LEDs flashing on and off
Posted: Mon May 07, 2012 3:44 pm
maybe I should put this in the newbie section:
errr, I've been wiring up my DIY LEDs from Rapidled and as I got the first bank done, I wanted to test fire the leds to be sure there were no bad connections - I hooked up the Dimmers to the two ports on the Relay Box, turned on the system and now the LEDs are turning on and off - any reason why? I havent changed the default programming, other than play with the brightness levels. Have I done something wrong? is the default programming set to flash on and off like this?
before putting all this together I made sure I had the proper "P" meanwell drivers for this.
