Salinity module works inversely to the way it should?
Posted: Sat Aug 25, 2012 8:03 am
Hi,
I have the salinity module, which seems to be working well, but have discovered that it works inversely to the way it should!!
I calibrate to 35ppt, no problem, BUT, if I put in RO water (effectively open circuit) it indicates a salinity of 60ppt and if I put it in some very salty water, it indicates a low salinity, so its working back to front?
Why???
When I set up, I didn't do the bit below, but just assumed as it worked, that it didn't need doing?
Setting up your Reef Angel Head Unit
1. Your Reef Angel Head unit needs to be setup to be able to communicate with any expansion modules.
2. You need to place the provided jumpers to the SDA and SCL pins.
Why???
