Re: customization menu
Posted: Mon Jul 30, 2012 12:38 pm
Try this:
// Versione 1.0
boolean PowerCoralActive=true;
boolean ScaredFish=false;
byte ScaredFishOnHour;
byte ScaredFishOnMinute;
prog_char menu1_label[] PROGMEM = "Alimentazione pesci";
prog_char menu2_label[] PROGMEM = "Alimentazione coralli";
prog_char menu3_label[] PROGMEM = "On luce";
prog_char menu4_label[] PROGMEM = "Off luce";
prog_char menu5_label[] PROGMEM = "Cambio acqua";
prog_char menu6_label[] PROGMEM = "ATO Clear";
prog_char menu7_label[] PROGMEM = "Overheat Clear";
prog_char menu8_label[] PROGMEM = "PH Calibration";
prog_char menu9_label[] PROGMEM = "Version";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label, menu9_label  };
void MenuEntry1()
  ReefAngel.FeedingModeStart();
void MenuEntry2()
  PowerCoralActive=false;
  ReefAngel.Timer[1].Start();
  ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry3()
  ScaredFish=true;
  ScaredFishOnHour=hour();
  ScaredFishOnMinute=minute();
  ReefAngel.Relay.RelayMaskOn|=Port4Bit;
void MenuEntry4()
  ScaredFish=false;
  ReefAngel.Relay.RelayMaskOn=0;
  void MenuEntry5()
void MenuEntry6()
ReefAngel.ATOClear();
void MenuEntry7()
ReefAngel.OverheatClear();
void MenuEntry8()
ReefAngel.SetupCalibratePH();
void MenuEntry9()
ReefAngel.DisplayVersion();
    ReefAngel.Init();
    ReefAngel.SetTemperatureUnit( Celsius );
	InternalMemory.FeedingTimer_write(600);
	ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
	ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
	ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.Timer[1].SetInterval(10800);
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.DelayedOn( Port1,2 );
    ReefAngel.SingleATO(true,Port3,60,0);
    ReefAngel.StandardLights( Port4,10,59,19,5 );
    ReefAngel.StandardLights( Port5,7,0,19,0 );
    ReefAngel.StandardHeater( Port7,239,241 );
    ReefAngel.StandardFan( Port8,239,281 );
    if (ScaredFish)
      ReefAngel.PWM.SetDaylight( PWMSlope(ScaredFishOnHour,ScaredFishOnMinute,19,0,5,60,10,5) );
      ReefAngel.PWM.SetActinic( PWMSlope(ScaredFishOnHour,ScaredFishOnMinute,17,0,5,30,10,5) );
      ReefAngel.PWM.SetDaylight( PWMSlope(11,0,19,0,5,60,120,5) );
      ReefAngel.PWM.SetActinic( PWMSlope(12,0,17,0,5,30,120,5) );
    if (ReefAngel.Timer[1].IsTriggered()) PowerCoralActive=true;
    ReefAngel.Relay.Set(Port1,PowerCoralActive);
    ReefAngel.Portal("adrynapoletano", "bisboccia");
