Portal Not Updating
fatman
Portal Not Updating
Post by fatman »
Having had some of the initial WiFi issues that some of the other members have experienced, I updated my WiFi module with the macro and reset the sleep mode as recommended in the forum topic. It's been running successfully for several hours :D In checking the portal I see that I'm connected, the portal shows the correct temp and pH, but the colors on the lights that are on stay red in automatic even though they are on. Is there a setting I can change to correct this?
Fat
Re: Portal Not Updating
Do you have the Portal() function in your code?
Seems like the last time the server got your info was several days ago
fatman
Post by fatman »
I will look and let you know.
As always, thank you!
Fat
