error uploading
dtzreef
error uploading
So, out of the gate. I'm trying to upload initial memory and first i get a "can't find com0" so I use COM3. Then I get "error uploading" message. Please help!!
Re: error uploading
Do you have any other port available?
Which RA do you have?
You have to make sure to select the correct one on Tools->Boards.
Reef Angel w/ optiboot for the standard RA and Reef Angel Plus for RA+
dtzreef
Re: error uploading
Just showing COM3 and pretty sure RA optiboot.
Re: error uploading
Can you double check one setting?
Control Panel->System->Device Manager->Ports(COM & LPT)
Double-click "USB Serial Port (COM3)"
Go to "Port Settings" tab
Click "Advanced" button
Make sure that "Set RTS on Close" is checked.
This is usually taken care by the RA installer, but by the way you mentioned COM0 was initially selected, indicates that this may not have been correctly set by the RA installer.
dtzreef
Re: error uploading
I already checked that. I'm good there. Could it be that I have to generate the settings in RAGen before I upload the code in Aduino. If that is the case it was not very clear in the Tutorials or maybe I'm just an idiot. (the later is probably the case). Should I just Unistall and reinstall then generate in RAGen then upload in Aduino. Thanks
Re: error uploading
You don't need RAGen to upload code.
Does your controller reboot when the message "Rebooting Reef Angel Controller" shows on the screen?
dtzreef
Re: error uploading
I haven't received a reboot message.
Re: error uploading
When you click upload, there is a log of what is happening at the bottom in red.
Can you copy and paste here?
dtzreef
Re: error uploading
Okay, how do I do that? I can copy and paste the program but I cannot copy the bottom part. I can tell you the last couple of lines.
using port:\\.\COM3
Using programmer:arduino
rebooting Reef Angel Controller
overriding baud rate: 115200
avrdude: send: 0 [30] [20]
avrdude:recv:
avrdude stk500_get sync():not in sync:resp=0x64
using port:\\.\COM3
avrdude:recv:
Re: error uploading
You see where it says rebooting Reef Angel Controller.
That's what I was asking.
dtzreef
Re: error uploading
I do see it. Should it reboot?
Re: error uploading
Yes, it should reboot the controller when that message shows up. Does it do it?
dtzreef
Re: error uploading
No, I get a flashing red led for a few seconds, nothing else.
dtzreef
dtzreef
Re: error uploading
Just wanted to post that Roberto tried to help me out remotely (freakin cool!!). But the problem ended up being the USB cable. He sent me a new one, received it in about two days, and now I'm up and running like a champ. VERY impressed so far!!!!!!!
Thavngr98
Re: error uploading
Roberto I got my RA yesterday and tried installing it today and I am having the same issues.
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 6,812 bytes (of a 32,256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\DMCJF\AppData\Local\Temp\build3283570312751371588.tmp\InitialInternalMemory.cpp.hex:i
System wide configuration file is "C:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
Ive tried both the wizard and installer and got the same error
Hmm maybe my cable is ok. I was able to connect the WiFi module to my router.
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv:
-Dave
Re: error uploading
Which RA did you order?
Make sure you have the correct board in menu Tools->Board
Thavngr98
Re: error uploading
Ok, you are good in there.
Can you check if you have multiple serial ports?
menu Tools->Serial Ports
If you have more than one, try the other ones.
Thavngr98
Re: error uploading
I tried com1 also but its shouldnt be that anyways. It recognized the cable on port 3 during the installation.
-Dave
Thavngr98
