Vortech\RF expansion issues
projectx
Post by projectx »
If I use the vortech MP40 controller to put the pumps into feeding mode, the entire system goes into feeding mode. But if I do it via the RA controller or the Droid app, the MP40s do not got into feed mode, only the pumps plugged into the RA go into feed mode.
Any ideas?
I used the vortech setup code in examples to set the 2 pumps slave.
here is my code
// Autogenerated file by RAGen (v1.2.2.171), (05/29/2012 11:15)
// RA_052912_1115.ino
#define DisplayImages
#define SetupExtras
#define DosingPumpSetup
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define DisplayLEDPWM
#define wifi
#define SingleATOSetup
#define RelayExp
#define DosingPumpIntervalSetup
#define PWMEXPANSION
#define ENABLE_ATO_LOGGING
#define ENABLE_EXCEED_FLAGS
#define RFEXPANSION
ReefAngel.FeedingModePorts = Port5Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.LightsOnPortsE[1] = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Box1_Port3);
ReefAngel.SingleATOLow(Port1);
ReefAngel.MHLights(Port4);
ReefAngel.DosingPumpRepeat1(Port7);
ReefAngel.DosingPumpRepeat2(Port8);
ReefAngel.MHLights(Box1_Port5);
ReefAngel.MHLights(Box1_Port6);
ReefAngel.StandardLights(Box1_Port1, 21, 0, 9, 0);
ReefAngel.StandardLights(Box1_Port2, 21, 0, 9, 0);
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(2,128,0);
// PWMSlope based on Internal Memory values for Standard Lights
ReefAngel.Portal("projectx");
Re: Vortech\RF expansion issues
Probably because of this line:
Try removing and see if it works.
projectx
Post by projectx »
Take it out all together or set it to true?
remove it
projectx
Post by projectx »
same result
What happens if you comment out this 2 lines:
projectx
Post by projectx »
Interesting, I remove those lines and it does work properly, and I can change the modes via the Memory in the App. It also shows the update in the Portal.
