Wavemaker Help
manoverboard
Wavemaker Help
Hello, I am new to the Reef Angel and am still trying to grasp the entire concept of the coding. I currently have my wavemakers set up for one to come on for 15 seconds, and the other for 30 (the best option I could get it to do for me) on ports 5 and 6. What I was trying to do was to make one come on for 30 seconds, then when it goes off have the other turn on for 30 seconds while the first is toggled off. I am lost as to how to make this happen, and exactly what the code would look like to get these results. Also I am unclear as to where to put this code in when i start the controller up. Thanks in advance for any possible help.
Re: Wavemaker Help
Did you try using RAGen?
http://forum.reefangel.com/viewtopic.php?f=15&t=60
- Contact:
Re: Wavemaker Help
so you want the wavemakers to alternate every 30 seconds? when one turns off the other turns on, right?
chase
Re: Wavemaker Help
I would also be interested in this wavemaker option, thanks in advance!binder wrote:so you want the wavemakers to alternate every 30 seconds? when one turns off the other turns on, right?
psyrob
Re: Wavemaker Help
I was baffled with this too...what I finally did was set one for 46 seconds and one for 37, thinking the difference in the odd/even numbers would stagger the pumps some and lead to random flow...
chase
Re: Wavemaker Help
Hey rob,psyrob wrote:I was baffled with this too...what I finally did was set one for 46 seconds and one for 37, thinking the difference in the odd/even numbers would stagger the pumps some and lead to random flow...
After reading through several posts and spending some time messing around this is what I pieced together and it's working well:
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(15,35));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.Toggle(Port6);
I commented out my ReefAngel.Wavemaker1(Port5); & ReefAngel.Wavemaker2(Port6); functions as well because I think this messes with the random wavemaker code above.
I also read somewhere that port 5 and 6 have special relays designed for toggling back and forth between quick intervals, so that's why I'm using them...if anyone knows this to be true or not feel free to comment.
- Contact:
Re: Wavemaker Help
you are correct with the wavemaker functions interfering with you random functionality. So you should not use the wavemaker functions and the random functions together. You are doing the right thing.
Spotted
Re: Wavemaker Help
I am trying to get this random code into my code. What would I need to copy and paste into my code to get this to work?
I was also wondering if there was a way to add like a nutrient transport function that would turn on all the power heads for X amount of time then revert back to the random pattern maker?
I have 4 power heads. 2 on port 5 and 2 on port 6.
Here is my code
Off topic, I have also lost ability to calibrate my PH probe with this code. If I reload the original code, calibrate, then reload custom code will that work for calibration?
Here is my code
// Autogenerated file by RAGen (v1.2.2.171), (06/11/2012 09:50)
// RA_061112_0950.ino
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 5
#define ENABLE_ATO_LOGGING
#define IOEXPANSION
unsigned long clearsiphon=now();
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
prog_char menu5_label[] PROGMEM = "Clear Siphon";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
ReefAngel.DisplayMenuEntry("Lights On");
void MenuEntry5()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
ReefAngel.DisplayMenuEntry("Lights Off");
void MenuEntry6()
clearsiphon=now();
// Initialize the custom menu
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
//Light On/Off Ports
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.Relay.On(Port8); //Return Pump
//Adds Wifi function
ReefAngel.AddWifi();
ReefAngel.SingleATO(true,Port1,120,1); //ATO time out 2 minutes once every hour
ReefAngel.StandardLights(Port2,19,0,7,0); //Refugium Light on at 7PM off at 6AM
ReefAngel.StandardLights(Port3,6,0,7,0); //Overflow pump on at 6AM off at 7PM
ReefAngel.StandardLights(Port4,7,0,19,0); // Tank light on at 7AM off at 7PM
ReefAngel.StandardLights(Port5,6,0,22,0); //Turn off powerheads from 10PM to 6AM
ReefAngel.StandardLights(Port6,6,0,22,0); //Turn off powerheads from 10PM to 6AM
ReefAngel.Relay.DelayedOn(Port7, 5); //Skimmer
if (now()%clearsiphon<120)
ReefAngel.Relay.On(Port3);
BackSiphon(Port8,Port3);
void BackSiphon(byte MonitorPort, byte BackSiphonPort)
static byte laststatus=0;
static unsigned long lastnow=now();
byte currentstatus=ReefAngel.Relay.Status(MonitorPort);
if (laststatus!=currentstatus)
laststatus=currentstatus;
if (currentstatus) lastnow=now();
ReefAngel.Relay.Set(BackSiphonPort,now()%lastnow<300);
Re: Wavemaker Help
Try this:
Yes, the ph calibration can be done that way.
