I don't understand this thing
Posted: Thu Jul 26, 2012 5:28 am
Okay I've posted before how my reefangel will randomly turn things off and wont let me turn them back on until I unplug the relay box. Well last night I removed a bunch of sand from my tank and the water level was low. I manually turned off the ATO so it wont kick on and empty my ATO water into my tank. I also turned off 1 of my 2 return pumps. Wouldn't you know it this morning both my return pumps are running and 7 gallons of ATO found its way into the tank. The controller that was supposed to make my life easier gives me nothing but headcahes all the time. Is there a step by step how this thing works? This is how it works (at least in my head)
Controller turns on and enables all the ports setup in code
Controller runs though the loop turning on and off relays etc
User disables one of the relays manually
Controller keeps running though the loop but will no longer be able to turn on the disabled port
Person using the controller is happy because 7g of ATO water doesn't get dumped into the tank and his 2nd return pump doesn't burn itself out due to not enough water being in the tank.
^ Am I off in that thinking?
