    ReefAngel.StandardLights(Port1, 13, 30, 00, 30);
    ReefAngel.StandardATO(Port2, 2400); //Quantidade de segundos para reposição, se desligar pelo timer, led vermelho do RA acende e bloqueia a reposição
    ReefAngel.StandardFan(Port3, 270, 264);  // Turn fan/chiller on at 270C and off at 264C
    ReefAngel.StandardHeater(Port4, 260, 266);  // Turn heater on at 260C and off at 266C
best regards
Marcelo
Posted: Mon Aug 15, 2011 8:14 am
Sweet :)
Posted: Mon Aug 15, 2011 2:29 pm
by binder
Marcelo
That's a nice and clean looking screen! I like it!
Posted: Mon Aug 15, 2011 2:32 pm
by binder
Side note:
You should be able to remove these lines from your PDE file. They are not used by the libraries.
Posted: Tue Aug 16, 2011 6:55 am
by mbertalha
I got friends thanks to Roberto and Curt.
Curt,
thanks for the recommendations.
I would leave the PDE file cleaner, if they have other recommendations, I will enjoy.
The only thing missing now I ride my custom menu, and remove some functions will not use. Do not use PWM and wave maker.
Best regards.
Marcelo
Posted: Thu Aug 25, 2011 9:31 am
by bmhair03
Just wanted to add my Main Display. Its based off Marcelo's. It has room for a second Relay if needed.
Thanks to all. code to follow:
Posted: Thu Aug 25, 2011 9:53 am
by bmhair03
Hope this is better.
Here is my .pde.
  char temptxt[3];
  int Temp = num;
  if (decimal>1)
  byte x = 6;
  byte y = 2;
  byte t;
  x = 12;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display         pH");
  char text[7];
Font8x16);
  x = 10;
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Sump:");
24, y+35, 10);
  ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"LED:");
x+24, y+35, 10);
  //y += 39*2;
 // x = 13;
  ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
   // #ifdef RelayExp
 // TempRelay = ReefAngel.Relay.RelayDataE[0];
 // TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
//  TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
 // ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
//#endif   RelayExp
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
//End of PWM Expansion Code Header
  randomSeed(second());
//  setTime(1313771580);  // Unix time
//  now();
//  ReefAngel.RTC.set(now());
  ReefAngel.Relay.On(Port5);
  // ReefAngel.StandardLights(Port1,20,00,1,00);
  ReefAngel.SingleATOLow(Port2);
  ReefAngel.StandardLights(Port3,10,30,19,30);
  ReefAngel.StandardLights(Port4,10,00,20,00);
 // ReefAngel.StandardFan(Port8);
  //ReefAngel.PWM.SetActinic(PWMSlope(10,0,20,00,15,100,60,ReefAngel.PWM.GetActinicValue()));
  //ReefAngel.PWM.SetDaylight(PWMSlope(10,30,19,30,15,65,60,ReefAngel.PWM.GetDaylightValue()));
  PWMChannel[LEDPWM0]=PWMSlope(10,0,20,0,15,100,60,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(10,30,19,30,15,75,60,PWMChannel[LEDPWM1]);
  //PWMChannel[LEDPWM2]=MoonPhase();
  if (hour()>=20 || hour()<1)
    PWMChannel[LEDPWM2]=0;
  CheckCloud();
  //PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM3]);
  //PWMChannel[LEDPWM4]=PWMSlope(11,0,21,30,0,50,40,PWMChannel[LEDPWM4]);
  //PWMChannel[LEDPWM5]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM5]);
  PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
  PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
  PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  //PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
  //PWMExpansion(LEDPWM4,int(2.55*PWMChannel[LEDPWM2]));
  //PWMExpansion(LEDPWM5,int(2.55*PWMChannel[LEDPWM3]));
//  ReefAngel.LCD.DrawText(0,255,75,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
//  ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
  Wire.beginTransmission(8); // transmit to device #2
  Wire.send('$'); // sends $
  Wire.send(cmd); // sends a value
  Wire.send(data); // sends 255
  Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
byte MoonPhase()
  int m,d,y;
  int yy,mm;
  long K1,K2,K3,J,V;
  byte PWMvalue;
  m=month();
  d=day();
  y=year();
  yy=y-((12-m)/10);
  mm=m+9;
  if (mm>=12) mm-=12;
  K1=365.25*(yy+4712);
  K2=30.6*mm+.5;
  K3=int(int((yy/100)+49)*.75)-38;
  J=K1+K2+d+59-K3;
  V=(J-2451550.1)/0.29530588853;
  V-=int(V/100)*100;
  V=abs(V-50);
  PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
  //pinMode(lowATOPin,OUTPUT);
  return (PWMvalue*100)/255;
void CheckCloud()
