Android app
reefcycle
Android app
Post by reefcycle »
Controller is still online and I can access or change things from portal. However this morning all sensors are reading zero and I tried unplugging and plugging it in again and the status says parsing and then nothing. I tried restarting phone and nothing
Re: Android app
Curt released an update yesterday.
Maybe it has to do with the update.
Try push and hold the refresh button and choose home option.
Does it work now?
reefcycle
Re: Android app
Post by reefcycle »
Same parsing.
I even tried setting info in home and away
Re: Android app
What version of the libraries are you using?
Do you have expansion relays enabled?
It sounds like you have expansion relays installed and are using the 0.8.5.X libraries.
Was it ever working with the Android App?
reefcycle
Re: Android app
Post by reefcycle »
Worked perfect till this morning. I am going to redo everything tonight and see what happens
reefcycle
Re: Android app
Post by reefcycle »
ok updated reefangel code installed latest libraries and latest arduino and it all works now fyi
Re: Android app
reefcycle wrote:ok updated reefangel code installed latest libraries and latest arduino and it all works now fyi
Cool. Just out of curiosity, what version of the libraries were you using? If it was 0.8.5.X and expansion relays, that would have caused it to hang on the parsing. You would have had to enable the v0.8.5.X relay support to fix the problem.
