Does anyone with good knowledge of HTML/AJAX programming want to be apart of the development of the internal memory settings change through wifi?
Curt has expressed that the "Updated XML data sending for Client Suite usage of reading/writing memory values" is in progress and I'm pretty sure that Dave is also apart of this one on his Client software.
But, I would also love to be able to have this capability with direct connection to the controller through wifi.
My idea is to have the internal webserver return a javascript file, which will then construct the webpage and everything necessary for the change of settings.
Everything has to be self contained in the JS file for it to work.
Then when the user changes any settings, an http request is made to the controller through wifi and the controller would change the internal memory and return with a sucess or failed response.
Let me know if you are this guy
