I want Port 7 on at 11:10 pm and off at 9:50 am
Posted: Sat Apr 14, 2012 6:57 pm
by miked
I already use my standard lights and metal halide lights from internal memory to control separate channels of the LEDs. Any easy way to just say outler on at 11:10 pm and off at 9:50 am. This is for a chaeto light running opposite my tank lights.
thanks
Re: I want Port 7 on at 11:10 pm and off at 9:50 am
Posted: Sat Apr 14, 2012 7:04 pm
You can use
This will turn Port1 to be on opposite cycle as StandardLights();
Or, you can manually set times:
ReefAngel.StandardLights(Port1,23,10,9,50);
Posted: Sat Apr 14, 2012 7:07 pm
by miked
thanks I will use the moonlights option. I did finally find the second suggestion in the forum search but I think I would rather just use the moonlight option. btw this thing has been great and your support is second to none.
Posted: Sat Apr 14, 2012 7:09 pm
by miked
after i entered
ReefAngel.MoonLights(Port1);
the MoonLights wording is black? from what everything else looks like should it be red?
Posted: Sat Apr 14, 2012 7:18 pm
As long as it is compiling without errors, you are good.
Updating to newer libraries will make it turn orange.
The orange color is just highlight context asnd sometimes I forget to add them and I catch as we go along and place on the next updates.
