pH meter and ATO issues...
Posted: Tue Jul 31, 2012 12:44 pm
For the life of me I can't seem to figure out why I am having pH and ATO issues.
My pH meter doesn't appear to have any physical damage. The bulb is not cracked or damaged in any visible way. After I calibrate it, it measures the pHs of my 7 and 10 standards correctly and it measures the pH of my tap water approximately correctly. But when I drop it in my tank, it says the pH is 1.6
Considering that I did not just dump a bottle of HCL into my tank, and its inhabitants are all pretty much OK, I know something is wrong. I have been having this issue for a few months now... The probe is not near any wires or pumps.
I had problems getting my RA to properly perform the StandardATO function. It kept performing the SingleATO function instead. I finally got it to work last week (I have no idea how...it just decided to work for no apparent reason that I can understand). But it only works properly intermittently. When the low ATO switch is triggered, the pump comes on. I have the timeout set for 240 seconds. But sometimes, the pump just shuts off, before the high ATO switch is visibly triggered and way before the timeout expires. I have the float switches mounted correctly, the high switch pointing up and the low switch pointing down.
Here's my code:
Any help on these issues would be appreciated.
Here's my code:
// Autogenerated file by RAGen (v1.2.2.171), (06/07/2012 14:54)
// RA_060712_1454.ino
#define VersionMenu
#define DisplayLEDPWM
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 8
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu2_label[] PROGMEM = "pH Calibration";
prog_char menu3_label[] PROGMEM = "DT Lights On";
prog_char menu4_label[] PROGMEM = "DT Lights Off";
prog_char menu5_label[] PROGMEM = "Toggle Fuge Lights";
prog_char menu6_label[] PROGMEM = "Date/Time";
prog_char menu7_label[] PROGMEM = "ATO Clear";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");
ReefAngel.SetupCalibratePH();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");
ReefAngel.Relay.Toggle(Port3);
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");
ReefAngel.SetupDateTime();
void MenuEntry8()
ReefAngel.ATOClear();
ReefAngel.DisplayMenuEntry("Cleared ATO Timeout");
// Initialize the custom menu
ReefAngel.FeedingModePorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port5);
ReefAngel.Timer[1].SetInterval(8);//Wavemaker Timer
ReefAngel.Timer[1].Start();
ReefAngel.Timer[2].SetInterval(8);//Wavemaker Delay Timer
// Initialize and start the RA Client logging timer
ReefAngel.Timer[4].SetInterval(15); // set interval to 15 seconds
ReefAngel.Timer[4].Start();
ReefAngel.StandardLights(Port1);
ReefAngel.StandardHeater(Port2);
ReefAngel.StandardLights(Port3,19,00,11,00);
ReefAngel.StandardATO(Port7);
//ReefAngel.DosingPumpRepeat(Port8,0,1440,3); // Dose for 6 second every 24 hours with 0 minutes offset
// PWMSlope based on Internal Memory values for Standard Lights
ReefAngel.PWM.ActinicPWMSlope(90);
if (ReefAngel.Timer[1].IsTriggered())//Wavemakers' Control
ReefAngel.Timer[2].Start();
ReefAngel.Relay.On(Port6);//Wavemaker 2
if (ReefAngel.Timer[2].IsTriggered())//Wavemakers' Control
ReefAngel.Relay.Off(Port6);
// Dump Params
Serial.flush();
Serial.print("<RA><T1>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT1));
Serial.print("</T1><T2>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT2));
Serial.print("</T2><T3>");
Serial.print(ReefAngel.TempSensor.ReadTemperature(ReefAngel.TempSensor.addrT3));
Serial.print("</T3><PH>");
Serial.print(ReefAngel.Params.PH);
Serial.print("</PH><R>");
Serial.print(ReefAngel.Relay.RelayData,DEC);
Serial.print("</R><RON>");
Serial.print(ReefAngel.Relay.RelayMaskOn,DEC);
Serial.print("</RON><ROFF>");
Serial.print(ReefAngel.Relay.RelayMaskOff,DEC);
Serial.print("</ROFF></RA>");
