ATO status color
Posted: Sun Jul 22, 2012 3:52 pm
I have my ATO in the standard configuration. When the water is at the 'normal' state, the ATO low is red as well as the ATO high. I guess I'm thinking that red means water level is below the low ATO level and would therefore be green in the 'normal' state. When the pump kicks in it would fill until the ATO high was floating and both would be green in the portal. For example....
normal state: ATO high (red) ATO low (green)
trigger state: ATO high (red) ATO low (red)
filled state: ATO high (green) ATO low (green)
I am using the TOM aqualifter and it is a slow fill. I thing the new libraries will let it work automatically, but it is slow enough now I can usually see it progress to top off the low and then the high level. (I have to manually keep the power on now as the timeout is too fast).
Am I missing something?
Jon
Jon
