Internal Memory section
Posted: Fri Jul 20, 2012 5:04 pm
Hi Everyone,
I just updated the Portal code to include the Internal Memory section.
This will allow you to change some internal memory settings right in the Portal too!!
It requires dev libraries v1.0.1, which is due to be released soon.
Stay tuned!
Re: Internal Memory section
Posted: Sat Jul 21, 2012 7:55 am
by fatman
Very nice, thank you.
Posted: Sat Jul 21, 2012 8:58 am
by btorrenga
Awesome feature, very very explanatory and well laid out. However, I have been having trouble setting my heater on value since upgrading to dev lib 1. The value seems to be stuck at 1023. Setting it via the wizard and android app has no effect. I tried with the portal, same result. Here is the portal output when setting the memory:
Saving Internal Memory...
Controller is running dev libraries v.1.0.1
Heater On - OK
Chiller On - OK
Chiller Off - OK
Vortech Mode - ERR
Done.
Checking with the android app shows the heater on temp value is still 1023. What could be causing this value to stick like that?
Posted: Sat Jul 21, 2012 9:16 am
There was a memory table relocation on version 1.0.0
On android app, choose Settings->Settings and make sure that Pre v1.0 Locations is unchecked.
It will direct the android app to look at the new memory table.
Posted: Sat Jul 21, 2012 9:20 am
by btorrenga
Right, I found that after I upgraded to 1.0.0. The option is unchecked in the app, but the variable does not change. Could something have gotten screwed up when, after I initially upgraded to 1.0.0, I did not uncheck that option at first?
Posted: Sat Jul 21, 2012 9:25 am
What do you get when you browse http://ipaddress:2000/mi222 ?
Posted: Sat Jul 21, 2012 9:34 am
by btorrenga
<M222>1023</M222>
Is that a default value from when I upgraded to 1.0.0?
Posted: Sat Jul 21, 2012 9:53 am
yes, that's the default value.
Now, what happens when you browse:
http://ipaddress:2000/mi222,780
That should put the 780 value in the memory. Does it do that?
Posted: Sat Jul 21, 2012 9:54 am
Did you run the memory conversion code or loaded a new memory file at all?
http://forum.reefangel.com/viewtopic.php?f=7&t=1477
Posted: Sat Jul 21, 2012 9:55 am
by btorrenga
<M222>OK</M222>
And then the result of http://ipaddress:2000/mi222 is
<M222>1022</M222>
Which is especially odd, isn't it???
Posted: Sat Jul 21, 2012 9:56 am
by btorrenga
rimai wrote:Did you run the memory conversion code or loaded a new memory file at all?
I loaded a new memory file created with the wizard
Posted: Sat Jul 21, 2012 10:54 am
Is it just the heater memory location?
Can you post what you get with /mr?
Posted: Sat Jul 21, 2012 11:19 am
by btorrenga
As far as I know it is the only memory section that gives this issue. Here is /mr (not sure what it means):
<MEM>
0D0016FF0C001600FFFFFFFF07FFFFFF78003E030000FE031603390334033C63031C020AFFFFFFFFFFFFFF3C00FFFF0000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF100EFFFFFFFFFFFF3CFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0AFFFFFFFFFFFFFFFF
</MEM>
Posted: Sat Jul 21, 2012 2:26 pm
If you try to change the hearter off, chiller on and chiller off, does it take those?
Posted: Sat Jul 21, 2012 2:37 pm
by btorrenga
Yes, I can successfully change all of those values.
Posted: Sat Jul 21, 2012 2:47 pm
Humm.. Let's see what happens if you change a byte long variable.
Try /mb222,100
Then read the byte value too with /mb222
What do you get?
Posted: Tue Jul 24, 2012 4:26 pm
by btorrenga
Result of /mb222,100:
<M222>OK</M222>
Result of /mb222:
<M222>254</M222>
Posted: Tue Jul 24, 2012 5:20 pm
It looks like your memory is somehow not saving it :(
I think the only solution is replace it. There isn't a way to replace the memory.
PM me.
