Re: Reasons for that can be turned statusled
Posted: Sat Apr 14, 2012 8:30 pm
There are only 2 reasons:
ATO or Overheat.
Posted: Sun Apr 15, 2012 5:43 am
by Sebyte
I have also found that an intermittent connection on a temperature extension lead plug can cause the LED to come on. One pin had pushed back. It seemed to cause a spike making the RA think it has an over heat. I found this out as my head unit is mounted on the door of my stand and as I opened the door the unit showed the red LED.
Worth checking
