pH
Posted: Wed Jun 06, 2012 11:34 am
by DrewPalmer04
What would everything think this might mean? I read EKGs in my work and I'm seeing a bit of a pattern here with my pH. I might need to consider additives to stablize?
Re: pH
Posted: Wed Jun 06, 2012 11:39 am
What do you have kicking in at 6am?
Re: pH
Posted: Wed Jun 06, 2012 11:43 am
by DrewPalmer04
Looks like these:
ReefAngel.StandardLights( Port7,6,0,20,0 );
And:
ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
And this off at 6 AM:
if (hour>=21 || hour()<6)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
Re: pH
Posted: Wed Jun 06, 2012 11:45 am
by DrewPalmer04
But to me it looks like something is happening at 45 after the hour in intervals....sort of ....sometimes 30 min after the hour intervals.
Re: pH
Posted: Wed Jun 06, 2012 11:52 am
I'm looking at the data on the portal and the way I see it is there is something that is going on between 5 and 6 that is bringing the pH down. It's not normal for pH to peak like that.
It seems to start at 5 and goes back to normal at 6.
Re: pH
Posted: Wed Jun 06, 2012 12:00 pm
by DrewPalmer04
I'm seeing the exact same thing.
Here is all I'm running:
// Autogenerated file by RAGen (v1.2.2.171), (05/29/2012 16:15)
// RA_052912_1615.ino
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.SingleATO( false,Port2,60,0 );
    pinMode(lowATOPin,OUTPUT);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Port5);
    //randomSeed(analogRead(0)); Possible future wavemaker
    //ReefAngel.Init();  //Initialize controller
    //ReefAngel.Timer[1].SetInterval(random(15,35));
    //ReefAngel.Timer[1].Start();
    //ReefAngel.Relay.On(Port5); End here
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port8,7,0,19,0 );
    //////// ReefAngel.Wavemaker1(Port5);
    /////// ReefAngel.Wavemaker2(Port6);
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ///if ( ReefAngel.Timer[1].IsTriggered() ) Future wavemaker
          ///  ReefAngel.Timer[1].SetInterval(random(15,35));
          ///  ReefAngel.Timer[1].Start();
           /// ReefAngel.Relay.Toggle(Port5);
          ///  ReefAngel.Relay.Toggle(Port6);
          /// } End future wavemaker
    if (hour()>=6 && hour()<20)
    ReefAngel.Portal("DrewPalmer04", "********");
Re: pH
Posted: Wed Jun 06, 2012 12:02 pm
by DrewPalmer04
I have nothing over than a few wall timers going. I don't have anything that kicks on at 5am? My stuff is mainly 0600 to 2000 or 2100
Re: pH
Posted: Wed Jun 06, 2012 12:06 pm
It is not necessarily within the tank.
It could be something in your house or in the room where the tank is located.
Does anything turn on at 5am?
Re: pH
Posted: Wed Jun 06, 2012 12:09 pm
by DrewPalmer04
The reef angel is isolated on a batter backup? There is nothing that I can think of that would draw power. My sump MH is on a seperate circuit...but It's on at 2030 and off at 0730. The air handler for the AC is on the same line, but I would see spikes throughout the day...clueless really?????
Re: pH
Posted: Wed Jun 06, 2012 12:19 pm
I don't think it is related to power draw.
Do you have a gas heater in the house? Does any appliance get turned on at 5am?
CO2 can impact pH on the tank. I would think that it would have a less steep affect, but you never know.
My office tank shoots pH warnings all weekend long every weekend.
Why? I think it is because there is nobody in the office breathing and thus no CO2, which causes the pH to rise up more than on normal business days.
Re: pH
Posted: Wed Jun 06, 2012 12:24 pm
by DrewPalmer04
I have a gas heater, but the line has been turned off for two months....That's the only thing gas in my house...no other appliances. The dryer is found upstairs and vents outside...my sump is in the basement with windows open 24/7 for gas exchange. I find it weird that on the weekly ph chart it shows it throughout the day at set times? I'm thinking is my pH dropped like that (in real life) I would have some acid cooked fish???
Re: pH
Posted: Wed Jun 06, 2012 12:31 pm
by DrewPalmer04
hmmm...on my chart I'm showing 07:39 on my pH drop....to 5.63
Re: pH
Posted: Wed Jun 06, 2012 12:32 pm
by DrewPalmer04
And all last week...07:30 I have dropped...
Re: pH
Posted: Wed Jun 06, 2012 1:14 pm
I also noticed that you are sending data to the portal through the Client as well as the controller.
I would highly suggest you disabling the Client sending data and leave just the controller handle that.
Re: pH
Posted: Wed Jun 06, 2012 1:24 pm
by DrewPalmer04
Can i get a webbanner with just the controller sending portal data?
Re: pH
Posted: Wed Jun 06, 2012 1:28 pm
yes
Re: pH
Posted: Wed Jun 06, 2012 2:00 pm
by DrewPalmer04
done. so this ph issue could be power draw? Its happening everyday at 0730
Re: pH
Posted: Wed Jun 06, 2012 2:29 pm
Oh, sorry... I forgot the time difference.
Yes, I was looking at between 5 and 6am PDT. The data self adjusts to my local time automatically.
You must be 2 hours ahead of me.
So, do you have anything that goes on at 7am?
Re: pH
Posted: Wed Jun 06, 2012 2:34 pm
by DrewPalmer04
My T5HO lights with fan...probably draws 120 watts
