Outlet Socket Assignment?
Posted: Sun Aug 12, 2012 1:31 pm
by Piper
Is this the correct outlet socket assignment for the current relay boxes?
Going off of this image I had two of my powerheads plugged into 5 and 6 for the wavemaker ports but they were not working. I plugged them into what would be 3 and 4 and they are working.
This is on the Relay Expansion Module if that makes a difference. The main module appears to be working as normal. Any ideas?
~Charlie
Re: Outlet Socket Assignment?
Posted: Sun Aug 12, 2012 1:43 pm
Yeap. That's correct.
Posted: Sun Aug 12, 2012 1:50 pm
by Piper
I can't seem to get ports 5 and 6 to work at all. I can get 7 and 8 to work through the portal with a light plugged into the outlet. Same with 1 and 2. 3 and 4 seem to be my wavemaker ports.
Is this something do do with the wiring in the box? My wiring of the relay expansion box? Or possibly my code?
~Charlie
Posted: Sun Aug 12, 2012 1:51 pm
can you post your code?
Posted: Sun Aug 12, 2012 2:01 pm
by Piper
Here's what I'm using now:
// Define relay box ports
// Relay Box #1
#define  ReturnPump     Box0_Port1
#define  Skimmer        Box0_Port2
#define  FugeLight      Box0_Port3
#define  Unused         Box0_Port4  // Not used
#define  PowerHead_1    Box0_Port5
#define  PowerHead_2    Box0_Port6
#define  AlkDoser       Box0_Port7
#define  CalDoser       Box0_Port8
// Relay Box #2
#define  Heater         Box1_Port1
#define  ReefBrite      Box1_Port2
#define  Kessil_A150_1  Box1_Port3
#define  Kessil_A150_2  Box1_Port4
#define  PowerHead_3    Box1_Port5
#define  PowerHead_4    Box1_Port6
#define  Kessil_A350_1  Box1_Port7
#define  Fans           Box1_Port8
boolean wmDelay = false;
byte    wmPort  = PowerHead_1;
byte lightOffset = InternalMemory.ActinicOffset_read();
boolean lightsAreOn () {
  boolean lightsOn = false;
  int lightsOnMins  = NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read()) - lightOffset * 2;
  int lightsOffMins = NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read()) + lightOffset * 2;
  int currentMins   = NumMins(hour(), minute());
  if (currentMins >= lightsOnMins && currentMins <= lightsOffMins) {
    lightsOn = true;
  } else {
    lightsOn = false;
  return lightsOn;
    ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
    ReefAngel.FeedingModePortsE[0] = Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPortsE[0] = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On(ReturnPump);
    ReefAngel.Relay.On(Skimmer);
    ReefAngel.AddWifi();
    randomSeed(analogRead(0));
    ReefAngel.Timer[1].SetInterval(random(18,45));
    ReefAngel.Timer[1].Start();
    // Trun on ReefBrite (2 * offset) minutes before full daylight
    ReefAngel.StandardLights(ReefBrite, lightOffset * 2);
    // Turn on Kessil A150s (offset) minutes before full daylight
    ReefAngel.StandardLights(Kessil_A150_1, lightOffset);
    ReefAngel.StandardLights(Kessil_A150_2, lightOffset);
    // Turn on Kessil A350 at standard daylight setting
    ReefAngel.DayLights(Kessil_A350_1);
    // We always want the fans on when the lights are on to vent the canopy.  When the lights
    // are out we want to run the fans in standard fan mode so they only turn on when needed.
    // We want to run the fuge light opposite daylight
    if (lightsAreOn()) {
      ReefAngel.Relay.On(Fans);
      ReefAngel.Relay.Off(FugeLight);
    else {
      ReefAngel.StandardFan(Fans);
      ReefAngel.Relay.On(FugeLight);
    // wavemaker timers and slow down at night
    // http://forum.reefangel.com/viewtopic.php?f=12&t=1588&p=12403
    if (ReefAngel.Timer[1].IsTriggered()) {
      // Night Mode
      if (!lightsAreOn()) {
        // Always turn off powerheads 3 and 4 at night.
