wifi setup issues
Posted: Wed Jul 11, 2012 7:54 pm
by Addicted2Coral
i started the setup utility downloaded with the initial software.. it asks for a password and name.. i have none my access is not blocked in any way.. is there a way around this??
Re: wifi setup issues
Posted: Wed Jul 11, 2012 8:57 pm
by Addicted2Coral
to be certain i am understood... my security is disabled.. the reason why is because i have a computer and a tablet.. the computer only works on a security that the tablet will not, the tablet works on a security that my computer will not..
please tell me i can get by this and still use my wifi connection...
it looks like the rf module will only be used for my pumps.. it does not allow my radions to be controlled by the set programs from the ecotech software.. but first things first the wifi.. i am goin to bed i cant handle no more.. please help!!
Posted: Wed Jul 11, 2012 8:59 pm
Try using the ssid and no password. Maybe it works.
Posted: Wed Jul 11, 2012 9:07 pm
by Addicted2Coral
Tried that. It turns the screen blank. The same result I get when I leave them both blank.
Posted: Wed Jul 11, 2012 9:13 pm
You may need to manually set it up then. Check the manual for instructions.
Posted: Wed Jul 11, 2012 9:48 pm
by Addicted2Coral
man this is frustrating... i download that software, actually already done so.. and follow the instructions.. it says that i should get some lines of data, then type $$$ within 1 second or something to get cmd function but as soon as i plug in the wifi module... nothing happens.. no data comes up.. it is connected but nothing works.. its automatically on the port.. but i cant type anything.. and no data loads up when the lights start to blink..
Posted: Wed Jul 11, 2012 10:45 pm
by Addicted2Coral
ok so for ssid i used my ssid, then for the authentication i used "none" it then went passed and gave this reading in the wifi utility
Please wait...
Setting up you Reef Angel Wifi Attachment...
your reef angel wifi attachment is now configured
"wifi status*
Associated: false
Authenticated: false
DHCP: false
Ip address and port: 192.168.2.13:2000
If the blue led is still blinking. it means that the reef angel wifi attachment could not connect to your wifi network.
If you would like to connect to your controller from outside your wifi network, the TCP port 2000 needs to be forwarded to 192.168.2.13 ip address above.
this hast to be done on your wifi router.
Routers with UPnp capability and compatible with the UPnPlib java implementation can be automatically configured for port forwarding.
Trying to connect to your router....
Found router G Wireless Router...
Attempting to setup port forwarding...
Port 2000 is now being forwarded to 192.168.2.13
Ok now i have a slow blinking green light, i assume this is correct action... then i follow the directions on loading the wifi example code into the reef angel, i dont know what to change where, but i tried anyway.. i loaded the wifi code, then it said press joystick to continue.. i do this and it does nothing... that message goes away and nothing is happening..
i dunno if i loaded the wrong code or what..
does it seem that the wifi attachment is good to go, and that it is the code that is the problem now, or is it still the attachment...??
and the big question is.. what do i do now..? i am sorry to bother you guys so much, if i would have known this i probly would not have gotten it.. not trying to be bitchy i just am so frustrated that 10 hours worth of work and i have squat to show for it.. i had two freind willing to buy the whole setup i did, one works offshore and wanted to have a webcam and this to monitor his levels while out... i would have to go and help them both step by step, that is if i get mine going...
Posted: Thu Jul 12, 2012 7:42 am
by Addicted2Coral
wifi still dont work, it says that it is configured from the utility.. i really need some help..
Posted: Thu Jul 12, 2012 7:50 am
Yes, you loaded the wrong code.
You wer supposed to load WifiTestCode and Not WifiSetup.
When you loaded the WifiSetup code, it messed up the settings you had gotten correctly in the first step you described above. You can redo the 1st step again and it will put things back correctly.
Then make sure to load WifiTestCode this time.
Posted: Thu Jul 12, 2012 7:52 am
by Addicted2Coral
sorry for being so ignorant, but i load the wifi test code in the reefangel.. not the wifi module right
Posted: Thu Jul 12, 2012 7:55 am
Correct.
Posted: Thu Jul 12, 2012 8:44 am
by Addicted2Coral
thanks fixed.. already found my next problem.. lol
Posted: Thu Jul 12, 2012 9:35 am
by fatman
Hang in there Addicted, when it finally comes together it's well worth it. Much of the really cool code has been written, so it's now a cut and paste operation to get some very cool features.
Posted: Thu Jul 12, 2012 1:15 pm
by Addicted2Coral
so the wifi worked for about an hour...
the green light flashes slowly on the wifi adapter, but the portal says unreachable address..
the portal on my phone just continually tries to update with no luck
the portal on my pc never did work.. lol
this sure is confusing to me...
Posted: Mon Mar 11, 2013 3:57 pm
by smellsfishy
Addicted2Coral wrote:Tried that. It turns the screen blank. The same result I get when I leave them both blank.
Just thought I'd throw this out there because I hit the same issue. When using the wifi_utility, it seems to expect something in the passphrase field, even if you are using an open network without encryption. Without a passphrase, you just get a black screen. I entered a single space into the passphrase field and it seemed to do the trick.
Posted: Mon Mar 11, 2013 4:21 pm
smellsfishy wrote:Addicted2Coral wrote:Tried that. It turns the screen blank. The same result I get when I leave them both blank.
Good catch. This has been noticed before. Maybe a comment should be added to the doc
Also, maybe you should protect your WiFi
