MH light on
Posted: Sat Jul 23, 2011 9:24 am
by trentdingo
Hey all, if I wanted to customize the screen on the unit to have a MH light on option, real quick what would the function to add in be?
also, did we ever figure something out to get scrolling menus or pages for our menu?
Re: MH light on
Posted: Sat Jul 23, 2011 10:42 am
Are you using RAGen?
Re: MH light on
Posted: Sat Jul 23, 2011 9:00 pm
by trentdingo
No I am not...
Ideally, I would like to just switch this line from MH Light off to MH Light on
ReefAngel.Relay.RelayMaskOn=B00000110;
I just dont know what code to put in there to specify for on instead of off...?
Re: MH light on
Posted: Sat Jul 23, 2011 9:34 pm
Can you post your code?
Re: MH light on
Posted: Sun Jul 24, 2011 7:30 pm
by trentdingo
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu1_label[] PROGMEM = "Water Change Mode";
prog_char menu2_label[] PROGMEM = "MH Lights On";
//prog_char menu3_label[] PROGMEM = "Cancel Override On";
//prog_char menu4_label[] PROGMEM = "Override ATO On";
prog_char menu3_label[] PROGMEM = "Clear Overheat";
prog_char menu4_label[] PROGMEM = "PWM Percentage 100%";
prog_char menu5_label[] PROGMEM = "PWM Percentage 60%";
prog_char menu6_label[] PROGMEM = "PWM Percentage 35%";
prog_char menu7_label[] PROGMEM = "PWM Percentage 10%";
prog_char menu8_label[] PROGMEM = "Restore PWM";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label};
byte SavedPWMValue = 255;
This block runs only once at start-up. It's called setup() function.
It initializes the controller, builds the menu system and turns on the pumps/powerheads
A couple of assumptions were made in this code:
Temp1 is water temperature sensor readings
Temp2 is lights temperature sensor readings
ReefAngel.LoadMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Load Menu items from above
ReefAngel.Relay.On(ATO); //Turn on ATO at startup
ReefAngel.Relay.On(Sump); //Turn Sump on at startup
ReefAngel.Relay.On(LEDs); //Turn on LED at startup
ReefAngel.Relay.On(WM1); //Turn WM1 on at startup
ReefAngel.Relay.On(WM2); //Turn WM2 on at startup
//ReefAngel.Timer[0].Interval=10; // Uncomment to override feeding timer. Default is 900 seconds
//ReefAngel.Timer[3].Interval=5; // Uncomment to override screen saver timer. Default is 600 seconds
//ReefAngel.Timer[3].Start(); // Uncomment to start screen saver timer if you uncommented line above
This block runs forever, over and over again. It's called loop() function.
ReefAngel.StandardGUI(); //Draw the Standard GUI
This block is where you setup your main functions
ReefAngel.MHLights(MHlight,11,30,22,15,15); // Setup Daylight to turn on at 11:30AM and off at 10:15PM / Delay 15mins in case of power failure
ReefAngel.StandardHeater(Heater,789,803); // Setup Heater to turn on at 78.9F and off at 80.3F
ReefAngel.StandardFan(Chiller,797,811); // Setup Chiller to turn on at 81.1F and off at 79.7F
//ReefAngel.StandardATO(AutoTopOff,60); //Setup ATO to turn on at ATOlow and off at ATOhigh / Timeout set to 60s
ReefAngel.Timer[1].Interval=170; // set timer to x seconds - Timer 1 is used for wavemaker 1
ReefAngel.Timer[2].Interval=245; // set timer to x seconds - Timer 2 is used for wavemaker 2
If the controller is on default mode and it is showing the default screen, the value of SelectedMenu will be 255.