        ReefAngel.Relay.Off(PowerHead_3);
        ReefAngel.Relay.Off(PowerHead_4);
        if (wmDelay) { // wm night delay
          ReefAngel.Timer[1].SetInterval(30);
          ReefAngel.Relay.Off(PowerHead_1);
          ReefAngel.Relay.Off(PowerHead_2);
          wmPort == PowerHead_1 ? wmPort = PowerHead_2 : wmPort = PowerHead_1;
          wmDelay = false;
        else {
          ReefAngel.Timer[1].SetInterval(20); // short wave
          ReefAngel.Relay.On(wmPort);
          wmDelay = true;
      // Day Mode
      else {
        ReefAngel.Timer[1].SetInterval(random(15,45));
        ReefAngel.Relay.Toggle(PowerHead_1);
        ReefAngel.Relay.Toggle(PowerHead_3);
        if (bitRead(ReefAngel.Relay.RelayData,PowerHead_1 - 1)) {
        } else {
          ReefAngel.Relay.On(PowerHead_2);
          ReefAngel.Relay.On(PowerHead_4);
    // Turn on the moonlight at night
    else {
      ReefAngel.PWM.SetDaylight(0);
      ReefAngel.PWM.SetActinic(0);
    // Set up the dosing pumps.
    ReefAngel.DosingPumpRepeat1(CalDoser);
    ReefAngel.DosingPumpRepeat2(AlkDoser);
    ReefAngel.Portal("xxxx", "xxxx");
    int x,y;
    ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 106, TempRelay );
Posted: Sun Aug 12, 2012 7:10 pm
That's some nice coding :)
I'm impressed on how you picked up on the coding so quick!!!
I don't see anything wrong or out of ordinary.
Can you test the ports with this code?
int port=0;
  ReefAngel.Init();
  This code will display:
  Temperature probes
  pH probe
  Daylight PWM % (if the feature is enabled)
  Actinic PWM % (if the feature is enabled)
  Relay box
  Time/Date
  ATO port status
  It will blink the red status LED and increment the PWM % every second.
  Moving or pressing the joystick will activate another port in the relay box.
  if (ReefAngel.Joystick.IsUp() || ReefAngel.Joystick.IsRight()) port++;
  if (ReefAngel.Joystick.IsButtonPressed()) port++;
  if (ReefAngel.Joystick.IsDown() || ReefAngel.Joystick.IsLeft()) port--;
  if (port>7) port=0;
  if (port<0) port=7;
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,10,"Port   On");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,45,10,port+1);
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,20,"Low ATO");
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,65,20,"Closed");
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,65,20,"Open  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,30,"High ATO");
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,70,30,"Closed");
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,70,30,"Open  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,15,40,"Status LED ");
  if (now()%2==0)
    ReefAngel.LED.On();
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,80,40,"On ");
    ReefAngel.LED.Off();
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,80,40,"Off");
  ReefAngel.Relay.RelayData=1<<port;
  //Box1_Port
  ReefAngel.Relay.RelayDataE[0]=1<<port;
  ReefAngel.PWM.SetActinic(now()%100);
  ReefAngel.PWM.SetDaylight(now()%100);
  ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params);
  ReefAngel.LCD.DrawOutletBox(12, 103, ReefAngel.Relay.RelayData);
  ReefAngel.LCD.DrawDate(6, 122);
  ReefAngel.Relay.Write();
  ReefAngel.Refresh();
Posted: Sun Aug 12, 2012 7:44 pm
by Piper
That code makes all the ports work as expected when testing each box individually. What's odd is that if I have the Relay Expansion Module hooked up while I'm testing the main box I get odd ports that turn on in the expansion box. It must be something to do with the Relay Expansion Module?
Is there anything special about the USB cable that came with the relay expansion module? The end the plugs into the main relay box was broken so I used a regular USB cable I had laying around in the cable drawer.
~Charlie
Posted: Sun Aug 12, 2012 7:47 pm
by Piper
rimai wrote:That's some nice coding :)
I took a couple of semesters of C and C++. After working with the code yesterday and today I can sure tell that it was a *loooong* time ago too :)
Looking through the docs that lnevo put up (http://www.easte.net/RA/html/index.html) helped a lot too. I can't wait to get my RA up and running and start working on the docs. Just what lnevo put up so far has been a big help!