#define Clouds_Every_X_Days 1
  // Minimum number of minutes for cloud duration
#define Min_Cloud_Duration 3
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 5
  // Channels used by the actinic LEDs on the PWM Expansion module
  // These channels will not be dimmed when the cloud effect is triggered
  // Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
  // Channels used by the daylight LEDs on the PWM Expansion module
  // These channels will be used for the spike when lightning effect is triggered
  // Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000010
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
#ifdef printdebug
      Serial.print("Cloud Chance: ");
      Serial.println(cloudchance,DEC);
#endif
      if (cloudchance)
        lightningchance=random(100);
#ifdef printdebug
        Serial.print("Num of Clouds: ");
        Serial.println(numclouds,DEC);
        Serial.print("Cloud Start: ");
        Serial.println(cloudstart,DEC);
        Serial.print("Cloud Start Range: ");
        Serial.print(Start_Cloud_After,DEC);
        Serial.print(" - ");
        Serial.println(Start_Cloud_After+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
        Serial.print("Cloud Duration: ");
        Serial.println(cloudduration,DEC);
        Serial.print("Lightning Chance: ");
        Serial.println(lightningchance,DEC);
        Serial.print("Lightning at: ");
        Serial.println(cloudstart+(cloudduration/2),DEC);
        time_t t=cloudstart;
        t*=60;
        t+=1311551999;
        setTime(t); // Unix time
        now();
        Serial.print("NumMins: ");
        Serial.println(LastNumMins,DEC);
#endif
  if (cloudchance)
    //is it time for cloud yet?
      // let's go through all channels to pick which ones will be dimmed
      for (int a=0;a<6;a++)
        if (bitRead(Actinic_Channels,a)==0)
          // this will slope down the channel from the current PWM to 0 within 3minutes.
          // then it will stay at 0 for the duration of the cycle
          // and finally slope up from 0 to PWM value within 3 minutes
          // it is basically an inversed slope
          PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
#ifdef printdebug
          if (second()==0)
            Serial.print("Dimming Channel ");
            Serial.print(a,DEC);
            Serial.print(PWMChannel[a],DEC);
            Serial.println("%");
          if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()>5)
            adjustTime(((cloudduration/2)*60)-6);
            Serial.print("Adjusting time to: ");
            Serial.println(now());
#endif
#ifdef printdebug
        Serial.println("Lightning...");
#endif
        for (int b=0;b<6;b++)
          if (bitRead(Daylight_Channels,b)==1)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
#ifdef printdebug
            Serial.print(b,DEC);
            Serial.println(PWMChannel[b],DEC);
#endif
            PWMChannel[b]=20;
#ifdef printdebug
      if ((NumMins(hour(),minute())!=(cloudstart+(cloudduration/2))) && second()==0)
        adjustTime(((cloudduration/2)*60)-1);
      if (second()==0) delay(1000);
#endif
      cloudindex++;
      if (cloudindex < numclouds)
#ifdef printdebug
        Serial.print(Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2),DEC);
        Serial.println((Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2))+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
        t*=60;
        t+=1311551999;
        now();
#endif
    ReefAngel.LCD.Clear(255,0,115,132,132);
    ReefAngel.LCD.DrawText(0,255,5,115,"C");
    ReefAngel.LCD.DrawText(0,255,11,115,"00:00");
    ReefAngel.LCD.DrawText(0,255,45,115,"L");
    ReefAngel.LCD.DrawText(0,255,51,115,"00:00");
      int x=0;
      ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart/60));
      ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart%60));
    //ReefAngel.LCD.DrawText(0,255,35,120,cloudstart);
    ReefAngel.LCD.DrawText(0,255,90,115,cloudduration);
    ReefAngel.LCD.DrawText(0,255,110,115,PWMChannel[LEDPWM1]);
    if (lightningchance)
      int x=0;
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
      ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
#ifdef printdebug
#endif
Posted: Thu Sep 01, 2011 2:43 pm
by mbertalha
Hi bmhair03,
very good its Main Screen.
