Problem with Vortech controlling
Posted: Mon Jun 18, 2012 5:46 am
by stephy
Here is my code:
    ReefAngel.AddDateTimeMenu();
    InternalMemory.OverheatTemp_write( 309 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardLights( Port1,10,0,22,0 );
    ReefAngel.StandardLights( Port2,11,0,21,0 );
    ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port2 ) );
    ReefAngel.StandardHeater( Port5,252,256 );
    ReefAngel.StandardFan( Port6,255,259 );
    if (hour()>=21 || hour()<11)
      ReefAngel.PWM.SetActinic( 0 );
    if (hour()==10)
      ReefAngel.RF.SetMode( ReefCrest,50,10 );
    else if (hour()>=11 && hour()<13)
      ReefAngel.RF.SetMode( ReefCrest,75,10 );
      else if (hour()>=13 && hour()<14)
      ReefAngel.RF.SetMode( Constant,30,10 );
      else if (hour()>=14 && hour()<15)
      ReefAngel.RF.SetMode(Smart_TSM,75,10 );
      else if (hour()>=20 && hour()<21)
      ReefAngel.RF.SetMode(ReefCrest,50,10 );
      else if (hour()>=22 || hour()<9)
      ReefAngel.RF.SetMode(Night,50,10 );
    ReefAngel.Portal( "stephy" );
All works except the vortech feeding mode that can't work from ra controller. Pump changes according to hours, rf change led color.
I'm a little bit confused also about parameters, can anybody place a scheme, please?
Stephy
Re: Problem with Vortech controlling
Posted: Mon Jun 18, 2012 7:53 am
What happens is that your code is overriding the feeding mode.
Try using this:
    if ( ReefAngel.RF.Mode != Feeding_Start)
      if (hour()==10)
Posted: Mon Jun 18, 2012 9:29 am
by stephy
rimai wrote:What happens is that your code is overriding the feeding mode.
Fine, it works perfectly.