~Charlie
Posted: Sun Aug 12, 2012 7:54 pm
No, nothing special about the usb cable.
The code was supposed to scroll through each port in the expansion box too, just like in the main box.
When you say odd, do you mean they don't turn on according to the sequence??
Posted: Sun Aug 12, 2012 8:08 pm
by Piper
I only had one row of outlets showing on the RA and assumed it was only able to test one box. Should I be seeing two rows if the expansion is set up correctly?
What I meant by odd is that when I got to port 3 on the main box (with the expansion plugged in) the ReefBrite strip plugged into the second box, Box1_Port2 I think, also turned up in addition to Box0_Port3.
Did I miss something when I set up the expansion?
Posted: Sun Aug 12, 2012 8:11 pm
Sorry, the test code was actually scrolling through both boxes at the same time even though it showed on line.
So, it should have been doing Box0_Port1 and Box1_Port1 at the same time, then Box0_Port2 and Box1_Port2 at the same time and so forth.
Posted: Sun Aug 12, 2012 8:17 pm
by Piper
Ooops - that makes more sense now :) Let me plug my light back and go hook the controller back up. Will let you know in a minute...
Posted: Sun Aug 12, 2012 8:31 pm
by Piper
OK - That worked as it should have. With the expansion hooked up it cycled through each port and both boxes fired off as expected.
So I have issues with my code somewhere?
Posted: Sun Aug 12, 2012 8:36 pm
That's what it is leading to.
Can you minimize your code to a few functions and go adding one at time as you go testing them??
Posted: Sun Aug 12, 2012 8:39 pm
by Piper
Yep! I'll let you know what I come up with.
Posted: Sun Aug 12, 2012 10:37 pm
by Piper
I went back to basically nothing and it's still acting haywire. I used the Wizard after that and it seemed to help but within 10 minutes it got all crazy on me again.
This is the code I have now:
    ReefAngel.LightsOnPorts = Port3Bit;
    ReefAngel.LightsOnPortsE[0] = Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.MoonLights( Port3 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.Wavemaker1( Port6 );
    ReefAngel.DosingPumpRepeat1( Port7 );
    ReefAngel.DosingPumpRepeat2( Port8 );
    ReefAngel.StandardHeater( Box1_Port1 );
    ReefAngel.ActinicLights( Box1_Port2 );
    ReefAngel.DayLights( Box1_Port3 );
    ReefAngel.DayLights( Box1_Port4 );
    ReefAngel.Wavemaker1( Box1_Port5 );
    ReefAngel.Wavemaker1( Box1_Port6 );
    ReefAngel.DayLights( Box1_Port7 );
    ReefAngel.StandardFan( Box1_Port8 );
    ReefAngel.Portal( "Piper" );
    int x,y;
    // Relay Expansion
If I use the portal to turn the ports on/off it works for some and not others. For instance, I can turn my fans off on Box1_Portt8 but then I can't turn them back on. I tried to turn on my alk pump on Port8 (Box0) and my fans came on! I'm confused...
Do I have something plugged in that the RA doesn't like maybe?
Box #1
Port 1 Little Giant pump
Port 2 EuroReef Skimmer
Port 3 T5 home depot shop light
Port 4 Not uesd
Port 5 Koralia pump
Port 6 Koralia pump
Port 7 Drew's doser pump
Port 8 BRS dosesr pump
Box #1
Port 1 Jager heater
Port 2 Reef Brite 50/50 strip
Port 3 Kessil A150
Port 4 Kessil A150
Port 5 Koralia pump
Port 6 Koralia pump
Port 7 Kessil A350
Port 8 4 x 12v DC fans hooked up to an in-line power supply w/ a 4-pin molex connector. The PS has puts out more than enough juice for the fans.
Do any of those not play nice with the RA?
~Charlie
Posted: Sun Aug 12, 2012 10:47 pm
by Piper
Roberto - One more question for you. On the wifi web server, http://xxx.xxx.xx.xxx:2000/wifi, should I see both sets of relay ports? I'm only seeing the main set up relays using that but I see both sets using the portal. Do I have something configured wrong maybe?
