Main unit crashes
Posted: Fri Jun 08, 2012 2:23 pm
by tngo
Hi All,
Currently I am using the new Reef Angel controller with the extra memory upgrade along with an relay expansion. Prior to installing the relay expansion, the WDT would any prevent crashes on the main unit. Now with the relay expansion installed the controller is crashing quite often. I am not sure if its just the LCD screen not waking when I toggle the joystick or if it the unit has locked altogether. Is there a way to log whether the time relays are still turning on/off or is there a way to just have the unit reset every so often as to prevent it from locking up? Thanks in advance for the help and suggestions!
Tim
// Autogenerated file by RAGen (v1.2.2.171), (06/07/2012 22:08)
// RA_060712_2208.ino
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define RelayExp
#define InstalledRelayExpansionModules 0
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 7
#define CUSTOM_MAIN
#define COLORS_PDE
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "On/Off Day Light";
prog_char menu3_label[] PROGMEM = "On/Off Sump Light";
prog_char menu4_label[] PROGMEM = "Reset WDT";
prog_char menu5_label[] PROGMEM = "Date / Time";
prog_char menu6_label[] PROGMEM = "PH Calibration";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label  };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.Relay.Toggle(Port1);
ReefAngel.Relay.Toggle(Port2);
ReefAngel.Relay.Write();
ReefAngel.DisplayMenuEntry("On/Off Kessil");
void MenuEntry4()
ReefAngel.Relay.Toggle(Port8);
ReefAngel.DisplayMenuEntry("On/Off Sump Light");
void MenuEntry5()
wdt_reset();
ReefAngel.DisplayMenuEntry("Reset Watch Dog Timer");
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.SetupCalibratePH();
    ReefAngel.LCD.DrawDate(6, 116);
    ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
    ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
    ReefAngel.LCD.DrawOutletBox(12, 90, TempRelay);
    ReefAngel.LCD.DrawOutletBox(12, 101, TempRelay);
    ReefAngel.LCD.DrawGraph(5, 5);
    // Initialize the custom menu
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.FeedingModePortsE[0] =     B00000100;
    //ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] =     B00110100;
    ReefAngel.Relay.On(Box1_Port2);
    //wavemaker timer
    ReefAngel.Timer[1].SetInterval(random(35,50));
    ReefAngel.Timer[1].Start();
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Box1_Port5);
    //2nd wavemaker timer
    ReefAngel.Timer[2].SetInterval(random(20,35));
    ReefAngel.Timer[2].Start();
    ReefAngel.Relay.On(Port6);
    ReefAngel.Relay.On(Box1_Port6);
    ReefAngel.StandardLights(Port1);
    ReefAngel.MHLights(Port8);
    //Wavemaker Timer 1
    if(ReefAngel.Timer[1].IsTriggered())
      ReefAngel.Relay.Toggle(Box1_Port5);
      ReefAngel.Relay.Toggle(Port7);
    //Wavemaker Timer 2
    if(ReefAngel.Timer[2].IsTriggered())
      ReefAngel.Timer[2].SetInterval(random(25,35));
      ReefAngel.Relay.Toggle(Box1_Port6);
      ReefAngel.Relay.Toggle(Box1_Port4);
    if(ReefAngel.Params.Temp[T3_PROBE]>=770)
      ReefAngel.Relay.On(Box1_Port3);
    if(ReefAngel.Params.Temp[T3_PROBE]<=740)
      ReefAngel.Relay.Off(Box1_Port3);
Re: Main unit crashes
Posted: Fri Jun 08, 2012 2:28 pm
What version of libraries are you using?
Posted: Fri Jun 08, 2012 3:13 pm
by tngo
I don't remember the library version but the installer I believe it's 0.9.5 b or c. I can look later tonight.
Posted: Sat Jun 09, 2012 9:55 am
I'm looking over your code and it seems you are using ports other than 5 and 6 for wavemakers.
It's probably what is causing the issues.
Ports 5 and 6 have special filters to dampen the noise caused by constant on/off of pumps.
Also, the 0.9.5 version didn't have the WDT enabled for the RA+ boards.
Can you try updating the libraries and also try to keep the wavemaker pumps on 5 and 6?
Posted: Sat Jun 09, 2012 8:57 pm
by tngo
Thanks for the suggestion Roberto. Everything is all good now.
Tim