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
boolean NTM=false;
prog_char menu6_label[] PROGMEM = "Nutri Transp";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry6()
clearsiphon=now();
void MenuEntry7()
NTM=true; // Enable NTM mode
ReefAngel.Timer[1].Start(); // Start timer for NTM mode
ReefAngel.Timer[1].SetInterval(900); // Timer for Nutrient Transport mode
// ReefAngel.StandardLights(Port5,6,0,22,0); //Turn off powerheads from 10PM to 6AM
// ReefAngel.StandardLights(Port6,6,0,22,0); //Turn off powerheads from 10PM to 6AM
ReefAngel.WavemakerRandom(Port5,60,90); // Port 5 on random wavemaker
ReefAngel.Relay.Set(!ReefAngel.Relay.Status(Port5)); // Port 6 is opposite of Port5
if (ReefAngel.Timer[1].Istriggered) // if timer for NTM mode is expired
NTM=false; // disable NTM mode
if (NTM) // if we are on NTM mode, turn ports on
ReefAngel.Relay.On(Port6);
Spotted
Re: Wavemaker Help
Ok, getting an error on this line:
error is:
no matching function for call to 'RelayClass::Set(bool)'
Here's the rest of the result window:
The following feature was automatically added:
Watchdog Timer
Version Menu
Wifi
Custom Menu
Number of Menu Options: 7
Latest_9_19.cpp: In function 'void loop()':
Latest_9_19:151: error: no matching function for call to 'RelayClass::Set(bool)'
C:\Users\Lisy\Documents\Arduino\libraries\Relay/Relay.h:44: note: candidates are: void RelayClass::Set(byte, boolean)
Latest_9_19:153: error: 'class TimerClass' has no member named 'Istriggered'
Also I no longer need the clear siphon function. I got it on constant power now.
error is:
Watchdog Timer
Version Menu
Wifi
Custom Menu
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
boolean NTM=false;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry6()
clearsiphon=now();
void MenuEntry7()
ReefAngel.StandardLights(Port3,7,0,19,0); //Blue LED on at 7AM off at 7PM
ReefAngel.StandardLights(Port4,8,0,18,0); // Daylight on at 8AM off at 6PM
Re: Wavemaker Help
Try this:
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
boolean NTM=false;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry6()
clearsiphon=now();
void MenuEntry7()
ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Port 6 is opposite of Port5
if (ReefAngel.Timer[1].IsTriggered()) // if timer for NTM mode is expired
Spotted
Re: Wavemaker Help
Almost working just right, I appreciate all the help.
When Nutri Trans is stopped, random wave function does not resume. All PH remain on. Also, I don't know if it's possible to still shut off all PH after 10 PM?
Also, the clear siphon function is no longer needed as I have put ports 3&4 on to lights. I think the clear siphon is interfering with the light function.
Actually I have run out of space on my bar and until I can save enough for an expansion, I gotta run the siphon manually..
Thanks again!!
Thanks again!!
Spotted
Re: Wavemaker Help
Wait, I just found time value for the nutri transport mode. I wil continue testing tomorrow. The lights still don't work right though, port 3 where the aqualifter was for the siphon on the overflow.
Re: Wavemaker Help
Yeah, the mode will last 15minutes (900seconds).
You can change it as you wish.
Try this one. I removed the siphon:
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
boolean NTM=false;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry6()
clearsiphon=now();
void MenuEntry7()
Spotted
Re: Wavemaker Help
Ok, so this line
Is the line that says how long the PHs are on yes? Is it between 60 to 90 seconds? Just making sure so I can play with the timing. Thanks.
Awesome work.
ReefAngel.WavemakerRandom(Port5,60,90); // Port 5 on random wavemakerAwesome work.
Spotted
Re: Wavemaker Help
Is it not possible to get the PHs to shut off at 10PM? I wasn't able to test until tonight and they don't shut off.
Otherwise everything looks awesome.
Spotted
Re: Wavemaker Help
Try this:
#define wifi
#define WDT
#define CUSTOM_MENU
#define IOEXPANSION
boolean NTM=false;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry6()
clearsiphon=now();
void MenuEntry7()
if (hour()>=22 || hour()<6)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
Spotted
Re: Wavemaker Help
Awesome work, everything is working perfectly!!
Now on to another problem. I think I may have a bad PH probe. I tried to calibrate it like we discussed earlier, with the original RA code and I am not getting correct readings, I think.
First I rinsed in RO, then into 7.0 which read 469. Then rinsed again and into the 10 which read 474. I didn't think these numbers were any good, but I put the probe back in my sump and it jumped between 7 and 10. Nothing in between , just 7 or 10.
I then repeated the calibration and nothing really changed. Now it's in my sump and is reading 14!!
Any suggestions?
Any suggestions?
Spotted
Re: Wavemaker Help
So, as of this morning, I got a message on the screen says
No Internal Memory Found
Only the return pump was running. I tried reflashing and it looks like it uploads, lights on the unit blink and flash just like it was uploading and the programmer runs through the normal flash routine, but same message on the screen.
I tried power cycling and now nothing is running and I tried reflashing and same thing.
What to do now?
What to do now?
Re: Wavemaker Help
Upload InitialInternalMemory code
File->Sketchbook->Example Codes->InitialInternalMemory
Spotted
Spotted
Re: Wavemaker Help
Ok, got it back up and running. Any idea what might have happened, so I don't do it again?
Spotted
Re: Wavemaker Help
I restored the original code to calibrate the PH probe, but then reloaded my code. I then got caught up in the election and left the usb connected, but I had shut the PC down.
Came back in the AM and it was not working. To be honest, I'm not certain it was working right last night. It was after 10 when everything shuts off..
Anyhow, it's all working again, thanks!!
