RAClient relays status
Posted: Fri Aug 24, 2012 5:28 pm
by Bogdan
I am running the preloaded code with some modifications done via the RAClient. I set the light (Both D and A) to be on but on the RAClient the status of these two relays is mask OFF, can't change it to Auto. So the light is OFF as well. How can I fix it. I can turn them on only when I click the mask ON, but they are off when I click AUTO.
Re: RAClient relays status
Posted: Fri Aug 24, 2012 5:36 pm
Is the red status led lit?
Could be that it sensed overheat, which causes your lights to be masked off.
This line defines the ports to be shut off in case of overheat:
  ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
Posted: Fri Aug 24, 2012 5:44 pm
by Bogdan
You are so right. I increase the overheat temp. and lights work like they should. BTW the temp. probes showing 85F (if you remember) were right, I checked them with a precise lab thermometer. I guess these 4 small pumps working non stop in my setup are heating the water up ~ 5F.
Posted: Fri Aug 24, 2012 5:51 pm
by Bogdan
The Status LED red light (on controller)however is still on.
Posted: Fri Aug 24, 2012 5:59 pm
by Bogdan
The wavemaker pump on relay 6 is set to 0 which stands for Always on, but the relay shows OFF and the pump doesnt work. I can turn it on when I click Mask ON
Posted: Fri Aug 24, 2012 6:03 pm
To clear it, use the joystick and go to clear overheat
Posted: Fri Aug 24, 2012 6:06 pm
by Bogdan
Red light cleared, thanks. How about the pump. How to turn it ON?
Posted: Fri Aug 24, 2012 6:08 pm
Change the code.
Use this instead of the wavemaker function:
ReefAngel.Relay.On(Port6);
Posted: Fri Aug 24, 2012 6:10 pm
by Bogdan
OK, but how do I edit the code? I opened the Arduino but don't know how to edit the code, sorry.
Posted: Fri Aug 24, 2012 6:13 pm
If you are still using the preloaded code, you can go to menu File->Sketchbook->RA_Preloaded
Posted: Fri Aug 24, 2012 6:23 pm
by Bogdan
Yes, thanks.
Posted: Fri Aug 24, 2012 6:29 pm
by Bogdan
Whenever I change the code It doesn't want to upload, the massage is com 5 already in use. So I have to use Windows task manager to stop the RAListner and RALogger, the I am able to upload the code. After that I need to use the task manager again to start the RAListner and RALogger. Is there any simpler way to get the code uploaded?
Posted: Fri Aug 24, 2012 6:45 pm
by Bogdan
How about relay 2 (Moon/fuge light), how can I control it (change the default setup). I can't do it via RAClient, so I need to change the code. I would like to turn on the light at 10PM and turn OFF at 10AM.
Posted: Fri Aug 24, 2012 7:33 pm
by Bogdan
OK I see that the moon lights turn on when the daylight turn off. YEs, I can live with that.
Posted: Fri Aug 24, 2012 7:35 pm
Yes, if you are using the Client, you need to start an d stop services whenever you want to communicate with the controller.
The Client needs to maintain a constant connection with your controller or it won't be able to pull data from it.