So, we check to see if the value is 255 and if it is, it'll check whether or not it should toggle the wavemaker powerheads WM1 and WM2 on or off.
if (ReefAngel.SelectedMenu==255) // Default Mode - Main Screen
if (ReefAngel.Timer[1].IsTriggered()) // If timer 1 expires
ReefAngel.Timer[1].Start(); // start timer
ReefAngel.Relay.Toggle(WM1); // toggle relay
if (ReefAngel.Timer[2].IsTriggered()) // If timer 2 expires
ReefAngel.Timer[2].Start(); // start timer
ReefAngel.Relay.Toggle(WM2); // toggle relay
If the controller is on "Feeding Mode", the value of SelectedMenu will be 0. This is based according to the menu created above
So, we check to see if the value is 0 and if it is, it'll turn Sump, WM1 and WM2 off. It will then display the feeding mode screen
if (ReefAngel.SelectedMenu==0) // Feeding Mode Selected
//ReefAngel.Relay.Off(Sump); //Turn Sump off
ReefAngel.Relay.Off(WM1); //Turn WM1 off
ReefAngel.Relay.Off(WM2); //Turn WM2 off
ReefAngel.FeedingModeGUI(); // Draw FeedingModeGUI
If the controller is on "Water Change Mode", the value of SelectedMenu will be 1. This is based according to the menu created above
So, we check to see if the value is 1 and if it is, it'll turn Sump, WM1 and WM2 off. It will then display the water change mode screen
if (ReefAngel.SelectedMenu==1) // Water Change Mode Selected
ReefAngel.WaterChangeModeGUI(); // Draw WaterChangeModeGUI
If the controller is on "Override Lights On", the value of SelectedMenu will be 2. This is based according to the menu created above
So, we check to see if the value is 2 and if it is, it'll set the relay mask to override the outlet 2 and 3 to always on, which are the MHlights and Actinic
It will also set the pwm channels to 50%, in case you are using LEDs.
if (ReefAngel.SelectedMenu==2) //Override Lights On Selected
ReefAngel.Relay.RelayMaskOn=B00000110; //Override Lights On;
ReefAngel.PWM.SetActinic(90); // Set PWM value
ReefAngel.PWM.SetDaylight(50); // Set PWM value
ReefAngel.LCD.DrawText(19,255,10,10,"Override Lights On");
If the controller is on "Cancel Override On", the value of SelectedMenu will be 3. This is based according to the menu created above
So, we check to see if the value is 3 and if it is, it'll set the relay mask to override the outlet 2 and 3 back to auto, which are the MHlights and Actinic
It will also set the pwm channels to 0%, in case you are using LEDs.
if (ReefAngel.SelectedMenu==3) //Override Lights Off Selected
ReefAngel.Relay.RelayMaskOn=B00000000; //Override Lights Off;
ReefAngel.PWM.SetActinic(0); // Set PWM value
ReefAngel.PWM.SetDaylight(0); // Set PWM value
ReefAngel.ReturnMenuFunction(); // Return from menu function;
If the controller is on "Clear ATO Timeout", the value of SelectedMenu will be 4. This is based according to the menu created above
So, we check to see if the value is 4 and if it is, it'll clear the ATO timeout flag and turn the status LED off
if (ReefAngel.SelectedMenu==4) //Clear ATO Timeout Selected
ReefAngel.LED.Off();
ReefAngel.ATO.topping=false;
If the controller is on "Clear Overheat", the value of SelectedMenu will be 5. This is based according to the menu created above
So, we check to see if the value is 5 and if it is, it'll clear the Overheat
if (ReefAngel.SelectedMenu==3) //Clear Overheat Selected
ReefAngel.Relay.RelayMaskOff=B11111111; //Override MHlight Auto;
The LED PWM signal 100% percentage will be defined here.
if (ReefAngel.SelectedMenu==4) // PWM signal 100% selected
// save the value if it's not currently stored
if ( SavedPWMValue == 255 )
SavedPWMValue = ReefAngel.PWM.ActinicPWMValue;
ReefAngel.PWM.SetActinic(100);
The LED PWM signal 50% percentage will be defined here.
if (ReefAngel.SelectedMenu==5) // PWM signal 50% selected
ReefAngel.PWM.SetActinic(60);
The LED PWM signal 35% percentage will be defined here.
