auto define reefangel_feature
Posted: Sun Sep 09, 2012 12:23 pm
this is new fonction???
i try to remove #define VersionMenu reappears
https://forum.reefangel.com/
byte WhiteValue=0;
byte BlueValue=0;
byte RoyalBlueValue=0;
//custom dysplay temp+on and off relay
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "TEMP pH");
char text[7];
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y,text);
#if defined AI_LED && ! defined RemoveAllLights
ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, 69, 78 ,"W:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(0), DPColor, 84, 78, 1);
ReefAngel.LCD.DrawText(APColor , DefaultBGColor, 69, 90 ,"B:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(1), APColor, 84, 90, 1);
ReefAngel.LCD.DrawText(APColor , DefaultBGColor, 94, 90 ,"RB:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.AI.GetChannel(2), APColor, 115, 90, 1);
ReefAngel.LCD.DrawMonitor(15, 65, ReefAngel.Params);
ReefAngel.LCD.DrawOutletBox(12, 97, TempRelay);
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(10,00)
#define End_Cloud_Before NumMins(22,00)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
WhiteValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,WhiteValue,0,180);
else lightningstatus=0;
if (lightningstatus)
WhiteValue=50;
BlueValue=50;
RoyalBlueValue=50;
WhiteValue=0;
BlueValue=0;
RoyalBlueValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
ReefAngel.AddWifi();
ReefAngel.AI.SetPort(lowATOPin);
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(10,InternalMemory.WM1Timer_read()));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port6);
ReefAngel.FeedingModePorts = B00110000;
ReefAngel.OverheatShutoffPorts = B00001110;
ReefAngel.WaterChangePorts = B11110001;
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Port7);
ReefAngel.StandardLights(Port3, 22, 00, 10, 00);
ReefAngel.StandardLights(Port2, 12, 00, 20, 00);
ReefAngel.StandardHeater(Port4);
ReefAngel.SingleATOHigh(Port1);
//wave maker fonction with night mode
if ( (hour() >= 22) || (hour() <= 9) ) // from 10p - 9a
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.AI.SetChannel(White,0);
ReefAngel.AI.SetChannel(Blue,MoonPhase()*0.04);
ReefAngel.AI.SetChannel(RoyalBlue,MoonPhase()*0.04);
// during the day
ReefAngel.Timer[1].SetInterval(random(20,25));
WhiteValue=PWMSlope(12,0,20,0,3,45,60,3);
BlueValue=PWMSlope(10,0,22,0,8,50,60,8);
RoyalBlueValue=PWMSlope(10,0,22,0,8,50,60,8);
CheckCloud();
ReefAngel.AI.SetChannel(White,WhiteValue);
ReefAngel.AI.SetChannel(Blue,BlueValue);
ReefAngel.AI.SetChannel(RoyalBlue,RoyalBlueValue);
