SingleATOLow not working properly
Posted: Sun Jul 29, 2012 1:36 pm
I am not sure what I am doing wrong here. I have a set of float switches wired in series (for redundancy) plugged into ATOLow that controls my ATO (port 8). Thoughts?
It works when I hard code ATOLow to turn on/off port 8, but I don't get the 60 second timeout:
But this won't work (using SingleATOLow). It'll work the first time but then never comes back on when the water level is too low:
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.StandardHeater( Port6 );
// ReefAngel.SingleATOLow( Port8 );
if ( ReefAngel.LowATO.IsActive() )
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.Off(Port8);
ReefAngel.Portal( "alexwbush" );
