iPhone app problem
Posted: Fri May 11, 2012 12:44 am
by Poiromaniax
Hi,
I think I've found a bug in the app.
When I try change memory values, changes don't reflect on the controller.
For instance, I was trying to change vortech mode (location 855) any change I made did not reflect
Re: iPhone app problem
Posted: Wed May 16, 2012 4:44 am
by wolfador
I will look into this.
Posted: Wed May 16, 2012 7:18 am
Great!!!
I can't wait to see this fixed
I was trying a custom memory yesterday and it didn't work
It would be nice to be able to read as well as write.
Also, is there a way to get vortech stuff in there too
Posted: Fri May 18, 2012 12:27 pm
by wolfador
If someone wants to send me an mp10 and the module
I will add it in as a dedicated spot instead of having to use the custom variable.
Posted: Fri May 18, 2012 12:35 pm
Cool!!
I think the labels could use the units too, so everyone knows what that number represents. Something simple like (s) to indicate seconds for example
Re: iPhone apps
Posted: Sat Jun 23, 2012 11:27 pm
by mikedizon
Hi,
I was wondering if the "custom" box works in the memory?
I would like to use the mem loc and value for controlling ph with dosing.
I just downloaded the new reef angel update.
Re: iPhone apps
Posted: Sun Jun 24, 2012 6:58 am
mikedizon wrote:Hi,
It should work. You just need to input the memory location you wish to use in there and then update the value.
Posted: Sun Jun 24, 2012 8:42 am
by mikedizon
Hi,
After downloading and updating the Reef Angel Libraries Version: 0.9.6 and the new update wizard 1.04.
None of the setting in the memory works. You can view the overheat temp value that but cant change any settings. I just read that when it's hard coded it won't work. Maybe this is the reason. The wizard creates hard coding. Can anyone verify if this is correct. Any work around this. Thanks
Posted: Sun Oct 21, 2012 11:38 pm
by SuperDodge
I also can't change memory settings based on a block value.
Posted: Mon Oct 22, 2012 8:37 am
Yeah, iphone app is broken for that part
John hasn't updated that yet for quite some time.
Anyone else to take over??
