Dual PH Setup & Code
Posted: Thu Aug 23, 2012 5:34 am
by Lockes
Hey all
I have two ph probes
Probe 1 (currently installed) is for my main tank reading
Probe 2 is for the CO2 solenoid valve / reactor setup
Probe 2 will switch a plug on/off as per the standard co2 settings on Ragen
I want Probe 1 to also switch off that particular plug if the ph falls below 7.9
How do I do this?
Thanks in advance
ReefAngel.LCD.DrawDate(6, 64);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 19, 4 , "BOBS REEF");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 33, 15, "Tank Water");
char text[7];
ReefAngel.LCD.DrawHugeText(COLOR_GOLDENROD, DefaultBGColor, 38, 26, text);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 60, 42, "pH");
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 53, 50, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,84,"ATO");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,94,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,104,"CO2");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,114,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,84,"Return");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,94,"Vortech");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,104,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,114,"Heater");
ReefAngel.LCD.DrawCircleOutletBox(60, 86, TempRelay, true);
    InternalMemory.OverheatTemp_write( 260 );
    ReefAngel.SingleATO( true,Port2,60,0 );
    ReefAngel.StandardLights( Port3,4,0,23,0 );
    ReefAngel.CO2Control( Port6,752,748 );
    ReefAngel.StandardHeater( Port7,250,255 );
    ReefAngel.Portal( "Lockes" );
Re: Dual PH Setup & Code
Posted: Thu Aug 23, 2012 9:51 am
Use this:
char text[7];
    if (ReefAngel.Params.PHExp <= 748) Relay.Off(Port6);  // If probe 2 PH <= 7.48 - turn off CO2
    if (ReefAngel.Params.PHExp >= 752) Relay.On(Port6);  // If probe 2 PH >= 7.52 - turn on CO2    if (ReefAngel.Params.PH <= 790) Relay.Off(Port6);  // If PH <= LowPH - turn off CO2
    if (ReefAngel.Params.PH <= 790) Relay.Off(Port6);  // If probe 1 PH <= 7.90 - turn off CO2
Posted: Wed Sep 05, 2012 10:36 am
by Lockes
Thank you for your reply
I am still awaiting my ph expansion so have not yet tried this
Just to confirm will the plug switch on once it raises again?
Posted: Wed Sep 05, 2012 10:46 am
yes
Posted: Sun Sep 16, 2012 3:10 am
by Lockes
I am getting an error unfortunately
'Relay' was not declared in this scope
And it highlights - if (ReefAngel.Params.PHExp <= 735) Relay.Off(Port6); // If probe 2 PH <= 7.35 - turn off CO2
char text[7];
Posted: Sun Sep 16, 2012 5:56 am
Change Relay.Off to ReefAngel.Relay.Off in that line.
Posted: Sun Sep 16, 2012 8:07 am
by Lockes
Thanks but got another
In file included from sketch_sep16a.cpp:26:
C:\Users\Andrew\Documents\Arduino\libraries\ReefAngel/ReefAngel.h:109: error: 'PHClass' does not name a type
char text[7];
    if (ReefAngel.Params.PHExp <= 735) ReefAngel.Relay.Off(Port6);  // If probe 2 PH <= 7.35 - turn off CO2
    if (ReefAngel.Params.PHExp >= 752) ReefAngel.Relay.On(Port6);  // If probe 2 PH >= 7.52 - turn on CO2    if (ReefAngel.Params.PH <= 790) Relay.Off(Port6);  // If PH <= LowPH - turn off CO2
    if (ReefAngel.Params.PH <= 790) ReefAngel.Relay.Off(Port6);  // If probe 1 PH <= 7.90 - turn off CO2
Posted: Sun Sep 16, 2012 8:10 am
Add this to the include section:
Posted: Sun Sep 16, 2012 8:51 am
by Lockes
Thanks for all the help and sorry for yet another question
Now it's too big unfortunately.
All I need is
2 X PH
2 X temp
1 X ATO
Wifi
Cannot seem to see what else I can exclude
Simple Menu
Binary sketch size: 33,150 bytes (of a 32,256 byte maximum)
processing.app.debug.RunnerException: Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
at processing.app.Sketch.size(Sketch.java:1844)
at processing.app.Sketch.build(Sketch.java:1775)
at processing.app.Sketch.build(Sketch.java:1750)
at processing.app.Editor$DefaultRunHandler.run(Editor.java:1867)
at java.lang.Thread.run(Thread.java:619)
char text[7];
Posted: Sun Sep 16, 2012 10:16 am
You will need to remove the large fonts you are using in your code.
