RF Expansion coding
Posted: Thu May 31, 2012 9:38 pm
by c_wick
Wondering if anybody can help me out here...I'm trying to get my Vortech pump setup with the RF expansion but unfortunately I'm failing... I stole somebody else's code and manipulated it to what I would like the pump to do. From the looks of it the module is working, I get a green light...but no talkie with pumpie...
Here's the code...
//Vortech Setup
if ( hour() > 11 || hour () < 14 )
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Random2,200,0); //Reef Crest from 11 am - 2 pm
else if ( hour() >= 13 || hour () <= 16 )
ReefAngel.RF.SetMode(Smart_NTM,230,10); //Nutrient Transport Mode from 1 pm - 4 pm
else if ( hour() > 16 || hour () < 20 )
ReefAngel.RF.SetMode(Smart_TSM,230,0); //Tidal Swell Mode from 4pm - 8 pm
else if ( hour() >= 20 || hour () <= 11 )
ReefAngel.RF.SetMode(Random1,125,0); //Night Mode from 8pm - 11 am
Re: RF Expansion coding
Posted: Thu May 31, 2012 9:50 pm
Did you sync the pumps with the controller?
Posted: Fri Jun 01, 2012 7:19 pm
by c_wick
I just synced the pump (didn't do that earlier...), everything went according to the manual (Had a solid green light on the module and solid white on the pump). When I tried uploading the Test code the module went to a white light and the pump stayed white...same thing when I tried uploading my code.
Posted: Fri Jun 01, 2012 7:38 pm
Which test code?
Posted: Fri Jun 01, 2012 7:53 pm
by c_wick
The customMainscreen_rfexpansion
Posted: Fri Jun 01, 2012 8:20 pm
The pump will always stay either white, orange or blue.
White means sync, orange means anti-sync and blue is back-of-tank.
You can check the modes on the vortech manual.
Now, the RF module changes colors according to whichever mode you set.
Let's see what is going on.
ReefAngel.RF.SetMode(0,50,10);
What color does the RF module show?
Posted: Fri Jun 01, 2012 8:29 pm
by c_wick
Module is green pump white
Posted: Fri Jun 01, 2012 8:32 pm
Green is good
Means you are communicating with the pump.
Now, let's try a different mode:
Does it change color?
Posted: Fri Jun 01, 2012 8:36 pm
by c_wick
Module looks white pump white
Posted: Fri Jun 01, 2012 8:43 pm
Is it white or light yellow??
Let's try one that has a very distinct color and changes speed.
Mode 3 is short pulse.
Posted: Fri Jun 01, 2012 8:52 pm
by c_wick
Module blue/pump white
Posted: Fri Jun 01, 2012 8:56 pm
Is the pump working like it is supposed to?
Short pulse at 50%?
Posted: Fri Jun 01, 2012 9:05 pm
by c_wick
Nope the pump right now is running at constant pump near max
Posted: Fri Jun 01, 2012 9:08 pm
Did you reset the pump settings before you went through the sync process?
What happens when you press the left button on the vortech driver?
Posted: Fri Jun 01, 2012 9:22 pm
by c_wick
Yep I followed the instructions to the T, after holding both the Mode and set buttons I get Flashing red, white and blue Then hold the mode until flashing purple and red
Posted: Fri Jun 01, 2012 9:24 pm
by c_wick
Then hold set and the pump goes to green and currently the pump is green with a perhaps yellowish white light on the rf module ( its kinda hard to tell)
Posted: Fri Jun 01, 2012 9:27 pm
by c_wick
Do you want me to send you my full code?
Posted: Sat Jun 02, 2012 8:50 am
If the driver is green, it means it is not synced.
When you erase the settings like you mentioned above, it turns the driver into a standalone driver.
Then you can go ahead and sync it to RA.
Posted: Sun Jun 03, 2012 4:26 pm
by c_wick
I'm still not able to get the pump working correctly. I've tested the code with different settings and everytime I get the RF module to change colors but nothing ever changes with the pump. I've reset and tried again from scratch mulitple times. Currently everything is set up as far as I can get it, the driver is white and if I hit the left button is goes orange
Posted: Sun Jun 03, 2012 4:51 pm
Just to confirm, you are hitting the joystick after you go though the sync process and get "Done" in the screen, right?
Posted: Sun Jun 03, 2012 4:55 pm
by c_wick
yep
