Page 1 of 2
LED Lightning Storm Simuation
Posted: Wed Jun 15, 2011 4:47 pm
by alexwbush
So, I know this may be a new idea here, but I was watching videos and reading about the Aqua Illuminations (AI) LED allows you to program lightning storms and thought it was pretty cool. I picked up a dimmable DIY LED set (currently being shipped) and would love to see this feature.
I propose something very similar to how the AI controller handles this, but for those of us with DIY LED sets. You should be able to change the setting on the headunit. The two settings:
1. Number of storms possible per day
2. Percentage you would like storms to occur
This would mean 1 storm, 100% would give you 1 storm per day. 1 storm, 50% gives you a 50% possibility of that 1 storm happening per day and it's just randomized from there. It doesn't need to remember the day of the week or do set things per day, but that may be a future option. In addition, and I know people would love this... but it could maybe model after a current or set weather pattern programmed in (i.e. you could download a table, or .h or .c file with a set period mapped out and it would model the "weather" after that) so that effectively you could pick an area you want your weather to be like, and it would do it.
Now I know this may be more of a parlor/party trick, but it might keep things interesting and the ability to turn it on and off from the controller would be awesome in the case that you decide you're sick of it or want to bring it back. It's been argued on many forums whether is beneficial or a detriment to fish and coral, but we'll leave that argument for another day.
[youtube]
http://www.youtube.com/watch?v=s__XwPhXhe0[/youtube]
Thoughts?
As soon as I get my controller, I'm going to jump into the coding more. I'm betting at least one of you has thought of this, even if you thought it was a stupid idea
Re: LED Lightning Storm Simuation
Posted: Wed Jun 15, 2011 5:29 pm
by NanoTrevor
hey alex, i bought the pwm expansion from roberto and he sent me this pde along with it, im still trying to somehow implement the clouds and storms into my pde...maybe you can work something with this code and let me know
//Library headers. Necessary if you are using Reef Angel Controller
#include <EEPROM.h>
#include <NokiaLCD.h>
//Expander I/O bits
#define Sump 8
#define Heater 7
#define WM1 6
#define SumpLight 5
#define Daylight 4
#define Actinic 3
#define Moonlight 2
#define AutoTopOff 1
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Fast Cloud";
prog_char menu1_label[] PROGMEM = "Slow Cloud";
prog_char menu2_label[] PROGMEM = "Thunderstorm 1";
prog_char menu3_label[] PROGMEM = "Thunderstorm 2";
prog_char menu4_label[] PROGMEM = "All 0%";
prog_char menu5_label[] PROGMEM = "All 10%";
prog_char menu6_label[] PROGMEM = "All 50%";
prog_char menu7_label[] PROGMEM = "All 100%";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label};
// setup function runs only once at start-up
ReefAngel.LCD.SetContrast(60); // Set contrast to 60
ReefAngel.LoadMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Load Menu items from above
//All channels 100%
for(int a=0;a<6;a++)
PWMExpansion(a,50); //Send cmd a and data 255
// loop function keeps running forever after start-up
ReefAngel.StandardGUI(); //Draw the Standard GUI
if (ReefAngel.SelectedMenu==0) // Fast Cloud
PWMExpansion(6,1); //Send cmd 6 and data 1
ReefAngel.ReturnMenuFunction(); // Return from menu function;
if (ReefAngel.SelectedMenu==1) // Slow Cloud
PWMExpansion(6,15); //Send cmd 6 and data 15
if (ReefAngel.SelectedMenu==2) //Thunderstorm 1
PWMExpansion(7,0); //Send cmd 7 and data 0
if (ReefAngel.SelectedMenu==3) //Thunderstorm 2
PWMExpansion(8,0); //Send cmd 8 and data 0
if (ReefAngel.SelectedMenu==4) //All 0%
PWMExpansion(a,0); //Send cmd a and data 0
if (ReefAngel.SelectedMenu==5) //All 10%
PWMExpansion(a,25); //Send cmd a and data 25
if (ReefAngel.SelectedMenu==6) //All 50%
PWMExpansion(a,128); //Send cmd a and data 128
if (ReefAngel.SelectedMenu==7) //All 100%
PWMExpansion(a,255); //Send cmd a and data 255
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
Posted: Wed Jun 15, 2011 5:49 pm
The PWM expansion module has the thunderstorm effects built-in.
Two actually. One is preset and will be always the same pattern across all 6 channels and one that is totally random.
Then you can program your PDE to call those effects whenever you want.
Posted: Wed Jun 15, 2011 6:13 pm
by NanoTrevor
hey roberto...i didn't know that, thought i had to code the stuff, how do i call them? what about the channels on the relay? can those be integrated into the storms/clouds?
Posted: Wed Jun 15, 2011 6:17 pm
For Fast Cloud
For Slow Cloud
For Thunderstorm 1 (preset pattern)
For Thunderstorm 2 (random pattern)
Posted: Wed Jun 15, 2011 7:03 pm
by astralmind
Really nifty stuff there nice ! Too bad I don't have any LEDs at this time, makes me almost regret grabbing that used T5 fixture....