which means C11:47 L11:50 7 0???
congratulations
Marcelo
Posted: Fri Sep 02, 2011 9:21 am
by bmhair03
Its display for the cloud lightning effect.
c=cloud L=lightning.
Posted: Sun Dec 04, 2011 7:55 pm
by peitro
Here is another display based off of Marcelo's, It adds status of the two float switch relays under the big temperature value. I have my head unit in an area that I cannot get a picture. Feel free to comment or improve on this.
// GLOBAL variables for display
int FloatHigh = 0;
int FloatLow = 0;
// custom menu code
  byte x = 6;
  byte y = 2;
  byte t;
  x = 12;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Sump         pH");
  char text[7];
Font8x16);
  x = 10;
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+18, "High Float:");
  ConvertNumToString(text, FloatHigh, 1);
  ReefAngel.LCD.DrawLargeText(COLOR_DIMGREY, COLOR_DEEPSKYBLUE, x+5, y+25, text, Font8x16);
  ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+41, "Low Float:");
  ConvertNumToString(text, FloatLow, 1);
  ReefAngel.LCD.DrawLargeText(COLOR_DIMGREY, COLOR_DEEPSKYBLUE, x+5, y+49, text, Font8x16);
  ReefAngel.LCD.DrawText(COLOR_GREEN, COLOR_WHITE, x, y+65, "0=Empty 1=Full");
  x += (16*4) + 8;
  ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,x+8,y+25,"Refug:");
x+24, y+35, 10);
  ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+50,"Room:");
x+24, y+60, 10);
  y += 39*2;
  x = 13;
Add this into your loop
      // variables used for display
        FloatLow = digitalRead(lowATOPin);
        FloatHigh = digitalRead(highATOPin);
Posted: Fri Dec 09, 2011 9:34 pm
by psyrob
Here is my humble attempt at a custom screen....thanks to all who do hard work coding for us newbies to Arduino coding...I am getting real good at cutting and pasting all the good work you do, and I can do some giggling of code, but without you all who know the nitty-gritty of writing the code, I would be lost...
Sorry for the junky iphone pic, it is the best I could get...
Posted: Fri Dec 09, 2011 9:42 pm
by psyrob
Here is my PDE
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 6, 2, "Rob's ReefAngel");
ReefAngel.LCD.Clear(COLOR_BLACK, 1, 17, 132, 17);
x = 12;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display       PH");
char text[7];
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text);
x = 10;
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"ROOM:");
9, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"FRAG:");
x+9, y+35, 10);
Posted: Fri Dec 09, 2011 9:53 pm
by binder
Nice. Looks good. Good job. :)
Posted: Sat Dec 10, 2011 9:35 am
I like it :)
Posted: Sat Dec 17, 2011 7:04 pm
by Deckoz2302
how come I always get 'class ReefAngel_NokiaLCD' has no class named 'DrawLargeText'?
Posted: Sat Dec 17, 2011 7:41 pm
You need to pick the size of font you want to use and define it in the features file.
Either of these 2:
#define FONT_8x8
#define FONT_8x16
Take a look at the manual for more info:
http://forum.reefangel.com/viewtopic.php?p=653#p653
