Type of cable for additional relay box - true USB?
Posted: Fri Aug 03, 2012 10:55 am
by garcastle
My main tank is in my kitchen and my sump/fuge/etc are in the basement. I bought a second relay box to run things in the basement.
So my question is: can I use a generic USB extension cable to extend the cable that "seems" to be USB to mini-USB? I just want to make sure the pin-out is the same, etc. and that I do not fry anything. :^)
Thanks! Every thing else is working great.
Cheers,
Gordon
Re: Type of cable for additional relay box - true USB?
Posted: Fri Aug 03, 2012 11:09 am
Yes, cable is USB. Make sure you get a good quality shielded cable if you are extending it or you may experience interferences coming from noise that gets absorbed in the long run.
Posted: Fri Aug 03, 2012 12:25 pm
by garcastle
Will do, thanks Roberto!
Cheers,
Gordon
