Pwm help
Posted: Sat Aug 18, 2012 8:12 am
by simplefound
Hi all
I have set my reef angel up using the wizard, i filled in all fields including pwm for sunrise/set
My problem is, it has not turned my lights on I have checked on the controller and dp and ap are both at zero if I manually change it to 100% on both the lights come on
Am I missing something simple?
Thanks in advance
Re: Pwm help
Posted: Sat Aug 18, 2012 9:46 am
Can I see the code?
Sent from my SPH-D700 using Tapatalk 2
Pwm help
Posted: Sat Aug 18, 2012 10:32 am
by simplefound
Just ran through the wizard again and noticed time for lights are set
Daylight 12.00-10.00
Antics 11.00-11.00
I assume this is the problem as should be set in 24h 12.00-22.00 and 11.00-23.00
Sometimes it's the simplest things
