Hello all,
I am looking at getting one of the Plus models, but I'm not 100% sure which one I should be getting. Here's the reason I'm stuck...
I will need compatibility with 2x Apollo SolarBlast Dimmables & 2x Tunze 6105s.
My ignorant guess is Plus Analog with the PWM Expansion Module, but of course, I am but a neophyte in this area.
Thanks in advance!
Which model should I get?
Re: Which model should I get?
Hi,
You will definitely need analog dimming signals for both the SolarBlast and Tunzes.
The PWM Expansion module can also be offered with Analog signal.
So, you can have 4 channels of dimming (2 white channels and 2 blue channels) for your SolarBlasts and 2 channels of control for your Tunzes.
If you get the expansion module, you may choose any dimming signal for the standard channels. You won't be using them for now.
Apollo1K9
Awesome, thank you very much for your assistance!
