Trouble with LED PWM Output
Posted: Tue Jul 19, 2011 3:13 pm
by icecool2
I'm trying to setup my LED system with the RA, but I'm not seeing any output on either of the PWM outs. Is there a test file I can test out to see if it is my code that's the problem?
Re: Trouble with LED PWM Output
Posted: Tue Jul 19, 2011 3:17 pm
Which libraries are you using?
Posted: Tue Jul 19, 2011 4:43 pm
by icecool2
I'm running v0.8.3. I should also point out that I ordered the pwm booster, but found it rattling around inside of the relay unit when it arrived. I took it out.
Posted: Wed Jul 20, 2011 3:07 pm
by icecool2
Turns out not having the booster on there is what caused the problem. If the booster isn't installed, you need to jumper across the pins to get an output. I installed two jumpers and everything is working great now.
