Dimming Expansion Module
grafspee1217
Hi Roberto, I am considering the analog dimming module. Does this require a separate power supply, Is the power supply included? When you add the module do you still have use of the dimming ports on the main relay box?
Re: Dimming Expansion Module
It comes with a 12VDC power supply.
Yes, you can still use the dimming ports on the main relay box in addition to the 6 on the dimming module.
