Upgraded to RA+ - Jumpers?
Posted: Fri Jul 27, 2012 7:39 am
by rschneider77
Hello, I just recently purchased the RA+ board upgrade. I replaced the board and put the unit back together. I then uploaded the memory, and then the INO/PDE file. The lights won't turn on or off.
I have just read a few posts about jumpers needed to be moved/changed/switched I guess. But I couldn't find any detailed instructions for which ones to change or remove. Could you explain the process or let me know exactly which ones to change?
Thank you.
Chris Schneider
Re: Upgraded to RA+ - Jumpers?
Posted: Fri Jul 27, 2012 8:01 am
I think they were already there, but just to be sure, look at the board and you will see 3 places for jumpers on the left side of the joystick. All three should be there.
Jumpers are only needed if you have expansion modules though.
It seems you did everything right. Have you checked the time on the controller?
Posted: Fri Jul 27, 2012 8:24 am
by rschneider77
rimai wrote:Jumpers are only needed if you have expansion modules though.
We do not have any expansion modules that I'm aware of, unless one of these are. We have 2 temperature probes, a PH probe, and an ATO plugged in. We also have the WIFI attachment. Are any of these considered expansion modules?
Thank you,
Chris Schneider
Posted: Fri Jul 27, 2012 8:38 am
No, so you don't need to worry about jumpers.
Posted: Fri Jul 27, 2012 8:47 am
by rschneider77
Probably just the Time/Date setting like you said. Thanks.
