PH probe not working any longer
Posted: Sun Aug 19, 2012 7:52 am
by chachew
My pH probe has been working fine since i got my RA but all of the sudden the pH readings just stuck at 1.42 and never move.
I have reloaded my InitialInternalMemory code and then tried the probe again after a few reboots of the RA but to no avail. Any ideas?? It reads 1.42 and NEVER changes from that number
Re: PH probe not working any longer
Posted: Sun Aug 19, 2012 7:57 am
Try these:
Unplug USB cable.
Disconnect the float switches from the head unit.
Did anyone of the above make a difference on the reading?
Posted: Sun Aug 19, 2012 8:28 am
by chachew
I tried your suggestions above and they didnt effect the reading at all from the pH probe. I have also tried unplugging everything from the RA unit except the pH probe and then rebooted it, no changes to the readings.
Posted: Sun Aug 19, 2012 8:33 am
Does your probe look ok?
Check the glass bulb at the tip.
Posted: Sun Aug 19, 2012 9:01 am
by chachew
Yea everything looks fine, i have rinsed it off and checked for debris all looks good. It has been sitting in the same spot in the sump since i bought it. My whole setup is only about 3-4 weeks old so im stumped, it was working fine and all of the sudden one day i woke up and it wasn't reading correctly anymore.
Here is an image of it
Posted: Tue Sep 04, 2012 2:33 pm
by dwptwo
Did you ever find a solution for this? I have the exact same issue. I've also tried all of the above, reading is stuck at 1.42 and the calibration reads 0. My RA is about 30 days old. Maybe a bad probe? Thanks for the help.
Posted: Tue Sep 04, 2012 3:31 pm
by DrewPalmer04
I had a bad probe (2 mo old) Roberto sent me a new one but the new style's cable is wayyyy too short
Posted: Tue Sep 04, 2012 3:47 pm
by dwptwo
Thanks for the reply. I figured the probe was bad.
Posted: Wed Sep 05, 2012 5:44 pm
by chachew
Yes, the probe was bad. The new probe i got was the newer style, green, and it works perfectly. I agree the cable is a little too short compared to the other one. I did a test on my water as well for stray voltage and i had .2v reading from my water. I put in a tank ground probe and immediately read as 0v, maybe this could have burned out a probe?
Posted: Wed Sep 05, 2012 5:56 pm
by DrewPalmer04
The new probe corrected all the graphed pH swings. It's as stable as it should be because I know my pH is tight. New probe instantly corrected issues I had immediately with that old probe style.