if (ReefAngel.SelectedMenu==6) // PWM signal 35% selected
ReefAngel.PWM.SetActinic(35);
The LED PWM signal 0% percentage will be defined here.
if (ReefAngel.SelectedMenu==7) // PWM signal 10% selected
ReefAngel.PWM.SetActinic(13);
___________________________________________________________________________________
Restore PWM percentage menu
if ( ReefAngel.SelectedMenu == 8) // this is the restore PWM menu
// restore the value
if ( SavedPWMValue >= 0 && SavedPWMValue <= 100 )
ReefAngel.PWM.SetActinic(SavedPWMValue);
The Timer[0] is used as feeding mode timer.
When Timer[0] is triggered, it will turn the Sump on.
if (ReefAngel.Timer[0].IsTriggered()) // If feeding timer runs out
ReefAngel.Relay.On(Sump); //Turn Sump off
If Temp2 sensor reachs 150.0F, it will consider an overheat and will turn the lights off
if (ReefAngel.Params.Temp2>=835 && ReefAngel.Relay.RelayData & 0x6 == 0x6) // It Temp2 >= 83.5F
ReefAngel.LED.On();
ReefAngel.Relay.RelayMaskOff=B11111001; //Override MHlight 1 & 2 Off;
Writes the updated value to the relay box.
ReefAngel.Relay.Write(); // Make relay changes effective
/*contrast*/
ReefAngel.LCD.SetContrast(50); // Set contrast to 50
/*time*/
setTime(1282404765); // Unix time
//Just make sure you comment or remove this function after you run it once, otherwise every time it is executed, it will set the clock
//to that time over and over again.
//After you force the RTC to update, you have to sync Reef Angel's time to the RTC with these functions:
now();
ReefAngel.RTC.set(now());
/*pH*/
ReefAngel.PHMin=970;// 540=PH7.0 after it went weird min=100 and max=800 was 8.25pH...
ReefAngel.PHMax=740;// 980=PH10.0
Also, when I am uploading I keep throwing this error... any ideas on that?
Binary sketch size: 28368 bytes (of a 30720 byte maximum)
processing.app.SerialException: Serial port '/dev/cu.usbserial-FTF0GMBP' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.<init>(Unknown Source)
at processing.app.debug.Uploader.flushSerialBuffer(Unknown Source)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(Unknown Source)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(Unknown Source)
at processing.app.Sketch.upload(Unknown Source)
at processing.app.Sketch.exportApplet(Unknown Source)
at processing.app.Editor$DefaultExportHandler.run(Unknown Source)
at java.lang.Thread.run(Thread.java:680)
Re: MH light on
Posted: Sun Jul 24, 2011 7:55 pm
The error is wrong com port.
The code is missing the beginning of it, which is where the ports are defined.
Can you also post that?
Re: MH light on
Posted: Sun Jul 24, 2011 9:48 pm
by trentdingo
//Library headers. Necessary if you are using Reef Angel Controller
#include <EEPROM.h>
#include <NokiaLCD.h>
Give labels to your outlets
#define Sump 8
#define Heater 7
#define Chiller 6
#define WM1 5
#define WM2 4
#define MHlight 3
#define LEDs 2
#define ATO 1
Re: MH light on
Posted: Mon Jul 25, 2011 8:34 am
Hey Trent,
This line already turns LEDs and MHLight on.
I'm confused on what you want to do exactly.
Re: MH light on
Posted: Mon Jul 25, 2011 9:57 am
by trentdingo
Oh, my mistake then... I thought that was the code to turn them off. Thanks for the help.
So about the port issue. I am very confused because I was connecting just fine 2 days ago and then this error randomly threw last night. Where would i define which port exactly
Re: MH light on
Posted: Mon Jul 25, 2011 10:02 am
On the menu, go to Tool->Serial Port
Re: MH light on
Posted: Mon Jul 25, 2011 5:52 pm
by trentdingo
ok, it was just a one time thing then... not sure why it selected a different port yesterday but it was back to the correct port tonight. Thank you for your help
