No graph on RA display
Posted: Mon Jun 18, 2012 10:27 am
by stephy
I'm using a code generate by wizard and the ra display doesn't draw any graph, while ports, Ts, pH and lights are updated. Did I forget something?
Another question, can I print on ra display date and time in format: dd/mm/yy and 18:21:04 (i.e.)?
Stephy
Re: No graph on RA display
Posted: Mon Jun 18, 2012 3:26 pm
It will strip out the graph if you enable some expansions.
Which ones do you have?
The time and date can't be displayed in military time :(
Posted: Mon Jun 18, 2012 10:30 pm
by stephy
rimai wrote:It will strip out the graph if you enable some expansions.
wifi and rf. Windows client works well, portal sometimes fails (I haven't configured dyndns yet).
