Updating to new libraries
Posted: Fri Jul 13, 2012 7:33 pm
by grafspee1217
Hi Roberto,
I have been meaning to extend my ATO timeout for a while and did some reading up on it. I see that there has been an update to the libraries that allows this to be done on the fly. I will try and update tomorrow. Since I have wifi, do I have to go through the setup for that all over again? Can I use any of my old code for PWM slope for example?
Re: Updating to new libraries
Posted: Fri Jul 13, 2012 7:47 pm
Yes, you can still use the old code. It is the same.
Do you use android app?
Posted: Fri Jul 13, 2012 7:51 pm
by grafspee1217
No not currently, will be in a month when I upgrade my phone, why?
Posted: Fri Jul 13, 2012 7:55 pm
Just wanted to check to give you how to change the setting.
You will need to browse to http://ipaddress:2000/mb276,xxx to change the value on the fly.
Posted: Fri Jul 13, 2012 8:01 pm
by grafspee1217
Once I update, I have to set up the wifi and the client again?
Posted: Fri Jul 13, 2012 9:28 pm
no. all you need to do is upload the code again.
You may need to upload the internal memory file too.
