Page 1 of 5
Coding Pwm module.
Posted: Tue May 08, 2012 3:31 am
by abhi_123
Hello Everyone.
which code should i use to make my pwm module to work.
i will be using 4 led drivers & two fans with parabola instead of slope with random cloud & lightning effect + moonlight phase on actinic channel on relay box.
Re: Coding Pwm module.
Posted: Tue May 08, 2012 7:25 am
I vote for one thing at a time.
1st step is getting the base code from RAGen. Do you have that?
Posted: Tue May 08, 2012 7:57 am
by abhi_123
rimai wrote:I vote for one thing at a time.
here we go
// Autogenerated file by RAGen (v1.2.2.171), (05/04/2012 21:21)
// RA_050412_2121.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define PWMEXPANSION
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.SingleATOLow(Port1);
ReefAngel.StandardLights(Port3);
ReefAngel.Wavemaker1(Port5);
ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardHeater(Port8);
// PWMSlope based on Internal Memory values for Standard Lights
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("abhi_123",);
Posted: Tue May 08, 2012 8:09 am
Ok, first thing we want to do is add the moonlight.
Replace this:
With this:
Posted: Tue May 08, 2012 8:13 am
by abhi_123
Done. now.
Posted: Tue May 08, 2012 8:15 am
Then, remove the daylight channel you are not using:
Posted: Tue May 08, 2012 8:17 am
And add the code for the parabolas. Make sure to add them in the designated area for your custom code:
ReefAngel.PWM.SetChannel(0,PWMParabola(9,0,20,0,0,100,0));
ReefAngel.PWM.SetChannel(1,PWMParabola(9,0,20,0,0,100,0));
ReefAngel.PWM.SetChannel(2,PWMParabola(9,0,20,0,0,100,0));
ReefAngel.PWM.SetChannel(3,PWMParabola(9,0,20,0,0,100,0));
Posted: Tue May 08, 2012 9:15 am
by abhi_123
updated.
now?
Posted: Tue May 08, 2012 9:56 am
Is it working?
Posted: Tue May 08, 2012 10:07 am
by abhi_123
YES.
Posted: Tue May 08, 2012 10:45 am
by abhi_123
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
Here is what i had uploaded. pwm expansion channel rating is still zero.
Posted: Tue May 08, 2012 12:20 pm
So, we don't know if it is working, right?
I guess you will need to wait until tomorrow to test?
Posted: Tue May 08, 2012 1:48 pm
by rufessor
I hate waiting for the sun to rise!
Seems like that's all I do lately!
Have fun-
Posted: Tue May 08, 2012 9:01 pm
by abhi_123
An update. Pwm expansion module is working fine but have some issue with actinic moonphase it is still on 59% although it is 9:30am here with sun shinning high.
Posted: Tue May 08, 2012 9:04 pm
Good.
From what time to what time do you want moonlights to be on?
Posted: Tue May 08, 2012 10:00 pm
by abhi_123
Just opposite to my daylight schedule.j
Posted: Tue May 08, 2012 10:02 pm
Replace this:
With this:
if (ReefAngel.Relay.Status(Port2)) ReefAngel.PWM.SetActinic(0); else ReefAngel.PWM.SetActinic(MoonPhase());
Posted: Tue May 08, 2012 10:50 pm
by abhi_123
Alright. My standard light are assigned on relay 3 so i have to make it 3 instead of 2?
After that now comes the fan portion. I like to install pwm fans on channel 4& 5 to control the temp of my heat sink & tank respectively.
Posted: Wed May 09, 2012 7:54 am
For Fan, use this:
byte Fan1Speed;
Fan1Speed=map(ReefAngel.Params.Temp[1],772,800,30,100); // Calculate Fan 1 speed
Fan1Speed=constrain(Fan1Speed,0,100);
ReefAngel.PWM.SetChannel(4,Fan1Speed);
byte Fan2Speed;
Fan2Speed=map(ReefAngel.Params.Temp[1],772,800,30,100); // Calculate Fan 2 speed
Fan2Speed=constrain(Fan2Speed,0,100);
ReefAngel.PWM.SetChannel(5,Fan2Speed);
You can change the temperatures and % on the map function.
I thought I had already posted this for you...
Posted: Fri May 11, 2012 11:07 am
by abhi_123
Sorry Roberto i missed that post that's why i asked again.
All my code is working great. Now i want to add lightning , cloud & thunderstorm effect to my lights.
Posted: Fri May 11, 2012 11:53 am
Cool.
How are you with memory space?
Posted: Fri May 11, 2012 6:39 pm
by abhi_123
rimai wrote:Cool.
Upto now no issue.
Posted: Fri May 11, 2012 6:42 pm
I mean, how much free space do you have?
Posted: Fri May 11, 2012 9:02 pm
by abhi_123
How to check that?
Posted: Fri May 11, 2012 9:06 pm
Hit the checkmark icon to compile and it will show you.
Posted: Fri May 11, 2012 9:29 pm
by abhi_123
31698 of 32256 bytes total.
Posted: Fri May 11, 2012 9:34 pm
That's getting pretty close to full.
I don't think we'll be able to fit.
Posted: Sat May 12, 2012 10:23 am
by abhi_123
any modification in my existing code is possible to include the desired function?
Posted: Sat May 12, 2012 11:28 am
If we hard code some of the settings and use a custom screen and custom menu, we will be able to squeeze it.
This would mean that you will loose the pH calibration on the menu and the graph on the main screen.
The other alternative is to modify the code in your PWM module itself and shift all the code for your lights to the module.
Take a look at these threads:
http://forum.reefangel.com/viewtopic.php?f=11&t=535
http://forum.reefangel.com/viewtopic.php?f=11&t=1069
http://forum.reefangel.com/viewtopic.php?f=11&t=923
Posted: Sat May 12, 2012 6:45 pm
by abhi_123
this is what i have to include in my code to shift light setting to my module?
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
