PWM Expansion difficulties
Posted: Tue May 22, 2012 3:31 pm
by c_wick
So I've been trying for the past day and half to figure out how to set my LED lights on a dimming schedule. So far all I've been able to do is turn them on and off. I've changed to code during my experiments to have the LED's run at only 30% so that I can visually tell if the code is working....but so far they keep running at full power...my brain is fried from reading posts on the forum and trying to figure this out...any help would be awesome!
Not looking for anything fancy right now...just want a sunrise/sunset effect...
// Autogenerated file by RAGen (v1.2.2.171), (05/22/2012 14:47)
// RA_052212_1447.ino
//The following features are enabled for this File:
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define SIMPLE_MENU
#define PWMEXPANSION
#define RFEXPANSION
#define IOEXPANSION
// LEDPWM Channel defines for easy code reading
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
//Start of PWM Expansion Code for Slope
    PWMChannel[LEDPWM0]=PWMSlope(11,00,17,00,20,80,60,PWMChannel[LEDPWM0]);
    PWMChannel[LEDPWM1]=PWMSlope(10,00,18,00,20,80,60,PWMChannel[LEDPWM1]);
    PWMChannel[LEDPWM2]=PWMSlope(9,30,18,30,20,80,30,PWMChannel[LEDPWM2]);
    PWMChannel[LEDPWM3]=PWMSlope(10,30,17,30,20,80,30,PWMChannel[LEDPWM3]);
    // The lines above are what calculates the slope.
    // You can change the schedule by changing the parameter inside the parenthesis of the PWMSlope() function
    // The are as follow:
    // 1st parameter: hour to start slope
    // 2nd parameter: minute to start slope
    // 3rd parameter: hour to end slope
    // 4th parameter: minute to end slope
    // 5th parameter: % of the PWM signal to start slope
    // 6th parameter: % of the PWM signal to end slope
    // 7th parameter: duration of slope in minutes
    // 8th parameter: always the same as the variable before the PWMSlope() call
Re: PWM Expansion difficulties
Posted: Tue May 22, 2012 4:30 pm
Your code looks just fine to me.
Did you place the jumper on the head unit?
Posted: Tue May 22, 2012 4:34 pm
Actually, I'm sorry.
Tired today. I should go rest for a bit....
On 2nd look, the code is actually not doing anything.
Try this:
    ReefAngel.PWM.SetChannel(0,PWMSlope(11,00,17,00,20,80,60,0));
    ReefAngel.PWM.SetChannel(1,PWMSlope(10,00,18,00,20,80,60,0));
    ReefAngel.PWM.SetChannel(2,PWMSlope(9,30,18,30,20,80,30,0));
    ReefAngel.PWM.SetChannel(3,PWMSlope(10,30,17,30,20,80,30,0));
Posted: Tue May 22, 2012 4:48 pm
by c_wick
No changes Roberto...lights still pumping full power. Not sure if this matters much, I figured a ground is a ground...but...when wiring the PWM Expansion Module everytime I hooked the 12V Adapter ground wire to the ground on the Module the adapter shorted out. Right now I have all 4 drivers hooked into channel 0,1,2,3 on the Module and the 12V adapter hot wire in the +12VDC spot and all the ground drivers plus the ground from the 12V adapter soldered together, separate from the Module. When I do it this way the lights work...not sure if this is the reason why the lights aren't dimming...what do you think?
Posted: Tue May 22, 2012 5:12 pm
Yes, this is the reason.
You need the ground reference from the module to be the same as everything else and leaving disconnected you create 2 ground references.
But it should not short out when you connect the ground.
Can you descrive what happens when you say it shorts out?
Posted: Tue May 22, 2012 5:21 pm
by c_wick
Ok, after the + wire is hooked on the +12VDC spot on the module as soon as I touch the ground wire to the module the green light on the adapter goes out...figured it was shorting...
Posted: Tue May 22, 2012 5:24 pm
Yeah, that is definitelly not normal behavior.
Does it do the same thing even without the drivers connected?
PM me to send it for repair.
Posted: Thu May 31, 2012 11:10 am
by c_wick
Thanks Roberto, just got your package in the mail, installed the module, hooked the wiring up...everything works like a champ! Thank you again for all your quick responses and great service!
Posted: Thu May 31, 2012 4:30 pm
Cool. Glad it's working :)
