I just pushed a new release that fixes the Relay Expansion code bug with the ports not getting turned off. It's in my github account (https://github.com/curtbinder/ReefAngel/downloads). If anybody is using the Relay Expansion modules, it is advised that you update your libraries or make the necessary changes.
Also, RAGen Installer has been updated to reflect the changes too.
v0.8.5.14
- Contact:
Re: v0.8.5.14
I tested and it works now
I actually was lucky and got to test Client suite with the expansion boxes and your .14 libraries. Everything worked very nicely!!
- Contact:
Re: v0.8.5.14
Good. I'm glad it works nicely now. Hopefully that will make it easier for others.