Posted: Wed Jun 15, 2011 7:48 pm
by alexwbush
haha, now you tell me Roberto! After I ordered the chip to fix my relay for LEDs! Oh well, I guess I'll need to do some programming. Since we know the PWM expansion already has it and those folks are set... lets work with the normal PWMs on the standard kit first.
Posted: Wed Jun 15, 2011 8:14 pm
by Ace25
Not a fan of the "lightning effect" I have seen others use, but the storm feature is cool. I also have the PWM module but have yet to use it.
After storms.. then you can think about incorporating "rain" as your ATO like this tank.
http://www.advancedaquarist.com/blog/ri ... fs-display
http://www.youtube.com/watch?v=TuDYCCaVIKo
Posted: Wed Jun 15, 2011 9:04 pm
by alexwbush
storm feature is an excellent idea! I guess it would be a combination of dimming since most people don't have each row setup on a different driver to simulate clouds moving across. Oh and I wonder if they use saltwater or ATO. Either way you'd be splashing salt, but I suppose you could have it wait to top off until that point in the day and do it all at once. But again, with the splashing salt, I'm sure most wouldn't want to simulate rain.
Posted: Thu Jun 16, 2011 11:34 am
by Ace25
They use RO/DI / ATO water for the rain because saltwater would clog up the rain system after just one use. I thought about using saltwater myself as a rain effect but after testing it one time on a small scale and finding out the salt clogs the drippers after just one cycle I gave up. My tank isn't big enough to allow me to use RO as rain for more than a few seconds a day on my tank.
Posted: Thu Jun 16, 2011 4:16 pm
You could always do it with saltwater and then turn off and just rinse with freshwater at the end.
Easy to do that with RA
Posted: Thu Jun 16, 2011 4:44 pm
by alexwbush
very true. My concern would be with salt splashing. Most see that already in their sump... nasty stuff.
But, back on topic of programming, I should have LEDs Monday and then let the fun begin!
Roberto, how did you code the PWM expansion for cloud modes? Is it hard coded? Or is there another .h or .cpp file?
Posted: Thu Jun 16, 2011 10:24 pm
by alexwbush
ok, step 1: random number generator
Posted: Fri Jun 17, 2011 9:13 am
Posted: Thu Jun 23, 2011 8:21 pm
by bmhair03
How many drivers do you need to have to run these feature? 6 ?
Posted: Thu Jun 23, 2011 8:23 pm
You can do storm with just one driver, but you won't get much cloud effect from just 1.
You can achieve a dim down and up, but it won't appear as a passing cloud (to the human eyes).
Posted: Thu Jun 23, 2011 8:33 pm
by alexwbush
thats one reason I was thinking lightning storm or just cloud cover. Most people have 22 drivers (one blue, one white). But running different drivers for different rows would be pretty cool for effects.
Posted: Thu Jun 23, 2011 9:42 pm
For those who want to try this with the standard PWM channels, all you have to do is set different values of PWM randomly.
Something like this:
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
randomSeed(analogRead(0));
if (second(now())==0) StandardThunderstorm(); else ReefAngel.PWM.SetDaylight(0);
void StandardThunderstorm()
byte value=random(255);
ReefAngel.PWM.SetDaylight(value);
Posted: Fri Jun 24, 2011 12:14 am
by alexwbush
sounds good! but doesn't the code above return a value between 0 and 255 for the LED percentage? Shouldn't it be 0-100 or 15-100 for us meanwell driver folks?
For meanwells, maybe something like:
//for meanwells 15%-100%
byte value=random(85);
if (value > 0) value = value+15;
Posted: Fri Jun 24, 2011 8:01 am
You got it
Now, go test and make us a video
Posted: Fri Jun 24, 2011 8:23 pm
by bmhair03
Very nice . will try it tomorrow and film it
Re: LED Lightning Storm Simulation
Posted: Fri Jun 24, 2011 8:33 pm
by bmhair03
if i wanted to try the cloud since i have 2 drivers what is the code for that . Now i might even break my 24 LEDS into 3 strand and add a third driver . Roberto can u PM me availability of the PWM expansion. And is it possible to mod Gen 1 boxes to work with it.
Posted: Fri Jun 24, 2011 8:54 pm
Although it is possible to mod it, you would have to send it to me. It's not as simple.
Posted: Sat Jun 25, 2011 4:12 pm
by bmhair03
I have the code uploaded .What are the item that I put values in .Just the random (85) spot and what dose the % represent. will this just control 1 channel or both.
Posted: Sat Jun 25, 2011 4:41 pm
by bmhair03
When i add the above code All that happens is my daylights start pulsing rapidly
Posted: Sat Jun 25, 2011 4:57 pm
by bmhair03
Here is t the .pde
Posted: Sat Jun 25, 2011 5:14 pm
It should pulse for just one second though.
The code will pulse everytime you have a whole minute for 1 second.
I'm curious to see a video. Can you create one?
Posted: Sat Jun 25, 2011 9:14 pm
by bmhair03
yes i can make a video. It didnt stop for me just kept strobing .
Posted: Sat Jun 25, 2011 10:02 pm
Let me test it then.
Posted: Sun Jun 26, 2011 4:29 pm
by bmhair03
sounds go you know what your doing unlike me.
