PWMSlope
PWMSlope
Trying to set actinics to shut off at 1:30am, by using the following:
ReefAngel.PWM.SetActinic( PWMSlope(11,30,01,30,2,100,120,0) );
If I load that code in the afternoon, upon loading, my actinic driver is off.
If I load the following:
ReefAngel.PWM.SetActinic( PWMSlope(11,30,24,59,2,100,120,0) );
The actinic driver is on. This doesn't seem to make sense, as there isn't a 2459 (or 2430 for that matter)
So, what is the correct way to set ending times for early morning?
Re: PWMSlope
The PWMSlope can't cross over to another day.
Try this:
http://forum.reefangel.com/viewtopic.ph ... 9&start=20
Try this:
Re: PWMSlope
Looks complicated in order to turn off at 1:30
Re: PWMSlope
In the thread referenced, it looks like D0lph1n was trying to accomplish several things.
Is there a simple example of PWMSlope where lights are set ON before midnight and OFF after?
Re: PWMSlope
The Wizard can't handle this, correct?
Re: PWMSlope
No, the wizard can't do that.
The PWMSlope function will not cross over to next day.
To do what you want, just use the function PWMSlopeOvernight() I posted in that thread.
Re: PWMSlope
I'm doing something wrong - Still turns off at midnight.
Does anyone have a simpler code example for use of PMWSlopeOvernight()?
Re: PWMSlope
Not sure what you are doing.
It's just like the other one, except it is called PWMSlopeOvernight, instead of PWMSlope.
ReefAngel.PWM.SetActinic( PWMSlopeOvernight(11,30,1,30,0,100,60,0) );
Re: PWMSlope
this is what i get:
sketch_12July:71: error: 'PWMSlopeOvernight' was not declared in this scope
Re: PWMSlope
Oh, you have to add the function to the end of your code, just like the post in the above thread.
This is a non standard function.
Here is the function again:
byte PWMSlopeOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
unsigned long Start = previousMidnight(now())+NumMins(startHour, startMinute);
unsigned long StartD = Start + Duration;
unsigned long End = nextMidnight(now())+NumMins(endHour, endMinute);
unsigned long StopD = End - Duration;
if ( now() >= Start && now() <= StartD )
return constrain(map(now(), Start, StartD, startPWM, endPWM),startPWM, endPWM);
else if ( now() >= StopD && now() <= End )
byte v = constrain(map(now(), StopD, End, startPWM, endPWM),startPWM, endPWM);
return endPWM-v+startPWM;
else if ( now() > StartD && now() < StopD )
return endPWM;
// lastly return the existing value
return oldValue;
Re: PWMSlope
i shouldnt need his If-Then-else logic though. i just loaded this code. did i get it right?
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 829 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.DosingPumpRepeat( Port1,0,60,10 );
ReefAngel.DosingPumpRepeat( Port2,5,60,10 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.StandardLights( Port7,11,0,2,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(12,30,23,30,0,100,90,0) );
ReefAngel.PWM.SetActinic( PWMSlopeOvernight(10,30,1,30,0,100,120,0) );
ReefAngel.Portal( "name", "xxxx" );
return endPWM;
return oldValue;
return endPWM;
return oldValue;
Re: PWMSlope
Exactly what I've been trying to say. Very simple.
I'm so sorry I didn't make it more clear
That looks good.
Try it out and let me know.
That looks good.
Re: PWMSlope
Well, it shut off at midnight again. I must be missing something.
Re: PWMSlope
Actinics turned off 0% at midnight, THEN 10-11 minutes later, came back on 100%.
I'm confused.
I'm confused.
Re: PWMSlope
Sorry
I made a mistake... lol
In that post, there was a correction on the PWMSlopeOvernight function.
http://forum.reefangel.com/viewtopic.php?p=8905#p8905
So, use that code instead. I should've read the entire post.
Re: PWMSlope
Seems to work great now!
Tim
Tim
PWMSlope
I've modified the PWMSlopeOvernight function so it should work as a standard and overnight slope. Please take a look at the logic, if it's good perhaps you can make this the standard PWMSlope function
My moonrise/moon set times may be overnight and maybe standard, so to have one function to use simplifies a lot
unsigned long Start = previousMidnight(now())+((unsigned long)NumMins(startHour, startMinute)*60);
unsigned long End = nextMidnight(now())+((unsigned long)NumMins(endHour, endMinute)*60);
boolean isOvernight=NumMins(startHour,startMinute)>NumMins(endHour,endMinute);
if (hour()<startHour && isOvernight) Start-=86400;
if (hour()<startHour || !isOvernight) End-=86400;
unsigned long StartD = Start + (Duration*60);
unsigned long StopD = End - (Duration*60);
endPWM);
endPWM);
return endPWM;
return oldValue;
Re: PWMSlope
I don't know yetrimai wrote:Awesome!!!
Does it work well?
Re: PWMSlope
Regular usage worked. We now have a universal PWMSlope function... who wants to do the same for PWMParabola
Re: PWMSlope
Thanks thekameleon for a PWMParabola version...
http://forum.reefangel.com/viewtopic.php?p=23120#p23120