~Charlie
Posted: Mon Aug 13, 2012 4:17 am
by binder
Piper wrote:Roberto - One more question for you. On the wifi web server, http://xxx.xxx.xx.xxx:2000/wifi, should I see both sets of relay ports? I'm only seeing the main set up relays using that but I see both sets using the portal. Do I have something configured wrong maybe?
~Charlie
The internal webserver / wifi page only shows the main relay. It's not been updated yet to show additional relays.
Posted: Mon Aug 13, 2012 6:47 am
by Piper
I think I found the problem. The Koralia on Box1_Port6 was running backwards and I think that might have made everything go haywire once it kicked on for the first time. Where it's located in the tank I was not able to see that it wasn't running correctly and I replaced it with a desk lamp when I used the test code :)
After replacing the cover on that PH it started running normal and things seem to be working now. I might still have a problem with my fans. They don't seem to want to turn back on within a minute or two of being turned off. I don't know if that has something to do with the power adapter or not. I'll see if I can put a delayed start on that outlet and see if that makes a difference. When I got up this morning they were running to cool the tank so it seems they will come back on after a certain time period.
Curt - Thanks! That clears that up for me.
Posted: Mon Aug 13, 2012 8:22 am
Yeah, we need new /wifi page :(
Just curious if you have any problem when it is running on auto mode or the problem only presents itself when you try to override the relays.
Posted: Mon Aug 13, 2012 9:11 am
by Piper
It was acting up out as soon as I uploaded the code to the live controller but I'm fairly certain that was because of the Koralia running in reverse. It would get worse when I used the portal to go from auto to on/off. That seemed to be when I had the problems with the fans for sure. I would get a pop-up on the Portal that simply said "Error" and that was it. And that seem to be mostly (or only - can't be certain) when going from auto to on.
What are you using for the web server on the module and what did you code the /wifi page in?
Posted: Mon Aug 13, 2012 9:17 am
Want to give it a shot?
The /wifi does nothing but return a JS file.
<script language='javascript' src='http://www.reefangel.com/wifi/ra1.js'></script>
Everything is encoded inside the JS file
So, the javascript basically tells the browser to draw something and also to update the information every few seconds.
It pulls data with /r99. The data is XML encoded and all you need to do is parse it :)
Posted: Mon Aug 13, 2012 9:46 am
by Piper
I'll take a look at it. I want to get my controller dialed in and clean up the mess I left in front of the tank first though :)
Hmmm - /r99 only shows me output for the first relay. Does that need to be fixed on the server first?
Posted: Mon Aug 13, 2012 6:58 pm
by Piper
rimai wrote:Just curious if you have any problem when it is running on auto mode or the problem only presents itself when you try to override the relays.
Roberto - Are there any known issues with this? I got home tonight and the fans were no-op after the lights came on this morning. They worked all night but looking at the portal today I thought the tank temp and canopy temp were too high for the fans to be on. There was a sharp increase in temp shortly after the lights kicked on and the fans usually compete with the heater on the tank.
On top of that, two of the four lights did not kick on (or kicked off at some point before I got home) either. All of the malfunctioning outlets were in auto mode. Manually switching them with the portal did not make a difference.
Still stumped...
Posted: Mon Aug 13, 2012 7:28 pm
by Piper
I loaded the test code again and it worked fine the first time through. I used the portal to flip a couple of switches and it started getting funky again. Most of the outlets on the 2nd box were not responding to the portal after a couple of minutes of toggling.
[EDIT]
Using the controller to flip through the outlets after using the portal did not have the same results. On the main box all but ports 5 and 6 worked. No response at all on 5 and 6. No response from any port an the expansion relay.
[/edit]
Posted: Mon Aug 13, 2012 9:07 pm
by Piper
Pulled everything apart, swapped the relay boxes, wired everything back up, did the happy relay box dance and I can no longer replicate the strangeness. With the relay boxes at least...
Going to leave the default wizard code in for now. I'll let you know how it goes tomorrow.
~Charlie
Posted: Tue Aug 14, 2012 10:21 pm
by Piper
Everything is working fine still. It must have been a lose wire somewhere. I'll revert back to my original code this weekend when I have time to hang out and observe how things go.
~Charlie
